Hi all, I want to compare two image objects... they look very similar to human visual system... but I want to find their similarities by metrics... The two image objects are embedded in two different large images... I mean, they are surrounded by dark or near-dark background in two larger images... And these two larger images are of different sizes and different sampling rate... And the two image objects aren't the same relative locations within the larger images... So how do I dig them out from their background and how do I compensate for different sampling rate in comparison? Thanksa lot
how to compare the two image objects with different size?
Started by ●December 21, 2004
Reply by ●December 21, 20042004-12-21
In article <cq9uqc$2kr$1@news.Stanford.EDU>, "lucy" <losemind@yahoo.com> wrote:> Hi all, > > I want to compare two image objects... they look very similar to human > visual system... but I want to find their similarities by metrics... > > The two image objects are embedded in two different large images... I mean, > they are surrounded by dark or near-dark background in two larger images... > > And these two larger images are of different sizes and different sampling > rate... And the two image objects aren't the same relative locations within > the larger images... > > So how do I dig them out from their background and how do I compensate for > different sampling rate in comparison? > > Thanksa lotgoogle: image warping google: pattern recognition -- Remove _me_ for e-mail address
Reply by ●December 22, 20042004-12-22
Use the brightness feature, as you mentioned, to separate the object from the background. Then, scale teh object to some normlized shape and then compare. Also, this may be of use.. I have found it helpful. http://www.ece.utexas.edu/~bevans/courses/ee381k/projects/fall00/rajagopal/litSurveyReport.pdf Isaac lucy wrote:> Hi all, > > I want to compare two image objects... they look very similar to human > visual system... but I want to find their similarities by metrics... > > The two image objects are embedded in two different large images... I mean, > they are surrounded by dark or near-dark background in two larger images... > > And these two larger images are of different sizes and different sampling > rate... And the two image objects aren't the same relative locations within > the larger images... > > So how do I dig them out from their background and how do I compensate for > different sampling rate in comparison? > > Thanksa lot > >
