Newbie question
Started by mkruisselbrink ●January 24, 2005
Jerry Avins wrote:
> Jim Thomas wrote: > >>Jerry Avins wrote: >> >> >>>Ethernet was originally a broadcast -- as in FM radio -- protocol >>>developed to link sites of the University of Hawaii. >> >> >>I think they called that the Aloha protocol. The transmitter didn't >>check the medium before transmitting, but waited for an ack. If it >>didn't get one, it would retransmit. >> >>The only reason I remember any of this is because my in-laws operate on >>a modified-Aloha protocol in their everyday conversation. The >>modification is that if they don't receive an ack, they retransmit with >>MORE POWER. >> >>I remember the first Christmas Eve I spent with them. One of my wife's >>uncles was talking to me when his brother just butted in. Not knowing >>how to respond, I ignored him. That's when he retransmitted. Louder. I >>ignored him again and soon learned until he got that ack, he was going >>to keep retransmitting at ever greater power levels. Apparently, his >>loop termination condition did not include a maximum-retries term. >>Meanwhile, the first uncle upped his power too. In an attempt to >>prevent the volume from overpowering my receiver, I was forced into TDM >>mode. Unfortunately, their protocol did not include an allowance for >>backing off the power levels. >> >>Those uncles never once called one another out with a "I was talking >>first," nor did they seem to think it was odd. It was their protocol. >>That's how it progressed the WHOLE EVENING, with upwards of a dozen >>transmitters (and I was not the only receiver either). > > > An essential part of the protocol is the transmitter- and retry-count > dependent waiting time before retransmitting after a collision. With > that, collision is the second attempt is less likely, and "frustration" > incrementally increases one's priority. > > Jerry
Oy! An essential part of the protocol is the transmitter-dependent waiting time before retransmitting after a collision. With that, collision on the second attempt is less likely. A refinement is retry-dependent delay that allows "frustration" to incrementally increases one's priority. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:
(someone wrote)
>>Well, I would have said that an ethernet network design should be no greater >>than X/20 or 5% loading - I think that's the standard rule of thumb (when >>there are no switches and everything collides with everything).
> A great deal depends on one's criterion. (It what flux density does this > transformer iron saturate?) Maximum delivered bits occurs at X/e. The > system chokes beyond that, with throughput becoming very small. At X/5 > there is poor latency but even temporary choking is very unlikely. At > x/20 it is possible for each user to think he has a private channel. > Take your pick.
Are you including the capture effect? It tends to increase overall throughput at high utilization, though also at high latency. (The backoff algorithm gives an extra advantage to the host that sent most recently.) Also, larger than average packets tend to increase throughput. -- glen
glen herrmannsfeldt wrote:
> Jerry Avins wrote: > > (someone wrote) > >>> Well, I would have said that an ethernet network design should be no >>> greater than X/20 or 5% loading - I think that's the standard rule of >>> thumb (when there are no switches and everything collides with >>> everything). > > >> A great deal depends on one's criterion. (It what flux density does this >> transformer iron saturate?) Maximum delivered bits occurs at X/e. The >> system chokes beyond that, with throughput becoming very small. At X/5 >> there is poor latency but even temporary choking is very unlikely. At >> x/20 it is possible for each user to think he has a private channel. >> Take your pick. > > > Are you including the capture effect? It tends to increase overall > throughput at high utilization, though also at high latency. (The > backoff algorithm gives an extra advantage to the host that sent most > recently.) Also, larger than average packets tend to increase throughput.
No, I hadn't. Most people tell me that when such considerations become necessary, they help only a little. Critical loading is a phenomenon that applies not only to networks, but also to roads and other constructs that make the term "traffic" relevant. I think someone once abstracted a general theory. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
news:35qcpmF4na5qtU1@individual.net...
> glen herrmannsfeldt wrote: > > > Jerry Avins wrote: > > > > (someone wrote) > > > >>> Well, I would have said that an ethernet network design should be no > >>> greater than X/20 or 5% loading - I think that's the standard rule of > >>> thumb (when there are no switches and everything collides with > >>> everything). > > > > > >> A great deal depends on one's criterion. (It what flux density does this > >> transformer iron saturate?) Maximum delivered bits occurs at X/e. The > >> system chokes beyond that, with throughput becoming very small. At X/5 > >> there is poor latency but even temporary choking is very unlikely. At > >> x/20 it is possible for each user to think he has a private channel. > >> Take your pick. > > > > > > Are you including the capture effect? It tends to increase overall > > throughput at high utilization, though also at high latency. (The > > backoff algorithm gives an extra advantage to the host that sent most > > recently.) Also, larger than average packets tend to increase throughput. > > No, I hadn't. Most people tell me that when such considerations become > necessary, they help only a little. > > Critical loading is a phenomenon that applies not only to networks, but > also to roads and other constructs that make the term "traffic" > relevant. I think someone once abstracted a general theory.
Of course nowadays, it is extremely cheap to construct Ethernet networks with no collisions using switches instead of repeater hubs. Plus you can get full-duplex communication at the nominal bit rate with everyone essentially having a private full-bandwidth channel, as long as the switching fabric can keep up. CobraNet is a technology that takes advantage of this, reliably sending hundreds of uncompressed high-resolution audio channels around a switched Ethernet network with minimal buffering/latency (no retries are necessary/possible). Even with a $30 5-port switch from the local computer megastore, collisions and retries are a thing of the past!
"Jim Thomas" <jthomas@bittware.com> wrote in message
news:10vfbjsckaemd74@corp.supernews.com...
> Jerry Avins wrote: > > Ethernet was originally a broadcast -- as in FM radio -- protocol > > developed to link sites of the University of Hawaii. > > I think they called that the Aloha protocol. The transmitter didn't > check the medium before transmitting, but waited for an ack. If it > didn't get one, it would retransmit. > > The only reason I remember any of this is because my in-laws operate on > a modified-Aloha protocol in their everyday conversation. The > modification is that if they don't receive an ack, they retransmit with > MORE POWER. > > I remember the first Christmas Eve I spent with them. One of my wife's > uncles was talking to me when his brother just butted in. Not knowing > how to respond, I ignored him. That's when he retransmitted. Louder. > I ignored him again and soon learned until he got that ack, he was going > to keep retransmitting at ever greater power levels. Apparently, his > loop termination condition did not include a maximum-retries term. > Meanwhile, the first uncle upped his power too. In an attempt to > prevent the volume from overpowering my receiver, I was forced into TDM > mode. Unfortunately, their protocol did not include an allowance for > backing off the power levels. > > Those uncles never once called one another out with a "I was talking > first," nor did they seem to think it was odd. It was their protocol. > That's how it progressed the WHOLE EVENING, with upwards of a dozen > transmitters (and I was not the only receiver either).
That reminds me of spending an evening with 2 of my wife's friends. Of the 4 of us, the 3 others seemed to talk constantly, usually at least 2 at the same time. They were all apparently all very good at full-duplex communication whereas personally I can only talk or listen at the same time, not both. When they had left, she asked why I was so quiet. I told her I was waiting for silence (that never came) to begin talking!
