Hi all, I understood how to pass a stationary random process through a LTI syste... the autocorrelation of the output has a beautiful relation with the input's autocorrelations, and so does the power spectrum density... But what if my stationary zero mean Gaussian random process x(t) go through a non-linear system, for example, a signum device(output 1 for input x(t)>0 and output -1 for input x(t)<=0)) How to find the autocorrelation and the power spectrum density of the output if I was given an input autocorrelation? Thanks a lot!
how to pass a random process through a non-linear system?
Started by ●December 26, 2004
Reply by ●December 26, 20042004-12-26
"kiki" <lunaliu3@yahoo.com> wrote in message news:cqlmms$epv$1@news.Stanford.EDU...> Hi all, > > I understood how to pass a stationary random process through a LTIsyste...> the autocorrelation of the output has a beautiful relation with theinput's> autocorrelations, and so does the power spectrum density... > > But what if my stationary zero mean Gaussian random process x(t) gothrough> a non-linear system, for example, a signum device(output 1 for inputx(t)>0> and output -1 for input x(t)<=0)) > > How to find the autocorrelation and the power spectrum density of theoutput> if I was given an input autocorrelation? >I don't think you can.> Thanks a lot! > > >
kiki wrote:> Hi all, > > I understood how to pass a stationary random process through a LTI syste... > the autocorrelation of the output has a beautiful relation with the input's > autocorrelations, and so does the power spectrum density... > > But what if my stationary zero mean Gaussian random process x(t) go through > a non-linear system, for example, a signum device(output 1 for input x(t)>0 > and output -1 for input x(t)<=0)) > > How to find the autocorrelation and the power spectrum density of the output > if I was given an input autocorrelation? > > Thanks a lot! > > >If you have a stationary process with known distribution and autocorrelation, then you know: a: the probability distribution of the process at any point in time (this is also the case if you have a non-stationary process with a known time dependence). b: the conditional probability distribution of the process at any point in time given a sample of the process at some other point in time. If you have the above two bits of information and you pass the process through a memoryless nonlinearity (such as your signum function), then you should be able to extract: c: The probability distribution of the process at any point in time. d: The conditional probability distribution of the process at any point in time given a sample of the process at some other point in time. If you know (c) then you can specify whether your output process is stationary (it will be for a stationary input process -- it may not necessarily be for a non-stationary input, depending on the nature of the time dependence and your nonlinearity, I just don't know in general but in specific you should be able to do the math and find out). If you know (d) then you can extract the autocorrelation function. Then you have your answer. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Reply by ●December 29, 20042004-12-29
"kiki" <lunaliu3@yahoo.com> wrote in message news:cqlmms$epv$1@news.Stanford.EDU...> Hi all, > > I understood how to pass a stationary random process through a LTIsyste...> the autocorrelation of the output has a beautiful relation with theinput's> autocorrelations, and so does the power spectrum density... > > But what if my stationary zero mean Gaussian random process x(t) gothrough> a non-linear system, for example, a signum device(output 1 for inputx(t)>0> and output -1 for input x(t)<=0)) > > How to find the autocorrelation and the power spectrum density of theoutput> if I was given an input autocorrelation? > > Thanks a lot! > > >Yes I believe this has been done by Wiener. I think it is called the Wiener expansion and such work has been done by others independently eg Barrett back in the 1940s! It will take you quite a while to track down the refs but most of it is there. Country Chiel
Reply by ●December 30, 20042004-12-30
On Sat, 25 Dec 2004 22:45:48 -0800, kiki wrote:> Hi all, > > I understood how to pass a stationary random process through a LTI syste... > the autocorrelation of the output has a beautiful relation with the input's > autocorrelations, and so does the power spectrum density... > > But what if my stationary zero mean Gaussian random process x(t) go through > a non-linear system, for example, a signum device(output 1 for input x(t)>0 > and output -1 for input x(t)<=0)) > > How to find the autocorrelation and the power spectrum density of the output > if I was given an input autocorrelation? > > Thanks a lot!In general this is not an easy problem. In the case you have presented, however, there is a solution. The solution I have comes from Lawson and Uhlenbeck, "Threshold Signals," MIT Radiation Laboratory Series, McGraw-Hill, 1950, page 57. They reference an earlier Radiation Lab Report (Van Vleck, "The Spectrum of Clipped Noise," RRL Report 51, July 21, 1943), which you can purchase from the MIT library, last I checked. It's not cheap. Van Vleck's work was also published in the IEEE Proceedings a few years ago (1966?), with Middleton as a coauthor. The final result is Ry(t) = (2/pi)asin(Rx(t)/Rx(0)), where Ry is the output autocorrelation, and Rx is the input autocorrelation. The power spectrum of the noise is the Fourier Transform of Ry(t), which is often easy to calculate using numerical math packages. Note that if your input is not band-limited, then Rx(t)/Rx(0) = 1 when t = 0, and 0 elsewhere, making the Fourier Transform easy to calculate. -- Mike --
