Hi, Im interested in learning how to generate sounds (e.g. music synthesizer) on the PC with software, talking to a sound card. Can anyone suggest some tutorials to get started? Thanks, Redd
Sound generation on the PC
Started by ●January 16, 2005
Reply by ●January 16, 20052005-01-16
XIAOBIN HAOO wrote:> Hi, > Im interested in learning how to generate sounds (e.g. music > synthesizer) on the PC with software, talking to a sound card. Can anyone > suggest some tutorials to get started? > > Thanks, > Redd > >Much depends on which bits are familiar to you (C programming? dsp?) and which bits are not! go to: http://www.musicdsp.org there is a mailing list, a source code archive, wiki tutorials, links to all sorts of things. Note there are also mailing lists devoted to the principal audio plugin protocols (VST, CoreAudio), and to key open-source software such as Csound, STK, PD, etc. Also check out portaudio.com for a cross-platform library for record/playback. Richard Dobson
Hi Richard, Thanks. Yes, rasonable expert in "C", "C++", just getting into DSP (took an engineering course ages ago, covered FFT, etc, mostly the math). Thanks for the post. Ill lookup the sites now. Regards, Redd. "Richard Dobson" <richarddobson@blueyonder.co.uk> wrote in message news:vUCGd.11918$GG1.10078@text.news.blueyonder.co.uk...> XIAOBIN HAOO wrote: > >> Hi, >> Im interested in learning how to generate sounds (e.g. music >> synthesizer) on the PC with software, talking to a sound card. Can >> anyone suggest some tutorials to get started? >> >> Thanks, >> Redd > > Much depends on which bits are familiar to you (C programming? dsp?) and > which bits are not! > > go to: > > http://www.musicdsp.org > > there is a mailing list, a source code archive, wiki tutorials, links to > all sorts of things. Note there are also mailing lists devoted to the > principal audio plugin protocols (VST, CoreAudio), and to key open-source > software such as Csound, STK, PD, etc. Also check out portaudio.com for a > cross-platform library for record/playback. > > > Richard Dobson
You might just take a look at http://www.ScienceOxygen.com/signal.html http://www.ScienceOxygen.com/gadget.html It is just with a collection of links that you might start from there.
Reply by ●January 17, 20052005-01-17
XIAOBIN HAOO wrote:> Hi, > Im interested in learning how to generate sounds (e.g. music > synthesizer) on the PC with software, talking to a sound card. Cananyone> suggest some tutorials to get started? > > Thanks, > ReddHave a look at Csound. Regards, Andor
Reply by ●January 18, 20052005-01-18
Hi Andor, Thanks for the reply, and link Regards, Redd "Andor" <an2or@mailcircuit.com> wrote in message news:1105952193.052187.240950@c13g2000cwb.googlegroups.com...> > XIAOBIN HAOO wrote: >> Hi, >> Im interested in learning how to generate sounds (e.g. music >> synthesizer) on the PC with software, talking to a sound card. Can > anyone >> suggest some tutorials to get started? >> >> Thanks, >> Redd > > > Have a look at Csound. > > Regards, > Andor >
