Hi I have done some work with BPSK modulation such modulating and demodulating the waveform and plotting the BER vs SNR under BPSK for AWGN channel. However I wonder how would I perform the simulation if the channel is bandlimited meaining that assume frequency response of channel is w/(w^3+w^2+w+1) then how to do demodulation and eventually finding the bit-error ? Thanks. --------------------------------------- Posted through http://www.DSPRelated.com
BER vs SNR under BPSK bandlimited channel
Started by ●June 24, 2015
Reply by ●June 24, 20152015-06-24
chess <106766@DSPRelated> wrote:>I have done some work with BPSK modulation such modulating and >demodulating the waveform and plotting the BER vs SNR under BPSK for AWGN >channel. However I wonder how would I perform the simulation if the >channel is bandlimited meaining that assume frequency response of channel >is w/(w^3+w^2+w+1) then how to do demodulation and eventually finding the >bit-error ?Probably the best approach is to use an Forney equalizer programmed with a truncated version of the impulse response of the above IIR filter. Most other approaches (matched filter, decision-feedback equalizer) will give you somewhat worse results, but depending on the extent of the bandlimiting, the effect could be pretty mild. Steve
