Just what is a "1 bit complex sample"? "The sampler is driven by orbit-prediction software that triggers a synchronized acquisition on both 1575.42 MHz and 1278.75 MHz using 1-bit complex samples at 60 megasamples per second (about 60 MHz total bandwidth)." http://gpsworld.com/first-signals-of-beidou-phase-3-acquired-at-ispra-italy/ 2nd paragraph
"... 1-bit complex samples at 60 megasamples per second ..." ???
Started by ●August 11, 2015
Reply by ●August 11, 20152015-08-11
>Just what is a "1 bit complex sample"?My guess is two single bit ADCs --------------------------------------- Posted through http://www.DSPRelated.com
On Tue, 11 Aug 2015 15:34:23 -0500, Richard Owlett wrote:> Just what is a "1 bit complex sample"? > > "The sampler is driven by orbit-prediction software that triggers a > synchronized acquisition on both 1575.42 MHz and 1278.75 MHz using 1-bit > complex samples at 60 megasamples per second (about 60 MHz total > bandwidth)." > > http://gpsworld.com/first-signals-of-beidou-phase-3-acquired-at-ispra-italy/> 2nd paragraphThis is all assuming, but: They've got to be using two 1-bit ADCs, and they've got to be doing I/Q sampling. Whether they're downconverting to baseband and then doing the 1-bit thang, or downconverting to some IF and directing every other 1-bit conversion to a decimator -- I dunno. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
On 8/11/2015 4:50 PM, Tim Wescott wrote:> On Tue, 11 Aug 2015 15:34:23 -0500, Richard Owlett wrote: > >> Just what is a "1 bit complex sample"? >> >> "The sampler is driven by orbit-prediction software that triggers a >> synchronized acquisition on both 1575.42 MHz and 1278.75 MHz using 1-bit >> complex samples at 60 megasamples per second (about 60 MHz total >> bandwidth)." >> >> http://gpsworld.com/first-signals-of-beidou-phase-3-acquired-at-ispra- > italy/ >> 2nd paragraph > > This is all assuming, but: > > They've got to be using two 1-bit ADCs, and they've got to be doing I/Q > sampling. Whether they're downconverting to baseband and then doing the > 1-bit thang, or downconverting to some IF and directing every other 1-bit > conversion to a decimator -- I dunno.When you talk about I/Q sampling, should I assume that implies mixing with a pair of reference sine waves 90 degrees out of phase before the ADC sampling? Is there an advantage to doing this before sampling rather than after? It has been a few days to my DSP activity, but I want to say every system I've worked with had one ADC and generated the I/Q streams digitally. Or is that what you are referring to by "directing every other 1-bit conversion to a decimator"? The method I've seen uses every other sample as I and the remaining samples as Q with every other one in each stream negated yielding a multiplication by a stream that is ...1, 0, -1, 0,... -- Rick
On Tue, 11 Aug 2015 17:25:14 -0400, rickman wrote:> On 8/11/2015 4:50 PM, Tim Wescott wrote: >> On Tue, 11 Aug 2015 15:34:23 -0500, Richard Owlett wrote: >> >>> Just what is a "1 bit complex sample"? >>> >>> "The sampler is driven by orbit-prediction software that triggers a >>> synchronized acquisition on both 1575.42 MHz and 1278.75 MHz using >>> 1-bit complex samples at 60 megasamples per second (about 60 MHz total >>> bandwidth)." >>> >>> http://gpsworld.com/first-signals-of-beidou-phase-3-acquired-at-ispra- >> italy/ >>> 2nd paragraph >> >> This is all assuming, but: >> >> They've got to be using two 1-bit ADCs, and they've got to be doing I/Q >> sampling. Whether they're downconverting to baseband and then doing >> the 1-bit thang, or downconverting to some IF and directing every other >> 1-bit conversion to a decimator -- I dunno. > > When you talk about I/Q sampling, should I assume that implies mixing > with a pair of reference sine waves 90 degrees out of phase before the > ADC sampling? Is there an advantage to doing this before sampling > rather than after?Yes. If there's an advantage it's just the reduced sampling rate. But the disadvantages engendered by mismatch between your two ADCs may be severe.> It has been a few days to my DSP activity, but I want to say every > system I've worked with had one ADC and generated the I/Q streams > digitally. Or is that what you are referring to by "directing every > other 1-bit conversion to a decimator"? The method I've seen uses every > other sample as I and the remaining samples as Q with every other one in > each stream negated yielding a multiplication by a stream that is ...1, > 0, -1, 0,...That's what I'm talking about: one ADC, then multiply it by two streams: [ 1 0 -1 0 1 0 -1 ...] [ 0 1 0 -1 0 1 0 ...] Keep in mind that at this point we're hypothesizing WAY ahead of our data! -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Richard Owlett <rowlett@cloud85.net> writes:> Just what is a "1 bit complex sample"? > > "The sampler is driven by orbit-prediction software that triggers a > synchronized acquisition on both 1575.42 MHz and 1278.75 MHz using > 1-bit complex samples at 60 megasamples per second (about 60 MHz total > bandwidth)." > > http://gpsworld.com/first-signals-of-beidou-phase-3-acquired-at-ispra-italy/ > 2nd paragraphRichard, I think someone's already answered (Tim?), but complex means from the complex numbers, so of the form a + i*b, where a and b are from a 1-bit ADC. So it's really two bits total. Also note that in complex sampling, Nyquist changes: it's the full Fs (sample rate) and not Fs/2. Actually, it always was Fs, but in a real signal half of the bandwidth is redundant and therefore wasted. -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
On Tue, 11 Aug 2015 19:25:03 -0400, Randy Yates wrote:> Richard Owlett <rowlett@cloud85.net> writes: > >> Just what is a "1 bit complex sample"? >> >> "The sampler is driven by orbit-prediction software that triggers a >> synchronized acquisition on both 1575.42 MHz and 1278.75 MHz using >> 1-bit complex samples at 60 megasamples per second (about 60 MHz total >> bandwidth)." >> >> http://gpsworld.com/first-signals-of-beidou-phase-3-acquired-at-ispra-italy/>> 2nd paragraph > > Richard, > > I think someone's already answered (Tim?), but complex means from the > complex numbers, so of the form a + i*b, where a and b are from a 1-bit > ADC. So it's really two bits total. > > Also note that in complex sampling, Nyquist changes: it's the full Fs > (sample rate) and not Fs/2. Actually, it always was Fs, but in a real > signal half of the bandwidth is redundant and therefore wasted.Or it's the way you parse what Harry Nyquist said. The Nyquist sampling theorem says you need to collect independent samples at twice the bandwidth. It doesn't say you have to collect evenly spaced samples of the same thing. Collecting I and Q at the bandwidth is still collecting twice the bandwidth. -- www.wescottdesign.com
Richard Owlett wrote:> Just what is a "1 bit complex sample"? > > "The sampler is driven by orbit-prediction software that triggers a > synchronized acquisition on both 1575.42 MHz and 1278.75 MHz using 1-bit > complex samples at 60 megasamples per second (about 60 MHz total > bandwidth)." > > http://gpsworld.com/first-signals-of-beidou-phase-3-acquired-at-ispra-italy/ > > 2nd paragraph >They're probably sampling I and Q seperately. -- Les Cargill
Reply by ●August 12, 20152015-08-12
Tim Wescott <tim@seemywebsite.com> writes:> On Tue, 11 Aug 2015 19:25:03 -0400, Randy Yates wrote: > >> Richard Owlett <rowlett@cloud85.net> writes: >> >>> Just what is a "1 bit complex sample"? >>> >>> "The sampler is driven by orbit-prediction software that triggers a >>> synchronized acquisition on both 1575.42 MHz and 1278.75 MHz using >>> 1-bit complex samples at 60 megasamples per second (about 60 MHz total >>> bandwidth)." >>> >>> http://gpsworld.com/first-signals-of-beidou-phase-3-acquired-at-ispra- > italy/ >>> 2nd paragraph >> >> Richard, >> >> I think someone's already answered (Tim?), but complex means from the >> complex numbers, so of the form a + i*b, where a and b are from a 1-bit >> ADC. So it's really two bits total. >> >> Also note that in complex sampling, Nyquist changes: it's the full Fs >> (sample rate) and not Fs/2. Actually, it always was Fs, but in a real >> signal half of the bandwidth is redundant and therefore wasted. > > Or it's the way you parse what Harry Nyquist said. The Nyquist sampling > theorem says you need to collect independent samples at twice the > bandwidth. It doesn't say you have to collect evenly spaced samples of > the same thing. Collecting I and Q at the bandwidth is still collecting > twice the bandwidth.I was just going to agree that it depends on perspective, but I just realized it doesn't. Consider sampling I and Q but where Q is zero. In other words, you're sampling a real signal with a complex ADC. You still have twice as many samples, but suddenly your (usable) bandwidth is half. So it's not the samples, it's something more inherent in the source information. Resist the temptation to blow this off and say, "Well, setting the samples to zero is like not sampling." The point is, you are sampling those imaginary samples, but there's no information there. It's the source information that is lacking, not the samples. Or maybe I'm just getting sleepy... -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
On Tue, 11 Aug 2015 23:35:28 -0400, Randy Yates <yates@digitalsignallabs.com> wrote:>Tim Wescott <tim@seemywebsite.com> writes: > >> On Tue, 11 Aug 2015 19:25:03 -0400, Randy Yates wrote: >> >>> Richard Owlett <rowlett@cloud85.net> writes: >>> >>>> Just what is a "1 bit complex sample"? >>>> >>>> "The sampler is driven by orbit-prediction software that triggers a >>>> synchronized acquisition on both 1575.42 MHz and 1278.75 MHz using >>>> 1-bit complex samples at 60 megasamples per second (about 60 MHz total >>>> bandwidth)." >>>> >>>> http://gpsworld.com/first-signals-of-beidou-phase-3-acquired-at-ispra- >> italy/ >>>> 2nd paragraph >>> >>> Richard, >>> >>> I think someone's already answered (Tim?), but complex means from the >>> complex numbers, so of the form a + i*b, where a and b are from a 1-bit >>> ADC. So it's really two bits total. >>> >>> Also note that in complex sampling, Nyquist changes: it's the full Fs >>> (sample rate) and not Fs/2. Actually, it always was Fs, but in a real >>> signal half of the bandwidth is redundant and therefore wasted. >> >> Or it's the way you parse what Harry Nyquist said. The Nyquist sampling >> theorem says you need to collect independent samples at twice the >> bandwidth. It doesn't say you have to collect evenly spaced samples of >> the same thing. Collecting I and Q at the bandwidth is still collecting >> twice the bandwidth. > >I was just going to agree that it depends on perspective, but I just >realized it doesn't. > >Consider sampling I and Q but where Q is zero. In other words, you're >sampling a real signal with a complex ADC. You still have twice as many >samples, but suddenly your (usable) bandwidth is half. > >So it's not the samples, it's something more inherent in the source >information. > >Resist the temptation to blow this off and say, "Well, setting the >samples to zero is like not sampling." The point is, you are sampling >those imaginary samples, but there's no information there. It's the >source information that is lacking, not the samples. > >Or maybe I'm just getting sleepy... >-- >Randy Yates >Digital Signal Labs >http://www.digitalsignallabs.comRandy, what they're describing is a common technique where a digital mixing oscillator mixes the sampled bandwidth to baseband. The effect is that fs/4 gets mixed to 0, so the complex mixing phasor has four samples per cycle. The phases of the sampling instants are often chosen to be on the coordinate axes, so that they come out just like Tim described earlier:>That's what I'm talking about: one ADC, then multiply it by two streams:>[ 1 0 -1 0 1 0 -1 ...] >[ 0 1 0 -1 0 1 0 ...]Those two vectors are just the I and Q mixing coefficients, in other words, the mixer samples are just: 1+j0, 0+j1, -1+j0, 0-j1...repeating ad nuaseum... That's just four samples around the unit circle, which mixes fs/4 to 0. One consequence of that method is that the information samples don't line up nicely, so some decimation or other filtering needs to be done to get things smoothed out. The decimation process is aided by this since you know that every other sample in I and Q is zero, so those calculations can be skipped with no consequence as long as the two filters are done properly. Easy decimation by 2:1 and filtering can be done this way pretty efficiently. If you don't want to decimate by two for whatever reason, or want to do it a different way, you can also make things simple by rotating the mixing coefficients 45 degrees: 1+j1, -1+j1, -1-j1, 1-j1, ....forever and ever... The result is the same, except now you have to process all the samples, but you also get some good signal magnitude gain because the vectors are no longer on the unit circle, but have magnitude sqrt(2). This can be very useful in some circumstances. Note that all of the information is preserved in either case. There is no loss of information or gain in information in either case. So those zeros in the first case don't really hurt you at all, and they can help reduce the computational load signifcantly. I've built many systems both ways, just depending on what was needed in each case. Naturally there are many variations on the theme, limited only by ones imagination (or schedule). I just wanted to point out that there's really nothing bad about the zeros. The real-valued input stream can be identical in each case, and you can get the same results in either case just with different methodology and tradeoffs. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
