I've started using a simple windowing function to low pass filter a 2D image. Following the FFT, I multiply in the frequency domain with a function that increases with distance from the origin (allowing for wrapping). Then I IFFT back to the image domain. Basically the window is this: f = sqrt(alpha / (alpha + x^2 + y^2)) where x,y range from 1-n/2 to n/2 and alpha is a scalar. Anyone know what this filter is called?
Name of this window
Started by ●December 22, 2004
Reply by ●December 23, 20042004-12-23
On 2004-12-23 01:47:28 +0100, spasmous@yahoo.com said:> Anyone know what this filter is called?A smoothing filter? -- Stephan M. Bernsee http://www.dspdimension.com
Stephan M. Bernsee wrote:> On 2004-12-23 01:47:28 +0100, spasmous@yahoo.com said: > > > Anyone know what this filter is called? > > A smoothing filter?Really? And what's it called when you're an idiot?
<spasmous@yahoo.com> wrote in message news:1103829541.581984.135040@f14g2000cwb.googlegroups.com...> Stephan M. Bernsee wrote: >> On 2004-12-23 01:47:28 +0100, spasmous@yahoo.com said: >> >> > Anyone know what this filter is called? >> >> A smoothing filter? > Really? And what's it called when you're an idiot? >Well Spasmous, The name of the filter is independent of Stephan's mental ranking. However he did describe its function correctly. Do you expect someone to give you an answer when you are so quick to insult?
spasmous@yahoo.com wrote:> I've started using a simple windowing function to low pass filter a 2D > image. Following the FFT, I multiply in the frequency domain with a > function that increases with distance from the origin (allowing for > wrapping). Then I IFFT back to the image domain. Basically the window > is this: > > f = sqrt(alpha / (alpha + x^2 + y^2)) > > where x,y range from 1-n/2 to n/2 and alpha is a scalar. > Anyone know what this filter is called? >If the "windowing" is done in the frequency domain it's called a filter, not a window. Now who's the idiot? -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Tim Wescott wrote:> If the "windowing" is done in the frequency domain it's called afilter,> not a window. >Mm hm? Well that's great. Did you check my spelling too?
spasmous@yahoo.com > killfile -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●December 24, 20042004-12-24
On 23 Dec 2004 12:38:14 -0800, spasmous@yahoo.com wrote:> >Tim Wescott wrote: > >> If the "windowing" is done in the frequency domain it's called a >filter, >> not a window. >> > >Mm hm? Well that's great. Did you check my spelling too?What is it with the noobs and their questions here lately? The homework density seems to be going up and now we get a crop of disrepectful twits that respond to help with insults. Either that or the trolls are bored again. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
Oh stop being a crybaby, I'm sure you've seen worse. But I'm intrigued by what you call "help"... in other groups we actually use the dictionary meaning.
