Hi all, Can anybody suggest some methods of gaining 8-bit ADC/DAC performance with 6 bit only ADC/DAC? Any thoughts? Thanks a lot!
how to use 6 bit ADC/DAC to gain 8 bit ADC/DAC performance?
Started by ●December 29, 2004
Reply by ●December 29, 20042004-12-29
"kiki" <lunaliu3@yahoo.com> wrote in message news:cqtnk1$k7h$1@news.Stanford.EDU...> Hi all, > > Can anybody suggest some methods of gaining 8-bit ADC/DAC performance with > 6 bit only ADC/DAC? > > Any thoughts? Thanks a lot! > >You could try 4 off 6 bit ADCs or DACS and shift their input/output ranges to cover the same range as your 8 bit device? Best of Luck - Mike
"kiki" <lunaliu3@yahoo.com> writes:> Hi all, > > Can anybody suggest some methods of gaining 8-bit ADC/DAC performance with 6 > bit only ADC/DAC?One can use oversampling, or oversampling along with noise-shaping. The latter technique is commonly called a delta-sigma (some say sigma-delta, but they're wrong) converter. -- % Randy Yates % "Rollin' and riding and slippin' and %% Fuquay-Varina, NC % sliding, it's magic." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Living' Thing', *A New World Record*, ELO http://home.earthlink.net/~yatescr
kiki wrote:> Hi all, > > Can anybody suggest some methods of gaining 8-bit ADC/DAC performance with 6 > bit only ADC/DAC? > > Any thoughts? Thanks a lot! > > >Yes, but in all cases you'll be trading resolution for the need to oversample. I've written an article on extending DAC performance using sigma-delta techniques (sorry Randy). It only presents a first-order modulator, but that's worked well for me in the applications where I've used it. http://www.wescottdesign.com/articles/sigmadelta.html. To get more resolution on the ADC side you need to dither the input and oversample. You can either do this with sigma-delta techniques, which will require an additional DAC, or you can make an analog ramp or noise generator to sum into your incoming signal, which will require a higher oversampling rate than sigma-delta. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Tim Wescott <tim@wescottnospamdesign.com> writes:> sigma-delta techniques (sorry Randy).Well, apologize to Inose, Yasuda, and Murakami since these folks were the originators of the technique [1]. You're also contradicting James Candy and Max Hauser, per personal conversations with Max Hauser. --RY [1] @article{inose, title = "{A Telemetering System by Code Modulation---Delta-Sigma Modulation}", author = "{Inose, Yasuda, and Murakami}", journal = "IRE Transactions on Space Electronics and Telemetry", year = "1962", month = "September"} -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
You can use a PGA along with an DAC offset to track the signal if you are able to oversample it. If the gain saturates then you have to adjust the DAC offset or zoom out with the PGA. -Tim
Reply by ●December 30, 20042004-12-30
