hello everybody, I search in google a lot but I can not find code of using gibbs sampling in audio (signal or sound) processing. if you can please help me. thanks in advance
simple code for audio (or signal or sound ) sampling using gibbs sampling
Started by ●August 21, 2015
Reply by ●August 21, 20152015-08-21
On Friday, August 21, 2015 at 12:48:23 AM UTC-4, Zahra T wrote:> hello everybody, I search in google a lot but I can not find code of using gibbs sampling in audio (signal or sound) processing. if you can please help me. > thanks in advanceA quick look on Google on Gibbs sampling (which I had never heard of) sounds like it applies to sampling probability distribution (& probably other statistical applications). What application did you intend to use this for in audio processing? Can you provide a link on your application? Thanks, Dirk
Reply by ●August 25, 20152015-08-25
>hello everybody, I search in google a lot but I can not find code ofusing>gibbs sampling in audio (signal or sound) processing. if you can pleasehelp>me. >thanks in advancehttps://victorfang.wordpress.com/2014/04/29/mcmc-the-gibbs-sampler-simple-example-w-matlab-code/ --------------------------------------- Posted through http://www.DSPRelated.com
