hello Shawn Steenhagen, I thank you for your answer. I've done so you said me. I took the magnitude of the result of rfft(). then I plotted it in ccs, but I haven't got the expected result. I expected to see only one peak, that correspond to the frequency of the sine. And if I take a rectangle input, then I don't see Harmonic waves and any peaks. I would like to sent you my quellcode or show you it somehow. It can be possible, that I write only one Line false, and that make my plott fals. can I upload my project somewhere on this site or like attachment in my message? thank you.
FFT build with DSP
Started by ●December 17, 2004
Reply by ●December 17, 20042004-12-17
You could probably cut and paste the high level main code showing how you are generating the sine wave, how you are calling the rfft( ) and how you are calculating the magnitude. Then perhaps myself (and others) will be able to help you, but I can't commit to debugging your project for you via this newsgroup. -Shawn "Eugene" <johnbesel@web.de> wrote in message news:6484110f.0412170527.75cdf065@posting.google.com...> hello Shawn Steenhagen, > I thank you for your answer. > > I've done so you said me. > I took the magnitude of the result of rfft(). > > then I plotted it in ccs, but I haven't got the expected result. I > expected to see only one peak, that correspond to the frequency of the > sine. > > And if I take a rectangle input, then I don't see Harmonic waves and > any peaks. > > I would like to sent you my quellcode or show you it somehow. It can > be possible, that I write only one Line false, and that make my plott > fals. > > can I upload my project somewhere on this site or like attachment in > my message? > > thank you.
