Is anybody using Sound Forge (v5 and above) and Acoustic Mirror to calculate impulse responses from sweeps? I bought the old stand alone Acoustic Modeler DX plugin from Sonic Foundry when they marketed it separately and it won't process recorded files or test sweeps or produce impulse responses over 16 bits. I'd like to know if the newer versions that are only bundled with Sound Forge have been upgraded to 32 bit float. Thanks, Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
Anybody Using S.F. Acoustic Mirror?
Started by ●December 19, 2004
Reply by ●December 20, 20042004-12-20
I think you have the wrong group. Isn't there a SF user forum somewhere out here on usenet, or maybe hosted at kvr? -- Stephan M. Bernsee http://www.dspdimension.com
Stephan M. Bernsee wrote:> > I think you have the wrong group. Isn't there a SF user forum somewhere > out here on usenet, or maybe hosted at kvr?I was hoping someone else here was interested in identifying linear systems in the audio band. I googled Sound Forge and couldn't find any forums. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
Reply by ●February 2, 20052005-02-02
Stephan M. Bernsee wrote:> > That may be because they belong to Sony now iirc... > > Try here: > > http://www.dmnforums.com/cgi-bin/displaywwugindex.fcgi?forum=sonic-foundry_soundforgeBingo! Thanks, Stephan. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
That may be because they belong to Sony now iirc... Try here: http://www.dmnforums.com/cgi-bin/displaywwugindex.fcgi?forum=sonic-foundry_soundforge -- -- Stephan M. Bernsee http://www.dspdimension.com
