Cell Phone DSP Hardware
Started by rickman June 10, 2015
Anyone know what DSP hardware is used in cell phones these days?  Did
the TI designs end up as IP on SoCs allowing software reuse or did one
of the several DSP startups get their IP onto the SoC devices requiring
a lot of porting?
Rick
In article <mlaiba$8jp$1@dont-email.me>, rickman  <gnuarm@gmail.com> wrote:
>Anyone know what DSP hardware is used in cell phones these days? Did >the TI designs end up as IP on SoCs allowing software reuse or did one >of the several DSP startups get their IP onto the SoC devices requiring >a lot of porting?
Not sure. I believe both TI and Broadcom have de-prioritized or exited that business, leaving Qualcomm and Mediatek (and, upstarts). TI will of course still do an SoC for you with their DSP cores and ARM cores. Qualcomm has its own in-house home grown DSP in their Snapdragon series. Not sure if it was something they obtained from a startup they swallowed up. I do not know what Mediatek uses. Steve
As has been discussed here many times before, this sort of information is often difficult to come by. Some of the more interested magazines sometimes do tear-downs to see what's in various models, and even then some chips may not give up much more info than who made them (and sometimes not even that). So figuring out what's going on at a detailed level of the implementation is often not public and often deliberately so. I've no idea, personally, and it's often a moving target, too. e.g., Samsung recently ditched Qualcomm and is now using their own chips. So there was a significant change there, and it is transparent to users and almost everybody but the suppliers themselves. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
rickman <gnuarm@gmail.com> writes:
> Anyone know what DSP hardware is used in cell phones these days? Did > the TI designs end up as IP on SoCs allowing software reuse or did one > of the several DSP startups get their IP onto the SoC devices > requiring a lot of porting?
Rick, Not THESE days, but when I was at Ericsson (late 90s/early 2000s), they had their own GSM chipset (all hardware) for many years that did pretty all the DSP in the tx/rx chain except the voice codecs, which, along with other audio processing, was done on a TI C54x DSP. -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
Randy Yates <yates@digitalsignallabs.com> writes:
> rickman <gnuarm@gmail.com> writes: > >> Anyone know what DSP hardware is used in cell phones these days? Did >> the TI designs end up as IP on SoCs allowing software reuse or did one >> of the several DSP startups get their IP onto the SoC devices >> requiring a lot of porting? > > Rick, > > Not THESE days, but when I was at Ericsson (late 90s/early 2000s), they > had their own GSM chipset (all hardware) for many years that did pretty > all the DSP in the tx/rx chain except the voice codecs, which, along > with other audio processing, was done on a TI C54x DSP.
PS: When Ericsson split off their handset development to Sony/Ericsson around 2001, they formed Ericsson Mobile Platforms to do chipset development. They were around for several years, but I'm not sure if they still are. Also, I don't know if either of these answer your inquiry - I may have not understood it correctly. -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
On 06/11/2015 11:56 AM, Randy Yates wrote:
> PS: When Ericsson split off their handset development to Sony/Ericsson > around 2001, they formed Ericsson Mobile Platforms to do chipset > development. They were around for several years, but I'm not sure if > they still are. > > Also, I don't know if either of these answer your inquiry - I may have > not understood it correctly. >
Ericsson's handset chipset business joined up with ST's, and then the whole thing closed down. Steve
On 6/11/2015 12:25 AM, Steve Underwood wrote:
> On 06/11/2015 11:56 AM, Randy Yates wrote: >> PS: When Ericsson split off their handset development to Sony/Ericsson >> around 2001, they formed Ericsson Mobile Platforms to do chipset >> development. They were around for several years, but I'm not sure if >> they still are. >> >> Also, I don't know if either of these answer your inquiry - I may have >> not understood it correctly. >> > Ericsson's handset chipset business joined up with ST's, and then the > whole thing closed down.
I seem to remember that. And that many stock analysts said it was not a good idea. -- Rick
On 6/10/2015 11:56 PM, Randy Yates wrote:
> Randy Yates <yates@digitalsignallabs.com> writes: > >> rickman <gnuarm@gmail.com> writes: >> >>> Anyone know what DSP hardware is used in cell phones these days? Did >>> the TI designs end up as IP on SoCs allowing software reuse or did one >>> of the several DSP startups get their IP onto the SoC devices >>> requiring a lot of porting? >> >> Rick, >> >> Not THESE days, but when I was at Ericsson (late 90s/early 2000s), they >> had their own GSM chipset (all hardware) for many years that did pretty >> all the DSP in the tx/rx chain except the voice codecs, which, along >> with other audio processing, was done on a TI C54x DSP. > > PS: When Ericsson split off their handset development to Sony/Ericsson > around 2001, they formed Ericsson Mobile Platforms to do chipset > development. They were around for several years, but I'm not sure if > they still are. > > Also, I don't know if either of these answer your inquiry - I may have > not understood it correctly.
Sure, an insight is helpful. I was just curious how the DSP thing worked out. I remember when cell phones were starting out TI made a decision to steer the whole semi part of the company (which may have ended up being pretty much the *whole* company) to support the cell phone business. At one time I think every hand set had a TI 5xxx DSP in it and every base station had a TI 6xxx DSP (or many I guess). Likely even the base stations have special chips in them now. -- Rick
>Sure, an insight is helpful. I was just curious how the DSP thing >worked out. I remember when cell phones were starting out TI made a >decision to steer the whole semi part of the company (which may have >ended up being pretty much the *whole* company) to support the cell >phone business.
Yep.
>At one time I think every hand set had a TI 5xxx DSP in >it and every base station had a TI 6xxx DSP (or many I guess). Likely >even the base stations have special chips in them now.
When I started working for TI in 2000, the narrative was that they were selling "a million chips a day" into the handset market, and that most phones had one or more TI chips in them. Although, these were not necessarily baseband chips, some could have been RF, little battery chargers, audio, whatever. When I left five years later, all had changed. TI are experts at exiting businesses well before a profit center turns into a loss center. And they are very careful about not overbuilding fab capacity... these guys simply do not do red ink. But I would not much doubt there are still plenty of TI DSP cores in TI-produced SoC's around. Steve
"rickman"  wrote in message news:mlaiba$8jp$1@dont-email.me...
>Anyone know what DSP hardware is used in cell phones these days? Did the >TI designs end up as IP on SoCs allowing software reuse or did one of the >several DSP startups get their IP onto the SoC devices requiring a lot of >porting?
Hi Rick, As far as I know the vast majority of baseband cell phone chips are based on DSP IP cores from companies like CEVA, TENSILICA. VERISILICON and similar. These DSP cores are of course integrated in custom ASICs. According to CEVA's web site, they are sold more than 5 billion DSP cores to date, more than 1 billion per year. Rober Lacoste www.alciom.com
