[Also posted to music-dsp mailing list] Hi, I'm playing around with my bi-amping audio system [1] and an idea popped into my head: instead of feeding the same signal to both HF and LF drivers and relying on the crossovers built into the speakers, why not have a crossover in the digital domain and use two DACs each feeding a separate amplifier? [1] Squeezebox -> Art DI/O DAC -> Rotel RA820A (modified)(HF) + Rotel RB850 (LF) I had a quick google around and found several devices that have analogue inputs and analogue outputs, but I couldn't find anything that simply takes a digital input signal and filters it digitally, producing a LF and HF digital output. Does anyone know of such a device? How easy would this sort of thing be to build? Thanks, R. -- http://robinbowes.com
Crossover in digital domain?
Started by ●January 18, 2005
Reply by ●January 18, 20052005-01-18
Robin Bowes wrote: (snip)> I had a quick google around and found several devices that have analogue > inputs and analogue outputs, but I couldn't find anything that simply > takes a digital input signal and filters it digitally, producing a LF > and HF digital output.Motorola has an application note for the 56001 for a graphic equalizer. I don't remember if the I/O was analog with appropriate A/D and D/A converters or digital. It seems that the 56001 is fast enough for a stereo equalizer with a reasonably number of bands, so should easily be enough for a crossover. -- glen
Robin Bowes <robin-news@robinbowes.com> wrote in news:JygHd.11$Jo6.0 @newsfe2-gui.ntli.net:> [Also posted to music-dsp mailing list] > > Hi, > > I'm playing around with my bi-amping audio system [1] and an ideapopped> into my head: instead of feeding the same signal to both HF and LF > drivers and relying on the crossovers built into the speakers, why not > have a crossover in the digital domain and use two DACs each feeding a > separate amplifier? > > [1] Squeezebox -> Art DI/O DAC -> Rotel RA820A (modified)(HF) + Rotel > RB850 (LF) > > I had a quick google around and found several devices that haveanalogue> inputs and analogue outputs, but I couldn't find anything that simply > takes a digital input signal and filters it digitally, producing a LF > and HF digital output. > > Does anyone know of such a device? How easy would this sort of thing be > to build? > > Thanks, > > R.You can do this with our dspstak family of boards. We have an S/PDIF board as well as analog ADCs & DACs. We are working with the Visual Audio group at Analog Devices that will allow you to create these kind of systems graphicalkly as well. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
It is pretty common to use digital crossovers in the installed sound market (think stadiums, sports arenas, etc.) and even in high-end home audio. The filtering requirements are quite simple, but finding something with the right form-factor and price may be a challenge. For a commercial product, check this out: http://www.bss.co.uk/includes/product_list_include.aspx?header_id=6&archived_flag=0 but it may not be geared exactly to your market. A DSP evaluation board with digital audio I/O may be the best bet if you like to program. Or you may be able to find PC software that allows real-time filtering. "Robin Bowes" <robin-news@robinbowes.com> wrote in message news:JygHd.11$Jo6.0@newsfe2-gui.ntli.net...> [Also posted to music-dsp mailing list] > > Hi, > > I'm playing around with my bi-amping audio system [1] and an idea popped into > my head: instead of feeding the same signal to both HF and LF drivers and > relying on the crossovers built into the speakers, why not have a crossover in > the digital domain and use two DACs each feeding a separate amplifier? > > [1] Squeezebox -> Art DI/O DAC -> Rotel RA820A (modified)(HF) + Rotel RB850 > (LF) > > I had a quick google around and found several devices that have analogue > inputs and analogue outputs, but I couldn't find anything that simply takes a > digital input signal and filters it digitally, producing a LF and HF digital > output. > > Does anyone know of such a device? How easy would this sort of thing be to > build? > > Thanks, > > R. > -- > http://robinbowes.com
Reply by ●January 19, 20052005-01-19
