DSP vs. Microprocessor
Started by dspguru_wannabe January 1, 2005
What is the most fundamental difference between a DSP (processor) and a
Microprocessor? I could list out a few, but what core features make a
DSP a DSP? What makes a Microprocessor not capable of performing DSP
applications unless emulated by software?
dspguru_wannabe wrote:
> What is the most fundamental difference between a DSP (processor) and a > Microprocessor? I could list out a few, but what core features make a > DSP a DSP?
The most fundamental difference that I see is a real full-blown MAC instruction that'll let you do a vector multiply (i.e. a FIR filter) at one clock cycle per tap. Having said that, a uP with a cheesy MAC add-on that doesn't give you pieces of MAC (for one cycle per tap vector copies, etc.) may not qualify as a "DSP" in my book.
> What makes a Microprocessor not capable of performing DSP > applications unless emulated by software? >
That us a null statement -- a general purpose DSP chip such as produced by TI, ADI and Freescale cannot perform DSP applications unless specifically instructed by software. The only difference is that the most common DSP operations which are very compute-intensive on a microprocessor are supported by things like the MAC instructions (and the hardware to back it up). The compare/contrast goes like this: To perform a 16x16 MAC into a 32 bit accumulator on an 80186 takes (if my memory serves me correctly) 180 clock cycles per tap, with some setup, or a shade over 11us on a 16MHz part. On an Analog Devices AD2101 it takes 1 (one) clock cycle per tap, with some setup. This is only a difference in degree, but inasmuch as it's two orders of magnitude worth of degree I think we can draw a line between the two processors. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
> What is the most fundamental difference between a DSP (processor) and a > Microprocessor? I could list out a few, but what core features make a > DSP a DSP? What makes a Microprocessor not capable of performing DSP > applications unless emulated by software?
You list the few you can think of and I'll augment the list. I won't start from scratch. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Thanks for the answer.
Would you consider the followings as essential features of a DSP?
1. multiple access memory
2. Hardware looping support
Also, would you consider single-cycle multiplier (say 16x16 MUL in
32-bit architecture) an absolute must in a DSP chip?
> Thanks for the answer. > > Would you consider the followings as essential features of a DSP? > > 1. multiple access memory
Necessary for many single-cycle instructions.
Without it, some loops would take at least twice as long.
> Also, would you consider single-cycle multiplier (say 16x16 MUL in > 32-bit architecture) an absolute must in a DSP chip?
No one feature is so important that without it one can say "this isn't a DSP." In a 32-bit architecture, I would like a 32x32 multiply. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
People have listed a few specific features, which they consider key to a device being a real DSP. By those measures a number of famous DSPs would not have been DSPs. For example, not every DSP has offered a single cycle MAC. If I remember correctly, the first really commercially successful DSP - the TMS32010 - took two cycles. The single cycle measure is quite complex, anyway - answers in one cycle, or a new computation starts each cycle? Pipeline latency can make some very tight processing kernels a pain to implement, even though the device can do an average of one operation per clock. I'd express things like this: - If it sucks at bit banging and logic it isn't a general purpose processor. A lot of (especially earlier) DSPs have really sucked at these jobs, and the code for even the simplest logic surrounding the core DSP activities is a mess. - If it sucks at polynomials it most certainly is no DSP. - If it sucks at vectors it is no serious high performance computing engine. Note that a lot of vector processors have sucked rather badly at DSP, as their latency doing polynomials was bad. Many DSPs now try to balance their polynomial and vector performance, especially the floating point ones. Really, how you achieve high performance isn't that relevant and can be highly algorithm specific. For example, many DSPs have special features (which always seem to be poorly documented) that allow LMS to be greatly speeded up. The particular addressing features for LMS are hardly used anywhere else. If you don't care about latency, does it really matter if you achieve your MAC performance through a single cycle MAC, or thousands of 1 bit processors each taking thousands of cycles per MAC. Some of the neatest early machines for signal processing did just that. See the Goodyear ASPRO for an example. Regards, Steve
I'd say the distinguishing characteristics of a DSP are as follows:
1)  Single-cycle MAC:  Many DSPs today can even do two MACs in a single
cycle.
2)  Repeat single instruction and repeat block of instructions.
3)  Addressing Modes:  Capability to do hardware circular addressing and
other post-increments/decrements in the same cycle as the instruction.
4)  Multiple memory accesses.  Often there are multiple buses available.
It really takes all 4 of the above characteristics to be able to implement a
super-efficient FIR filter (i.e. a few setup cycles and then 1 cycle per
tap)
Brad.
"dspguru_wannabe" <gogichen@gmail.com> wrote in message
news:1104602593.082839.83060@c13g2000cwb.googlegroups.com...
> What is the most fundamental difference between a DSP (processor) and a > Microprocessor? I could list out a few, but what core features make a > DSP a DSP? What makes a Microprocessor not capable of performing DSP > applications unless emulated by software? >
Yes, I consider them to be essential of a DSP. At least I wouldn't
expect a processor without them to be named a "DSP".
JaaC
JaaC
I'm more replying to the OP here, just using Jerry's responses as a
jumping-off point...
On Sat, 01 Jan 2005 22:06:25 -0500, Jerry Avins wrote:
> dspguru_wannabe wrote: > >> Thanks for the answer. >> >> Would you consider the followings as essential features of a DSP? >> >> 1. multiple access memory > > Necessary for many single-cycle instructions.
Although not exclusive to DSPs, in the modern context. Most of the "big time" workstation microprocessors, Pentia, Itanium, Athlons, PPCs, etc, can sustain several memory ops/cycle from on-chip cache.
>> 2. Hardware looping support > > Without it, some loops would take at least twice as long.
The same processors listed above use branch prediction to manage zero-overhead loops without architecting it in the instruction set. Some "DSPs", such as the TI C6000 series manage without hardware "loop" instructions by having enough spare VLIW instruction slots that the work involved in a hardware loop mechanism can be expressed in "ordinary" instructions.
>> Also, would you consider single-cycle multiplier (say 16x16 MUL in >> 32-bit architecture) an absolute must in a DSP chip? > > No one feature is so important that without it one can say "this isn't a > DSP." In a 32-bit architecture, I would like a 32x32 multiply.
I'd say that it comes down to what you're using the chip for. DSPs are optimised for some specific algorithms, typically characterised by "vector" operations of fairly simple sorts: real and complex matrix multiplies of various sorts, and (in some contexts) special help for things like "max()" to help with Viterbi. The dynamic range of the data and the precision of the calculations and (sometimes) the ease of programmability determines issues like word-size and multiplier width, and fixed-vs floating point. The algorithms are well known, alhough there are enough variations in applications and conditions to keep those of us here occupied. The reason that the hardware is typically optimized for the algorithm is not (necessarily) because it's faster that way, but because that allows you to solve the given (real time) problem with less hardware and/or less power. People do DSP on 8-bit micros, when the signals being processed are sufficiently slow or low-precision. People do DSP on workstations and PCs when the signals are off-line, and they aren't concerned about hard real-time constraints or power consumption. What we call a "DSP" hits a sweet spot for "audio" frequency signals, because you can run an algorithm of a few hundred to a few thousand instructions on every sample, and that's useful. What you need for video processing, or software radio typically looks a bit different. FPGAs and other custom circuits are used for some of those things, because the sample rates are such that you can't apply enough conventional-processor instructions to each. Conversely, the amount of matrix multiplication involved in compressed-audio decoding is actually pretty limited: much of the work is bit-bashing, and so you find things like ARM cores getting a lot of that action (in portable devices), even though they don't (or didn't originally) have single-cycle multiplies or multi-word memory access. DSP is typically a verb. The noun "a DSP" is just whatever you need to use to do the DSP that you need to do. Cheers, -- Andrew
