Hiya, I have a heavily noise contaminated source (12db sig/noise) which contains a BPSK signal. I know the frequency, but obviously not the base phase or amplitude. Does anyone know any algorithms/code to decode this, and get the phase and ampltiude etc? I have other semi stationary noise frequencies near the one in question, if that helps selection at all. Any information, suggestions or even wild guesses warmly accepted. I'm sure this question must come up quite a bit... Thanks, M.
PSK help
Started by ●December 14, 2004
Reply by ●December 14, 20042004-12-14
"Miso Soup Addict" <mick_from-dsp@yahoo.com> wrote in message news:1103008071.496249.227520@f14g2000cwb.googlegroups.com...> Hiya, > > I have a heavily noise contaminated source (12db sig/noise) > which contains a BPSK signal. > > I know the frequency, but obviously not the base phase or amplitude. > > Does anyone know any algorithms/code to decode this, and get the > phase and ampltiude etc? > > I have other semi stationary noise frequencies near the one in > question, > if that helps selection at all. > > Any information, suggestions or even wild guesses warmly accepted. > > I'm sure this question must come up quite a bit... > Thanks, > M. >Hi! quite like Miso soup myself - not sure why though. Yep , it comes up a lot , 12 dB SNR is not at all bad and you can just matched filter , decimate and square to get a power estimate and phase reference (assuming you know what your symbol rate and shaping is). As you know what your frequency is you won't lose any signal power due to the matched filtering and should be able to get a pretty good synchronisation. You can then decide whether you would be better off without matched filtering (e.g. if you don't have white noise at your receiver). Best of Luck - Mike
"Miso Soup Addict" <mick_from-dsp@yahoo.com> wrote in message> I have a heavily noise contaminated source (12db sig/noise) > which contains a BPSK signal. > > I know the frequency, but obviously not the base phase or amplitude. > > Does anyone know any algorithms/code to decode this, and get the > phase and ampltiude etc?http://www.qsl.net/ae4jy/ao40rcv.htm Kind Regards, Howard
On 13 Dec 2004 23:07:51 -0800, "Miso Soup Addict" <mick_from-dsp@yahoo.com> wrote:>Hiya, > >I have a heavily noise contaminated source (12db sig/noise) >which contains a BPSK signal. > >I know the frequency, but obviously not the base phase or amplitude. > >Does anyone know any algorithms/code to decode this, and get the >phase and ampltiude etc? > >I have other semi stationary noise frequencies near the one in >question, >if that helps selection at all. > >Any information, suggestions or even wild guesses warmly accepted. > >I'm sure this question must come up quite a bit... >Thanks, > M.For BPSK 12dB is actually a pretty high SNR. Synchronization of BPSK/QPSK at 0-3dB SNR is done pretty frequently, so 12dB shouldn't be too bad. As others have suggested, using typical synchronizing loops will do the job, e.g., a Costas loop for the carrier and a traditional symbol recovery loop for the timing. There are quite a few texts out there that have examples, so you might try browsing digital comm texts that may be available to you. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
