I just finished the reading of An introduction to different rounding algorithms, http://www.eetimes.com/document.asp?doc_id=1274485. I must admit I never pay much attention on the trick of the quantization. The approach of Round-toward-nearest is always used in my design. Did anyone have practical experiences to show the DSP filter performance improved or degraded by using Round-half-even instead of Round-toward- nearest? --------------------------------------- Posted through http://www.DSPRelated.com
Round-half-even or Round-toward-nearest
Started by ●June 29, 2015
Reply by ●June 29, 20152015-06-29
>I just finished the reading of An introduction to different rounding >algorithms, http://www.eetimes.com/document.asp?doc_id74485. I must >admit I never pay much attention on the trick of the quantization. The >approach of Round-toward-nearest is always used in my design. Didanyone>have practical experiences to show the DSP filter performance improvedor>degraded by using Round-half-even instead of Round-toward- nearest? > >--------------------------------------- >Posted through http://www.DSPRelated.comVarious rounding methods help avoid dc bias. With direct truncation dc is very likely as we always round towards minus inf. With classic rounding to nearest integer we don't expect much dc except if signal has dc offset. dc then occurs due to midpoint rounding bias. This also means that such dc bias gets high if we are rounding one or so LSB and it also explains build up of error in accumulators. For this end rounding to nearest even is used to avoid dc bias as the midpoint rounding is alternated. Kaz --------------------------------------- Posted through http://www.DSPRelated.com
