I am a research scholar working in Power System related to Power Electronics devices. In my work I have to use PLL through assembly langeage programming (by TMS320LF2407A EVM board in Code Composer 2000 environment) for detecting the instantanous frequency of a 3ph transmission line. any one can help me to implement the same? regards jkm
implementation of PLL
Started by ●December 16, 2004
Reply by ●December 16, 20042004-12-16
Hello jkm, If you have at least two line voltages measured make dq-Transformation and "fix" the resulting vector by changing omega slightly. (If you don't have a weak net you can use a very slow PI-control for that.) Some people having only one voltage measured determine sin/cos-correlation factors to determine phase each period and make a correction afterwards. Be aware: Most People don't change frequency as net's frequency is very stable. They only determine a correction factor once a period and add/subtract a "peace of phase" to stay synchronuous in next period. For assembly language programming: - have a sin-table in memory. - apply MAC operation to voltage using sin-table - give out correction value at period end - ready A hint: I've never seen the real need to do assembly programming for 3ph power electronics as they mostly aren't the ultra cheap mass market product. As most people run a control loop related to the PWM frequency (e.g. 8kHz switching frequency using measured values in a 4kHz/8kHz or 16kHz loop) normaly the phase determination is done within this loop as a very small task. Second hint: Don't know but as TI has motor control specializsed DSP's (your's too ?) I'm shure that you can find prototype code for this ... (Don't do things others have done for you ...) Good luck, Wolfgang "jkm" <jkrushna@rediffmail.com> schrieb im Newsbeitrag news:6beddc36.0412152119.621f4c05@posting.google.com...>I am a research scholar working in Power System related to Power > Electronics devices. In my work I have to use PLL through assembly > langeage programming (by TMS320LF2407A EVM board in Code Composer 2000 > environment) for detecting the instantanous frequency of a 3ph > transmission line. any one can help me to implement the same? > > regards > jkm
