Erik,> Sorry, thats just plain bad advice.I'd figured that out already, by reading the other advices :)> "The day Microsoft makes something that doesn't suck is probably the > day they start making vacuum cleaners." -- Ernst Jan PluggeNice ;-)
Oversampling 8KHz to 44.1KHz
Started by ●October 29, 2004
Reply by ●November 3, 20042004-11-03
Rob Vermeulen wrote:> Erik, > >>Sorry, thats just plain bad advice. > > I'd figured that out already, by reading the other advices :)If you're strapped for processing resources, and if you are processing off-line data (that is, the sample rate converter is not between an A/D and a D/A - for example, you could be streaming A/D to disk), then you might consider converting 8KHz to 44.0KHz instead of to 44.1K. This will shift the frequencies down, but for the typical 8K-sampled signal (voice), the shift will not likely be noticed. I dunno how it might affect modulated signals (i.e., fax/modems) but even that might be able to tolerate the frequency shift. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 People think it must be fun to be a super genius, but they don't realize how hard it is to put up with all the idiots in the world - Calvin
On 2004-11-03 14:39:31 +0100, Jim Thomas <jthomas@bittware.com> said:> ...then you might consider converting 8KHz to 44.0KHz instead of to > 44.1K. This will shift the frequencies down,Just some nit picking: it will actually *scale* the frequencies. It will shift the pitch... -- Stephan M. Bernsee http://www.dspdimension.com
ggabe wrote:> There's a 8KHz audio sample rate I want to convert up to 44.1KHz > sample rate. What's the right approach to keep Mr. Nyquist happy?No one's mentioned Secret Rabbit Code for sample rate conversion. I haven't tried it, but from the web site it looks like good stuff. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
If the data sample isn't too long, you might try "Perfect Interpolation". In article <10ohv6pln7psi4a@corp.supernews.com>, Tim Wescott <tim@wescottnospamdesign.com> wrote:>ggabe wrote: > >> There's a 8KHz audio sample rate I want to convert up to 44.1KHz >> sample rate. What's the right approach to keep Mr. Nyquist happy? > >No one's mentioned Secret Rabbit Code for sample rate conversion. I >haven't tried it, but from the web site it looks like good stuff. >
Stephan M. Bernsee wrote:> On 2004-11-03 14:39:31 +0100, Jim Thomas <jthomas@bittware.com> said: > >> ...then you might consider converting 8KHz to 44.0KHz instead of to >> 44.1K. This will shift the frequencies down, > > > Just some nit picking: it will actually *scale* the frequencies. It will > shift the pitch...Yes. I think the only advantage this offers though is that it requires less memory for the the filter coefficients. Using the standard multirate filtering tricks (don't multiply by zero, and don't calculate samples that will be discarded), the processing time should be about the same. These days, reduced memory is not much of an advantage. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 People think it must be fun to be a super genius, but they don't realize how hard it is to put up with all the idiots in the world - Calvin
Tim Wescott wrote:> > ggabe wrote: > > > There's a 8KHz audio sample rate I want to convert up to 44.1KHz > > sample rate. What's the right approach to keep Mr. Nyquist happy? > > No one's mentioned Secret Rabbit Code for sample rate conversion. I > haven't tried it, but from the web site it looks like good stuff.Actually, I pretty sure I mentioned it (see my email address below) :-). Erik -- +-----------------------------------------------------------+ Erik de Castro Lopo nospam@mega-nerd.com (Yes it's valid) +-----------------------------------------------------------+ "Always code as if the person who ends up maintaining your code will be a violent psychopath who knows where you live." -- Martin Golding
