no, by oversampling
how to use 6 bit ADC/DAC to gain 8 bit ADC/DAC performance?
Started by ●December 29, 2004
Reply by ●December 30, 20042004-12-30
Reply by ●December 31, 20042004-12-31
balchand wrote:> no, by oversamplingActually (as the smilie implied), my reply was a humourous response to the fact that you (presumably accidentally -- Google Groups in particular is notorious for that) posted *your* first reply twice in quick succession. :-)
Reply by ●January 2, 20052005-01-02
kiki wrote:> Hi all, > > Can anybody suggest some methods of gaining 8-bit ADC/DAC performancewith 6> bit only ADC/DAC? > > Any thoughts? Thanks a lot!Depends how good your 6 bit a/d is, integral nonlinearity is the spec you need to look at, if its only good to 6 bits, then the answer is you can't do it by oversampling. In this case you can still achieve your goal by using multiple 6 bit a/ds for each signal (basically break the analog signal into 6bit dynamic range chunks and feed it to a 6 bit a/d and digitally combined them)
Reply by ●January 3, 20052005-01-03
bungalow_steve@yahoo.com wrote:> > kiki wrote: > > Hi all, > > > > Can anybody suggest some methods of gaining 8-bit ADC/DAC performance > with 6 > > bit only ADC/DAC? > > > > Any thoughts? Thanks a lot! > > Depends how good your 6 bit a/d is, integral nonlinearity is the spec > you need to look at, if its only good to 6 bits, then the answer is you > can't do it by oversampling. In this case you can still achieve your > goal by using multiple 6 bit a/ds for each signal (basically break the > analog signal into 6bit dynamic range chunks and feed it to a 6 bit a/d > and digitally combined them)I think it depends on what you want to achieve. By oversampling, you can certainly improve the SNR (in all cases!). However, integral nonlinearity will limit the linear behaviour of the device (generation of harmonics of the input signal), oversampling or not. I did not do any calculations on this, but is it possible that the harmonic spurious in the signals's spectrum due to integral nonlinearity are smaller than the inband quantization noise? Jeroen
Reply by ●January 4, 20052005-01-04
Jeroen Boschma wrote:> bungalow_steve@yahoo.com wrote: > > > > kiki wrote: > > > Hi all, > > > > > > Can anybody suggest some methods of gaining 8-bit ADC/DACperformance> > with 6 > > > bit only ADC/DAC? > > > > > > Any thoughts? Thanks a lot! > > > > Depends how good your 6 bit a/d is, integral nonlinearity is thespec> > you need to look at, if its only good to 6 bits, then the answer isyou> > can't do it by oversampling. In this case you can still achieveyour> > goal by using multiple 6 bit a/ds for each signal (basically breakthe> > analog signal into 6bit dynamic range chunks and feed it to a 6 bita/d> > and digitally combined them) > > I think it depends on what you want to achieve. By oversampling, youcan certainly improve the SNR> (in all cases!). However, integral nonlinearity will limit the linearbehaviour of the device> (generation of harmonics of the input signal), oversampling or not. Idid not do any calculations on> this, but is it possible that the harmonic spurious in the signals'sspectrum due to integral> nonlinearity are smaller than the inband quantization noise? > > JeroenI believe oversampling only improves SNR when the noise is evenly distributed, a rogue clock signal near the a/d, for instance, would induce noise that could not be removed by oversampling. Integral nonlinearity can be improved by characterizing the a/d, so I guess that with oversampling could work (although I think hysteresis could bite you in the foot)
