Dear audio/DSP experts: Please go to my *Google Drive* and click once on the *AT&T* folder. http://goo.gl/Jm4bZ7 Watch the TV commercial (MP4) and listen to the background music. Since my objective is to apply some *Voice Identification* process to the audio, as a preliminary step, I would like to remove the music. I have already identified the song as "You're My Best Friend" by Queen. Being a newbie, I am only familiar with: • Adobe Audition • iZotope RX4 • Audacity but I don't believe they have such feature. I gather that you profs use something called DAW? Note: I found a free app which performs subtractions, but has been abandoned and it is really meant for signals which have very close content. http://www.libinst.com/Audio%20DiffMaker.htm How common is the "difference" operation? If it works as advertised, it should be extremely useful, right? TIA, -RFH
How to remove a track/signal from an audio clip?
Started by ●April 8, 2015
Reply by ●April 8, 20152015-04-08
On 08/04/2015 20:32, Ramon F Herrera wrote:> > Dear audio/DSP experts: > > Please go to my *Google Drive* and click once on the *AT&T* folder. > > http://goo.gl/Jm4bZ7 > > Watch the TV commercial (MP4) and listen to the background music. > > Since my objective is to apply some *Voice Identification* process to > the audio, as a preliminary step, I would like to remove the music. > > I have already identified the song as "You're My Best Friend" by Queen. > > Being a newbie, I am only familiar with: > > • Adobe Audition > • iZotope RX4 > • Audacity > > but I don't believe they have such feature. I gather that you profs use > something called DAW? >Those or other similar programmes running on a computer form a Digital Audio Workstation.> Note: I found a free app which performs subtractions, but has been > abandoned and it is really meant for signals which have very close content. > > http://www.libinst.com/Audio%20DiffMaker.htm > > How common is the "difference" operation? If it works as advertised, it > should be extremely useful, right? > >Depending on what you're trying to extract, you could try a karaoke filter, which will give you the mix less anything positioned central in the sound field, then subtract the result from the untreated track. Audacity has at least one available, though you might have to search the Web for a plugin. What are you trying to get, though? The only voices which sound recoverable in that track are already clear, and it sounds as if the final voice may not even be speaking English. Anything more would be in the field of forensic audio analysis and extraction, which is a much harder problem, often needing dedicated hardware and software. -- Tciao for Now! John.
On 4/8/2015 3:00 PM, John Williamson wrote:> What are you trying to get, though?The voice and only the voice at the end.> The only voices which sound > recoverable in that track are already clearClear to you (or any human ear) but not to a Speaker Identification or Voice Recognition software. I intend to verify that the voice belongs to the gentleman in the picture, by using audio clips known to be from him. This is the software that I plan to use: http://alize.univ-avignon.fr/ -Ramon
