Hello I need help, in DFT, the frequency domain�s independent variable can be refereed to in many ways, one way is being a fraction of the sampling rate. could some one please explain why X[ ] independent variable runs between 0 and 0.5, if you say because discrete data can only contain frequencies between DC and � the sampling rate, then if the sampling rate (x[ ] has) 128 points then 128 * � is 64 then why X [ ] has 65 samples? I must be missing something. Thanks
DFT X[ ] independent variable
Started by ●January 3, 2005
Reply by ●January 3, 20052005-01-03
"Tim Wescott" <tim@wescottnospamdesign.com> wrote in message news:10tjikljh67jh9d@corp.supernews.com...> Vec wrote: > >> Hello >> >> I need help, in DFT, the frequency domain�s independent variable can be >> refereed to in many ways, one way is being a fraction of the sampling >> rate. >> could some one please explain why X[ ] independent variable runs between >> 0 and 0.5, if you say because discrete data can only contain frequencies >> between DC and � the sampling rate, then if the sampling rate (x[ ] has) >> 128 points then 128 * � is 64 then why X [ ] has 65 samples? >> I must be missing something. >> >> Thanks >> > The discrete data can only contain frequencies between DC and 1/2 the > sampling rate _inclusive_, and points 0 through 64 is a set with 65 > members. > > Note: Your rule only applies when you are sampling real data. If you are > sampling complex data (or I & Q data) then you need all 128 points. > > -- > > Tim Wescott > Wescott Design Services > http://www.wescottdesign.comWith no disagreement, said a slightly different way: A DFT means the temporal data is sampled and the spectrum repeats at periods of fs. -fs/2 to fs/2 covers one period of the spectrum. If the temporal data is real, then the spectral data is even. Accordingly, the spectral data from zero to fs/2 is a mirror image of the data from zero to -fs/2, and the data from fs/2 to fs is the same as the data from -fs/2 to zero. So, all of the information in the spectral data is present from zero to fs/2. If we normalize the sequences so that the time sampling interval is assumed to be 1 second, then fs=1Hz and fs/2 is 0.5Hz. This is handy because often we are dealing with regularly spaced "temporal" samples or maybe just regularly spaced unlabeled samples - in which case using a sample interval of "1.0" is convenient. Then the spectrum from 0 to 0.5 is all we need. Fred
"Vec" <vec2u@valoudari.edu.mx> wrote in message news:41d9b8ed$1_1@news.iprimus.com.au...> [...] (x[ ] has) 128 points then 128 * � is 64 then why X [ ] has 65 > samples? > I must be missing something.I assume you're using real (i.e., not complex) input data. In the DFT output, the frequency samples are complex numbers, i.e., each contains two real numbers, except for the DC and fs/2 which can have only one non-zero real component each. The total count of real numbers in X[] is then 1 + 63*2 + 1 = 128, as you would expect. -- Matt
"Vec" <vec2u@valoudari.edu.mx> wrote in message news:41d9b8ed$1_1@news.iprimus.com.au...> Hello > > I need help, in DFT, the frequency domain�s independent variable can be > refereed to in many ways, one way is being a fraction of the sampling > rate. > could some one please explain why X[ ] independent variable runs between 0 > and 0.5, if you say because discrete data can only contain frequencies > between DC and � the sampling rate, then if the sampling rate (x[ ] has) > 128 points then 128 * � is 64 then why X [ ] has 65 samples? > I must be missing something. > > Thanks >And I might have added: While fs/2 is the mirroring point in frequency, it need not have a sample located there. If the number of time samples is even, e.g. 64, then so is the number of frequency samples out of a DFT. If the number of frequency samples is 64, the frequency sampling interval is fs/64. 64 samples covers the spectral range zero to fs-fs/64 and F(0)=F(fs) so F(fs) need not be included because it would be redundant. Note that the range 0 to fs is split into 64 intervals that are spanned by 65 samples if fs is included. If it is in 64 intervals then fs/2 is in exactly 32 intervals which is spanned by 33 samples if fs/2 is included. The remaining 31 samples run from fs/2+fs/64 to fs-fs/64. SO: If the number of samples is even, as is often the case for a DFT, then there is a sample located at fs/2. If the number of time samples is odd, e.g. 65, then so is the number of frequency samples out of a DFT. If the number of frequency samples is 65, the frequency sampling interfval is fs/65. 65 samples covers the spectral range zero to fs-fs/65 and F(0)-F(fs) as above. Note that the range 0 to fs is split into 65 intervals that are spanned by 66 samples if fs is included. If it is in 65 intervals, then fs/2 lies in the middle of the 33rd interval and is not spanned by an integral number of samples. SO: If the number of samples is odd, then there is not a sample located at fs/2 and the nearest sample to fs/2 is at fs/2-fs/2N. The spectrum of a real temporal sequence still mirrors at fs/2. Fred
Reply by ●January 5, 20052005-01-05
On Tue, 04 Jan 2005 08:20:11 -0800, Vec <vec2u@valoudari.edu.mx> wrote:>Hello > >I need help, in DFT, the frequency domain�s independent variable can be >refereed to in many ways, one way is being a fraction of the sampling rate. >could some one please explain why X[ ] independent variable runs between >0 and 0.5, if you say because discrete data can only contain frequencies >between DC and � the sampling rate, then if the sampling rate (x[ ] has) >128 points then 128 * � is 64 then why X [ ] has 65 samples? >I must be missing something.If you look at the DFT it runs around in a circle so the values repeat after going from 0 to pi. The sample point are points on the circle. Regards, Steve Drake
