Jim Thomas <jthomas@bittware.com> writes:> Randy Yates wrote: > > Jim Thomas <jthomas@bittware.com> writes: > [snip] > >>Again, I'm allowing ample room for the possibility that I'm wrong, so > >>don't be shy! Is your equation correct? > > Nope! You're right. I had a sign problem in the x's. This corrects > > that problem (hopefully > > > there are no others!): > > y[n] = x[n*M - 0*M - 0] * h[ 0*M + 0] + x[n*M - 0*M - > > 1] * h[ 0*M + 1] + ... + x[n*M - 0*M - (M-1)] * h[ 0*M + > > (M-1)] > > > + x[n*M - 1*M - 0] * h[ 1*M + 0] + x[n*M - 1*M - 1] * h[ 1*M + 1] + ... + x[n*M - 1*M - (M-1)] * h[ 1*M + (M-1)] > > + ... > > + x[n*M - (K-1)*M - 0] * h[(K-1)*M + 0] + x[n*M - (K-1)*M - 1] * h[(K-1)*M + 1] + ... + x[n*M - (K-1)*M - (M-1)] * h[(K-1)*M + (M-1)] > > Thanks for the correction, Jim. > > > That's better, and now I see what you mean. But... it seems to me > that arranging the filter equation into rows and columns like this is > somewhat artificial.I agree. But it sure sounds impressive.> At this point I'm just going to confuse people who already understand > polyphase filters but aren't confident in their understanding, and for > that, I apologize in advance. I guess I'm firmly in that same camp.I think you've got more on the ball than you think.> Each value of y depends on every filter tap, so I still don't see why > it's polyphase. If this is polyphase, aren't ALL FIRs polyphase?In a sense, yes. The difference between a "standard" FIR that is operating in a system in which the input and output sample rate is the same and a decimator is that you don't skip output computations. Once again I come to the point where I must state, supporting Jim's impression, that many things in DSP that "sound" very complex and intimidating are, when you cut through to the bottom line, aren't all that fancy. To me this "polyphase" stuff is in that category, but I admit that I haven't studied the higher concepts like those in the Vaidnayathan book on filter banks. Perhaps when you look at it from a linear algebra point-of-view there is more to see. -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
Sample Rate Conversion (Downsampling)
Started by ●December 14, 2004
Reply by ●December 17, 20042004-12-17
"Randy Yates" <randy.yates@sonyericsson.com> wrote in message news:xxpr7lp3pdz.fsf@usrts005.corpusers.net...> > Once again I come to the point where I must state, supporting Jim's > impression, that many things in DSP that "sound" very complex and > intimidating are, when you cut through to the bottom line, aren't all > that fancy. To me this "polyphase" stuff is in that category, but I > admit that I haven't studied the higher concepts like those in the > Vaidnayathan book on filter banks. Perhaps when you look at it from > a linear algebra point-of-view there is more to see.I agree with this. When I first about polyphase, it seemed to be like a rather obvious optimization. Most of the inputs to your filter are zero, so you don't bother including them in the calculation. Most of the outputs aren't used anyway, so you don't bother computing them. Simple! One other point, I first learned about polyphase in the context of sample rate conversion by a ratio of n/m, where 'the upsample by n' and 'downsample by m' are combined into a single filtering operation. In that case, you end up with what looks like a standard FIR low-pass filter (sinc-like shape) whose impulse response has been interpolated to a higher sample rate. But then you end up only using a part (one phase) of that filter for every output sample. To me, this rational conversion case is when you can really see the polyphase technique in action and can get a grasp on why it is called polyphase (literally 'many phases').
The most intuitive way I found to look at polyphase decimation (as I learned it) was through the "commutator" structure shown in the Crochiere book. If you start out by writing out the convolution sum for every n. y[n] = h[0]x[n] + h[1]x[n-1] + ... + h[N-1]x[n-N+1] , n=0,1,... For a rate-M decimator, throw away every M output samples and then look at your corresponding y[Mn] samples you wrote out above for a bunch of different n values, you will see the structure. Basically a direct-form decimator is similar to a standard FIR implementation, but instead of computing one y output for each x input, here you skip M samples in your x[n] history buffer for each y output sample. Hence your computations are reduced by M. For the polyphase approach, the commutator model basically does something similar where you commutate your samples into your structure - once you have injected M new samples into the filter you compute one output point. It is just another way to look at the efficient direct-form approach (but there are some subtle differences). I had to put together a paper for some non-DSP engineers, it does show the commutator model if you are interested: http://www.hyperdynelabs.com/dsp/DSP%20code%20optimizations.pdf Dont go grading me on it, the paper was a quick write up! Jim Jon Harris wrote:> "Randy Yates" <randy.yates@sonyericsson.com> wrote in message > news:xxpr7lp3pdz.fsf@usrts005.corpusers.net... > > > > Once again I come to the point where I must state, supporting Jim's > > impression, that many things in DSP that "sound" very complex and > > intimidating are, when you cut through to the bottom line, aren'tall> > that fancy. To me this "polyphase" stuff is in that category, but I > > admit that I haven't studied the higher concepts like those in the > > Vaidnayathan book on filter banks. Perhaps when you look at it from > > a linear algebra point-of-view there is more to see. > > I agree with this. When I first about polyphase, it seemed to belike a rather> obvious optimization. Most of the inputs to your filter are zero, soyou don't> bother including them in the calculation. Most of the outputs aren'tused> anyway, so you don't bother computing them. Simple! > > One other point, I first learned about polyphase in the context ofsample rate> conversion by a ratio of n/m, where 'the upsample by n' and'downsample by m'> are combined into a single filtering operation. In that case, youend up with> what looks like a standard FIR low-pass filter (sinc-like shape)whose impulse> response has been interpolated to a higher sample rate. But then youend up> only using a part (one phase) of that filter for every output sample.To me,> this rational conversion case is when you can really see thepolyphase technique> in action and can get a grasp on why it is called polyphase(literally 'many> phases').
<jshima@timing.com> wrote in message news:1103322876.125371.118970@f14g2000cwb.googlegroups.com...> The most intuitive way I found to look at polyphase decimation (as I > learned it) was through the "commutator" structure shown in the > Crochiere book. > > If you start out by writing out the convolution sum for every n. > > y[n] = h[0]x[n] + h[1]x[n-1] + ... + h[N-1]x[n-N+1] , n=0,1,... > > For a rate-M decimator, throw away every M output samples and then look > at your corresponding y[Mn] samples you wrote out above for a bunch of > different n values, you will see the structure. > > Basically a direct-form decimator is similar to a standard FIR > implementation, but instead of computing one y output for each x input, > here you skip M samples in your x[n] history buffer for each y output > sample. Hence your computations are reduced by M. > > For the polyphase approach, the commutator model basically does > something similar where you commutate your samples into your structure > - once you have injected M new samples into the filter you compute one > output point. It is just another way to look at the efficient > direct-form approach (but there are some subtle differences).I really like the commutator model as well, since it maps well in my brain with implementation in mind. However, I've always had trouble with most references that use this in their diagrams. For example, in the PP. Vaidyanathan book, Figure 4.3-9 (page 131) still doesn't make that much sense. The delay line in (a) makes sense. Then going from that to the exact order of how the commutator rotates doesn't seem intuitive. I woul've said, when n=0, the commutator is on the top branch. For n=1, I would've picked the 2nd branch (since it is one sample delayed from the top branch). But the book shows the 3rd branch. In the past, I've tried working through it with brute force and the book's answer does work out but it just wasn't sitting well with my intuition. I wonder if one of you guys can make me feel at ease. If some of you have been to fred harris' multi-rate class, his pictures look a little different as well (he starts his commutators at the bottom branch). Hmm...now that I look at it again, I think I know what I'm having difficulty with (and why), but I'd still like to hear some of your thoughts. Cheers Bhaskar> > I had to put together a paper for some non-DSP engineers, it does show > the commutator model if you are interested: > http://www.hyperdynelabs.com/dsp/DSP%20code%20optimizations.pdf > > Dont go grading me on it, the paper was a quick write up! > > Jim > > > > > > Jon Harris wrote: > > "Randy Yates" <randy.yates@sonyericsson.com> wrote in message > > news:xxpr7lp3pdz.fsf@usrts005.corpusers.net... > > > > > > Once again I come to the point where I must state, supporting Jim's > > > impression, that many things in DSP that "sound" very complex and > > > intimidating are, when you cut through to the bottom line, aren't > all > > > that fancy. To me this "polyphase" stuff is in that category, but I > > > admit that I haven't studied the higher concepts like those in the > > > Vaidnayathan book on filter banks. Perhaps when you look at it from > > > a linear algebra point-of-view there is more to see. > > > > I agree with this. When I first about polyphase, it seemed to be > like a rather > > obvious optimization. Most of the inputs to your filter are zero, so > you don't > > bother including them in the calculation. Most of the outputs aren't > used > > anyway, so you don't bother computing them. Simple! > > > > One other point, I first learned about polyphase in the context of > sample rate > > conversion by a ratio of n/m, where 'the upsample by n' and > 'downsample by m' > > are combined into a single filtering operation. In that case, you > end up with > > what looks like a standard FIR low-pass filter (sinc-like shape) > whose impulse > > response has been interpolated to a higher sample rate. But then you > end up > > only using a part (one phase) of that filter for every output sample. > To me, > > this rational conversion case is when you can really see the > polyphase technique > > in action and can get a grasp on why it is called polyphase > (literally 'many > > phases'). >
Reply by ●December 18, 20042004-12-18
In article <10s5p467bnklbfa@corp.supernews.com>, Jim Thomas <jthomas@bittware.com> wrote:>Each value of y depends on every filter tap, so I still don't see why it's >polyphase. If this is polyphase, aren't ALL FIRs polyphase?Yes. All this polyphase stuff is just a distraction, *except* for reasons of implementation efficiency. Standard resampling filters are all (usually windowed) variants of Sync (or sync-like) reconstruction FIRs, with the Sync width appropriate to the output sample rate, and with some phase. The phase seems to disappear from standard decimators because the default input to output phase is taken as zero (but you don't have to decimate that way!). Using Polyphase coefficient tables is one method of optimization if the input/output ratio is appropriate. But the input/output ratio can be irrational and you can still reconstruct with Sync coefficients, they just have to be appropriate coefficients for every output sample (calculated individually per sample or interpolated for instance). I've even found uses for resampling filters where the input/output ratio has been 1:1 (tuneable precision delay lines for instance). IMHO. YMMV. -- Ron Nicholson rhn AT nicholson DOT com http://www.nicholson.com/rhn/ #include <canonical.disclaimer> // only my own opinions, etc.
