Hello All Posting here after long time! I have acceleration data along with corresponding quaternions. The goal is to remove the bias from the acceleration by using quaternions. I found an implementation where accelerations ax and ay are converted to Euler angles (Phi and Theta) and quaternions are also converted to Euler angles (Phi, Theta and Psi). Then these Euler angles are passed to Unscented Kalman filter. This approach works, but it cannot filter az. How can I accomplish this. Many thanks. Best Regards Chintan --------------------------------------- Posted through http://www.DSPRelated.com
Acceleration signal and Kalman filter
Started by ●April 15, 2015
