On Mon, 15 Jun 2015 13:36:21 -0400, Randy Yates <yates@digitalsignallabs.com> wrote:>N0Spam@daqarta.com (Bob Masta) writes: > >> On Sun, 14 Jun 2015 12:23:02 +0000 (UTC), >> spope33@speedymail.org (Steve Pope) wrote: >> >>>Bob Masta <NoSpam@daqarta.com> wrote: >>> >>>>On Sat, 13 Jun 2015 14:10:34 -0400, Randy Yates >>> >>>>>I wouldn't call it a vocoder. A vocoder uses subtractive synthesis, >>>>>while this technique uses additive synthesis (or you could call it a >>>>>type of additive synthesis). Also, a vocoder has two input channels, >>>>>while this only has one. >>> >>>>Apparently there must be vocoders out there that I haven't >>>>heard about, or you are using a different definition of >>>>"subtractive synthesis" than conventional music synth usage. >>> >>>>The classical vocoder is a bank of filters applied to the >>>>(single) input channel, each filter followed by some sort of >>>>detector, which then controls the amplitude of an oscillator >>>>(typically at the same frequency as the filter channel >>>>center). That's pretty much exactly what the piano gadget >>>>is doing. >>> >>>My belief is "vocoder" originally meant "voice encoder / decoder" >>>(or something close to that) and there were at least two >>>very common techniques, the phase vocoder being one, the others >>>mostly based on linear prediction (which could be said to be >>>"subtractive" but has nothing to do with "subtractive" synthesis >>>in electronic music. >> >> Apologies to Randy... I should have checked Wikipedia >> instead of relying on my ever-greying grey cells. > >Hi Bob, > >No problem. Been there, done that! > >> I was neglecting that the channel envelope followers in classical >> vocoders controlled *filters*, not *oscillator* amplitude. So of >> course the filter signal input is Randy's second input channel, and >> the filtering would be the subtractive synthesis he mentioned. > >Yes, exactly! Now we're communicating. > >> [...] > >>>Anything similar to these voice coders also got called (by somebody.. >>>does anyone remember who?) "vocoders" in electronic music. >>>But these could be broadly different from the original concepts. >>> >>>Steve >> >> Googling up on it now, it seems Moog and Carlos were using >> the full vocoder concept Back In The Day. But I seem to >> recall an "experimental" guy with a German or Eastern >> European name. Hafta dig through my dead tree collection... > >When you say "Carlos" did you mean Wendy Carlos (the switched-on-Bach >dude)?The very same. In fact, I have that album from the actual "dude" (Walter Carlos) days. Maybe it is a "collectible" now?>I was also trying to think of who Steve was referring to but came up >blank. >-- >Randy Yates >Digital Signal Labs >http://www.digitalsignallabs.com---- Bob Masta DAQARTA v7.60 Data AcQuisition And Real-Time Analysis www.daqarta.com Scope, Spectrum, Spectrogram, Sound Level Meter Frequency Counter, Pitch Track, Pitch-to-MIDI FREE Signal Generator, DaqMusiq generator Science with your sound card!
interesting application of dsp to music/audio
Started by ●June 6, 2015
Reply by ●June 16, 20152015-06-16
