Hi I have written Matlab script for BPSK modulation. The way my code works is as follow: series of 0 and 1----> NRZ data (continuous rectangular pulses with amplitude -1 and 1)--->multiply by carrier----> add noise--> multiply by carrier---> integration--->detection---> Bit Error collection? I would like to know can anyone tell me where I should apply DAC and ADC ? I am wondering should it be after NRZ data or before that for DAC ? --------------------------------------- Posted through http://www.DSPRelated.com
ADC and DAC for modulation and demodulation
Started by ●July 11, 2015
Reply by ●July 11, 20152015-07-11
On Fri, 10 Jul 2015 22:19:20 -0500, chess wrote:> Hi I have written Matlab script for BPSK modulation. The way my code > works is as follow: > > series of 0 and 1----> NRZ data (continuous rectangular pulses with > amplitude -1 and 1)--->multiply by carrier----> add noise--> multiply by > carrier---> integration--->detection---> Bit Error collection? > > I would like to know can anyone tell me where I should apply DAC and ADC > ? > I am wondering should it be after NRZ data or before that for DAC ?Perhaps the best place would be in the same spot as in the system that you're trying to simulate. -- www.wescottdesign.com
>On Fri, 10 Jul 2015 22:19:20 -0500, chess wrote: > >> Hi I have written Matlab script for BPSK modulation. The way my code >> works is as follow: >> >> series of 0 and 1----> NRZ data (continuous rectangular pulses with >> amplitude -1 and 1)--->multiply by carrier----> add noise--> multiplyby>> carrier---> integration--->detection---> Bit Error collection? >> >> I would like to know can anyone tell me where I should apply DAC andADC>> ? >> I am wondering should it be after NRZ data or before that for DAC ? > >Perhaps the best place would be in the same spot as in the system that >you're trying to simulate. > >-- >www.wescottdesign.comI have already written the code for modulation and demodulation but this time I would like to use ADC and DAC to produce the digital and analog signal but I wonder where to place them exactly ? do they come after the multiplication by carrier? --------------------------------------- Posted through http://www.DSPRelated.com
On Sat, 11 Jul 2015 01:53:25 -0500, chess wrote:>>On Fri, 10 Jul 2015 22:19:20 -0500, chess wrote: >> >>> Hi I have written Matlab script for BPSK modulation. The way my code >>> works is as follow: >>> >>> series of 0 and 1----> NRZ data (continuous rectangular pulses with >>> amplitude -1 and 1)--->multiply by carrier----> add noise--> multiply > by >>> carrier---> integration--->detection---> Bit Error collection? >>> >>> I would like to know can anyone tell me where I should apply DAC and > ADC >>> ? >>> I am wondering should it be after NRZ data or before that for DAC ? >> >>Perhaps the best place would be in the same spot as in the system that >>you're trying to simulate. >> >>-- >>www.wescottdesign.com > I have already written the code for modulation and demodulation but this > time I would like to use ADC and DAC to produce the digital and analog > signal but I wonder where to place them exactly ? do they come after the > multiplication by carrier?The reason I am being tart with you is because you seem to be living the fallacy that "to know Matlab is to know DSP". Instead of asking where you should put a PRETEND device into a PRETEND simulation inside of a simulation environment, why don't you ask where you might put REAL devices in a REAL system that has to work in the REAL world and may even have to compete with other REAL devices in the REAL marketplace? The place you put ADCs and DACs, exactly, in a REAL system, is nearly anywhere in the signal processing chain -- including off the table, because lots of radios can be built without DSP. You can build a system that goes antenna -> ADC -> signal processing -> DAC -> speaker You can build a system that goes antenna -> signal processing -> ADC -> signal processing -> DAC -> signal processing -> speaker You can build a system that goes antenna -> signal processing -> speaker or any variation in between (you could even dive into and out of discrete time more than once, although when that's done it's usually an artifact of purchased modules or an old product and a convoluted upgrade program). Where it is advantageous to transition from continuous-time to sampled- time depends on a huge number of factors pertaining to the real world. Absolutely none of them have anything to do with Matlab. I suggest you try again, with either your question or your project. Tell us what you're trying to build (NOT some Matlab program: what real thing are you building, or what real thing are you designing, even if it won't ever get built). Be specific to the point where we know what sort of data rates and carrier frequencies are involved, and what forms of modulation. State what sort of a quality/cost compromise you have in mind. Maybe even say what sort of production volume you're anticipating (it matters). Then don't ask for the one spot where the ADC should go, and the one spot where the DAC should go. Rather, because the answer isn't absolute, ask people where they would put the sampling and the reconstruction, and why. -- www.wescottdesign.com
Reply by ●July 12, 20152015-07-12
On 2015-07-11 5:19, chess wrote:> Hi > I have written Matlab script for BPSK modulation. The way my code works > is > as follow: > > series of 0 and 1----> NRZ data (continuous rectangular pulses with > amplitude -1 and 1)--->multiply by carrier----> add noise--> multiply by > carrier---> integration--->detection---> Bit Error collection? > > I would like to know can anyone tell me where I should apply DAC and ADC > ? > I am wondering should it be after NRZ data or before that for DAC ?As Tim said it really depends on the actual system. In a typical "state of the art" comm-radio it is usually before the carrier multiplication, i.e. you prepare the baseband signal in digital domain, DAC and mix it with the RF in analog domain. However, newer systems can also use RFDACs and do even carrier modulation in digital. Also you may want to apply pulse shaping as well. -Peter
