"jaac" <jaime.aranguren@ieee.org> wrote in message news:1104773346.953976.218710@f14g2000cwb.googlegroups.com...> Hi Phil, > > Thanks for the reply. > > You are right. I would get aliasing. Thank you for pointing this out. > > To be honest the 200Hz Fs comes from originally having the carrier at > 50 Hz in the IEC document, but this won't be my case. If I stay without > the sample rate conversion, and sampling directly at low frequency, I'd > better change it to 240Hz, and I'll have to redesign my filters (I'm > lazy to do that). > > More interesting, I'll go for the decimation after squaring at 8kHz. > So, my bandpass filter, from 0.05Hz to 35Hz @ 200Hz will effectively > reject the aliased signals, I won't modify the original signal's shape > (important because my information is there), and more important, I'll > only need one ADC per channel, instead of two (one sampling at 8kHz for > spectral analysis, the other one sampling at 200Hz for waveshape > fluctuation analysis). > > Thank you very much! > > JaaC >Glad to have been of help. Won't you have to re-design your filter (0.05Hz to 35Hz @ 200 Hz) to work at 8KHz? If you just feed the 8KHz samples in, I suspect it will filter from 0.4Hz to 280Hz Best wishes, --Phil
Sample rate conversion doubt
Started by ●January 2, 2005
Reply by ●January 3, 20052005-01-03
Reply by ●January 6, 20052005-01-06
Philip Martel wrote:> Glad to have been of help. Won't you have to re-design your filter(0.05Hz> to 35Hz @ 200 Hz) to work at 8KHz? If you just feed the 8KHz samplesin, I> suspect it will filter from 0.4Hz to 280Hz > > Best wishes, > --PhilHi Phil, No. The signal flow would be like this: Samples @ 8kHz -> Squaring (AM demodulation) @ 8kHz -> Decimation by 40 (New Fs: 200 Hz) -> Bandpass filtering (0.05Hz - 35 Hz) @ 200Hz -> Other processing @ 200 Hz. What's wrong here? Regards, JaaC
