Hello, This code is a modification of some TI code to allow me to transfer 32 bits over a mcbsp via a DMA. It works fine for McBSP1 but if I make the changes needed to make it work for McBSP0 it hangs at the "Wait for DMA transfer to be complete" loop. (I've noted the mods "wont work"). This should be simple. I'm also a bit confused DMA config structure line. It looks to me it gets written over later anyway? 0, // (DMA_AdrPtr)(MCBSP_ADDR(DRR10)), /* DMACSSAL */ Thanks for any input teeretz //=============================================== //=============================================== #include <stdio.h> #include <csl_mcbsp.h> #include <csl_dma.h> #include <csl_irq.h> #ifndef NOP #define NOP asm( " nop ") #endif //---------Global constants--------- #define N 8 //---------Global data definition--------- /* Define transmit and receive buffers */ #pragma DATA_SECTION(rcv,"dmaMem") Uint32 xmt[N], rcv[N]; MCBSP_Config ConfigLoopBack32= { MCBSP_SPCR1_RMK( MCBSP_SPCR1_DLB_ON, /* DLB = 1 */ MCBSP_SPCR1_RJUST_RZF, /* RJUST = 0 */ MCBSP_SPCR1_CLKSTP_DISABLE, /* CLKSTP = 0 */ MCBSP_SPCR1_DXENA_NA, /* DXENA = 0 */ MCBSP_SPCR1_ABIS_DISABLE, /* ABIS = 0 */ MCBSP_SPCR1_RINTM_RRDY, /* RINTM = 0 */ 0, /* RSYNCER = 0 */ MCBSP_SPCR1_RRST_DISABLE /* RRST = 0 */ ), MCBSP_SPCR2_RMK( MCBSP_SPCR2_FREE_NO, /* FREE = 0 */ MCBSP_SPCR2_SOFT_NO, /* SOFT = 0 */ MCBSP_SPCR2_FRST_RESET, /* FRST = 0 */ MCBSP_SPCR2_GRST_RESET, /* GRST = 0 */ MCBSP_SPCR2_XINTM_XRDY, /* XINTM = 0 */ 0, /* XSYNCER = N/A */ MCBSP_SPCR2_XRST_DISABLE /* XRST = 0 */ ), MCBSP_RCR1_RMK( MCBSP_RCR1_RFRLEN1_OF(0), /* RFRLEN1 = 0 */ MCBSP_RCR1_RWDLEN1_32BIT /* RWDLEN1 = 5 */ ), MCBSP_RCR2_RMK( MCBSP_RCR2_RPHASE_SINGLE, /* RPHASE = 0 */ MCBSP_RCR2_RFRLEN2_OF(0), /* RFRLEN2 = 0 */ MCBSP_RCR2_RWDLEN2_8BIT, /* RWDLEN2 = 0 */ MCBSP_RCR2_RCOMPAND_MSB, /* RCOMPAND = 0 */ MCBSP_RCR2_RFIG_YES, /* RFIG = 0 */ MCBSP_RCR2_RDATDLY_0BIT /* RDATDLY = 0 */ ), MCBSP_XCR1_RMK( MCBSP_XCR1_XFRLEN1_OF(0), /* XFRLEN1 = 0 */ MCBSP_XCR1_XWDLEN1_32BIT /* XWDLEN1 = 5 */ ), MCBSP_XCR2_RMK( MCBSP_XCR2_XPHASE_SINGLE, /* XPHASE = 0 */ MCBSP_XCR2_XFRLEN2_OF(0), /* XFRLEN2 = 0 */ MCBSP_XCR2_XWDLEN2_8BIT, /* XWDLEN2 = 0 */ MCBSP_XCR2_XCOMPAND_MSB, /* XCOMPAND = 0 */ MCBSP_XCR2_XFIG_YES, /* XFIG = 0 */ MCBSP_XCR2_XDATDLY_0BIT /* XDATDLY = 0 */ ), MCBSP_SRGR1_RMK( MCBSP_SRGR1_FWID_OF(1), /* FWID = 1 */ MCBSP_SRGR1_CLKGDV_OF(1) /* CLKGDV = 1 */ ), MCBSP_SRGR2_RMK( MCBSP_SRGR2_GSYNC_FREE, /* FREE = 0 */ MCBSP_SRGR2_CLKSP_RISING, /* CLKSP = 0 */ MCBSP_SRGR2_CLKSM_INTERNAL, /* CLKSM = 1 */ MCBSP_SRGR2_FSGM_DXR2XSR, /* FSGM = 0 */ MCBSP_SRGR2_FPER_OF(15) /* FPER = 0 */ ), MCBSP_MCR1_DEFAULT, MCBSP_MCR2_DEFAULT, MCBSP_PCR_RMK( MCBSP_PCR_IDLEEN_RESET, /* IDLEEN = 0 */ MCBSP_PCR_XIOEN_SP, /* XIOEN = 0 */ MCBSP_PCR_RIOEN_SP, /* RIOEN = 0 */ MCBSP_PCR_FSXM_INTERNAL, /* FSXM = 1 */ MCBSP_PCR_FSRM_EXTERNAL, /* FSRM = 0 */ MCBSP_PCR_CLKXM_OUTPUT, /* CLKXM = 1 */ MCBSP_PCR_CLKRM_INPUT, /* CLKRM = 0 */ MCBSP_PCR_SCLKME_NO, /* SCLKME = 0 */ 0, /* DXSTAT = N/A */ MCBSP_PCR_FSXP_ACTIVEHIGH, /* FSXP = 0 */ MCBSP_PCR_FSRP_ACTIVEHIGH, /* FSRP = 0 */ MCBSP_PCR_CLKXP_RISING, /* CLKXP = 0 */ MCBSP_PCR_CLKRP_FALLING /* CLKRP = 0 */ ), MCBSP_RCERA_DEFAULT, MCBSP_RCERB_DEFAULT, MCBSP_RCERC_DEFAULT, MCBSP_RCERD_DEFAULT, MCBSP_RCERE_DEFAULT, MCBSP_RCERF_DEFAULT, MCBSP_RCERG_DEFAULT, MCBSP_RCERH_DEFAULT, MCBSP_XCERA_DEFAULT, MCBSP_XCERB_DEFAULT, MCBSP_XCERC_DEFAULT, MCBSP_XCERD_DEFAULT, MCBSP_XCERE_DEFAULT, MCBSP_XCERF_DEFAULT, MCBSP_XCERG_DEFAULT, MCBSP_XCERH_DEFAULT }; /* Create DMA Receive Side Configuration */ DMA_Config dmaConfig = { DMA_DMACSDP_RMK( DMA_DMACSDP_DSTBEN_NOBURST, DMA_DMACSDP_DSTPACK_OFF, DMA_DMACSDP_DST_DARAM, DMA_DMACSDP_SRCBEN_NOBURST, DMA_DMACSDP_SRCPACK_OFF, DMA_DMACSDP_SRC_PERIPH, DMA_DMACSDP_DATATYPE_32BIT ), /* DMACSDP */ DMA_DMACCR_RMK( DMA_DMACCR_DSTAMODE_POSTINC, DMA_DMACCR_SRCAMODE_CONST, DMA_DMACCR_ENDPROG_ON, DMA_DMACCR_REPEAT_OFF, DMA_DMACCR_AUTOINIT_OFF, DMA_DMACCR_EN_STOP, DMA_DMACCR_PRIO_LOW, DMA_DMACCR_FS_DISABLE, DMA_DMACCR_SYNC_REVT1 ), /* DMACCR */ DMA_DMACICR_RMK( DMA_DMACICR_BLOCKIE_OFF, DMA_DMACICR_LASTIE_OFF, DMA_DMACICR_FRAMEIE_ON, DMA_DMACICR_FIRSTHALFIE_OFF, DMA_DMACICR_DROPIE_OFF, DMA_DMACICR_TIMEOUTIE_OFF ), /* DMACICR */ 0, // (DMA_AdrPtr)(MCBSP_ADDR(DRR10)), /* DMACSSAL */ 0, /* DMACSSAU */ (DMA_AdrPtr)&rcv, /* DMACDSAL */ 0, /* DMACDSAU */ N, /* DMACEN */ 1, /* DMACFN */ 0, /* DMACFI */ 0 /* DMACEI */ }; /* Define a DMA_Handle object to be used with DMA_open function */ DMA_Handle mhDma; /* Define a MCBSP_Handle object to be used with MCBSP_open function */ MCBSP_Handle mhMcbsp; volatile Uint16 xfrCnt = 0; Uint16 err = 0; Uint16 old_intm; Uint16 xmtEventId; //---------Function prototypes--------- /* Protoype for MCBSP transmit interrupt function */ interrupt void mcbspIsr(void); void taskFxn(void); //---------main routine--------- void main(void) { Uint16 i; Uint32 kk; /* Initialize CSL library - This is REQUIRED !!! */ CSL_init(); kk = 0x12345678; /* Initialize data for transfer */ for (i = 0; i <= N - 1; i++) { xmt[i] = kk++; rcv[i] = 0; } /* Call function to effect transfer */ taskFxn(); } void taskFxn(void) { Uint16 srcAddrHi, srcAddrLo; Uint16 dstAddrHi, dstAddrLo; Uint16 i; // By default, the TMS320C55xx compiler assigns all data symbols word addresses. // The DMA however, expects all addresses to be byte addresses. // Therefore, we must shift the address by 2 in order to change the word // address to a byte address for the DMA transfer. // works on mcbsp1 srcAddrHi = (Uint16)(((Uint32)(MCBSP_ADDR(DRR21))) >> 15) & 0xFFFFu; srcAddrLo = (Uint16)(((Uint32)(MCBSP_ADDR(DRR21))) << 1) & 0xFFFFu; // wont work on mcbsp0 // srcAddrHi = (Uint16)(((Uint32)(MCBSP_ADDR(DRR20))) >> 15) & 0xFFFFu; // srcAddrLo = (Uint16)(((Uint32)(MCBSP_ADDR(DRR20))) << 1) & 0xFFFFu; dstAddrHi = (Uint16)(((Uint32)(&rcv)) >> 15) & 0xFFFFu; dstAddrLo = (Uint16)(((Uint32)(&rcv)) << 1) & 0xFFFF; dmaConfig.dmacssal = (DMA_AdrPtr)srcAddrLo; dmaConfig.dmacssau = srcAddrHi; dmaConfig.dmacdsal = (DMA_AdrPtr)dstAddrLo; dmaConfig.dmacdsau = dstAddrHi; /* Open MCBSP Port 1 and set registers to their power on defaults */ // works mhMcbsp = MCBSP_open(MCBSP_PORT1, MCBSP_OPEN_RESET); // won't work // mhMcbsp = MCBSP_open(MCBSP_PORT0, MCBSP_OPEN_RESET); /* Get interrupt event assoicated MCBSP transmit */ xmtEventId = MCBSP_getXmtEventId(mhMcbsp); /* Temporarily disable interrupts and clear any pending */ /* interrupts for MCBSP transmit */ old_intm = IRQ_globalDisable(); IRQ_clear(xmtEventId); /* Enable MCBSP transmit interrupt in IER register */ IRQ_enable(xmtEventId); /* Set Start Of Interrupt Vector Table */ IRQ_setVecs(0x10000); /* Place address for MCBSP transmit interrupt service routine */ /* in associated vector location */ IRQ_plug(xmtEventId,&mcbspIsr); /* Open DMA Channel 2 and set registers to their power on defaults */ mhDma = DMA_open(DMA_CHA2,DMA_OPEN_RESET); /* Write values from configuration structure to MCBSP control regs */ MCBSP_config(mhMcbsp, &ConfigLoopBack32); /* Write values from configuration structure to DMA control regs */ DMA_config(mhDma,&dmaConfig); /* Enable all maskable interrupts */ IRQ_globalEnable(); /* Start MCBSP */ MCBSP_start(mhMcbsp, MCBSP_SRGR_START|MCBSP_SRGR_FRAMESYNC,0x300u); /* Enable DMA */ DMA_start(mhDma); /* Take MCBSP transmit annd receive out of reset */ MCBSP_start(mhMcbsp, MCBSP_XMIT_START| MCBSP_RCV_START, 0); /* Wait for DMA transfer to be complete */ while (!DMA_FGETH(mhDma,DMACSR,FRAME)) { NOP; } /*------------------------------------------*\ * Compare values \*------------------------------------------*/ for(i = 0; i <= N - 1; i++){ if (rcv[i] != xmt[i]){ ++err; break; } } printf ("%s\n",err?"TEST FAILED" : "TEST PASSED"); /* Restore status of global interrupt enable flag */ IRQ_globalRestore(old_intm); /* We're done with MCBSP and DMA , so close them */ MCBSP_close(mhMcbsp); DMA_close(mhDma); } /* MCBSP transmit interrupt service routine */ interrupt void mcbspIsr(void) { if (xfrCnt < N) { MCBSP_write32(mhMcbsp,xmt[xfrCnt]); ++xfrCnt; } else { MCBSP_FSETH(mhMcbsp,SPCR2,XRST,0); } }
TI 5509a mcbsp / dma problem
Started by ●January 25, 2005
Reply by ●January 25, 20052005-01-25
One reason you might not ever see the DMA transfer complete would be if nothing is coming in the McBSP. If you look at the McBSP registers and refresh a bunch of times can you see data coming in? It looks like you've got it set up for external clock and frame sync. Are you sure there are signals being provided by an external device to both McBSPs? Brad "teeretz" <teeretz@yahoo.com> wrote in message news:1106694977.439281.305290@z14g2000cwz.googlegroups.com...> Hello, > > This code is a modification of some TI code to allow me to > transfer 32 bits over a mcbsp via a DMA. It works fine > for McBSP1 but if I make the changes needed to make it work > for McBSP0 it hangs at the "Wait for DMA transfer to be complete" > loop. (I've noted the mods "wont work"). This should be simple. > > > I'm also a bit confused DMA config structure line. It looks to me > it gets written over later anyway? > 0, // (DMA_AdrPtr)(MCBSP_ADDR(DRR10)), /* DMACSSAL */ > > > Thanks for any input > > teeretz > > > //=============================================== > //=============================================== > > #include <stdio.h> > > #include <csl_mcbsp.h> > #include <csl_dma.h> > #include <csl_irq.h> > > > > #ifndef NOP > #define NOP asm( " nop ") > #endif > > > > //---------Global constants--------- > #define N 8 > > //---------Global data definition--------- > /* Define transmit and receive buffers */ > #pragma DATA_SECTION(rcv,"dmaMem") > Uint32 xmt[N], rcv[N]; > > > MCBSP_Config ConfigLoopBack32= { > MCBSP_SPCR1_RMK( > MCBSP_SPCR1_DLB_ON, /* DLB = 1 */ > MCBSP_SPCR1_RJUST_RZF, /* RJUST = 0 */ > MCBSP_SPCR1_CLKSTP_DISABLE, /* CLKSTP = 0 */ > MCBSP_SPCR1_DXENA_NA, /* DXENA = 0 */ > MCBSP_SPCR1_ABIS_DISABLE, /* ABIS = 0 */ > MCBSP_SPCR1_RINTM_RRDY, /* RINTM = 0 */ > 0, /* RSYNCER = 0 */ > MCBSP_SPCR1_RRST_DISABLE /* RRST = 0 */ > ), > MCBSP_SPCR2_RMK( > MCBSP_SPCR2_FREE_NO, /* FREE = 0 */ > MCBSP_SPCR2_SOFT_NO, /* SOFT = 0 */ > MCBSP_SPCR2_FRST_RESET, /* FRST = 0 */ > MCBSP_SPCR2_GRST_RESET, /* GRST = 0 */ > MCBSP_SPCR2_XINTM_XRDY, /* XINTM = 0 */ > 0, /* XSYNCER = N/A */ > MCBSP_SPCR2_XRST_DISABLE /* XRST = 0 */ > ), > MCBSP_RCR1_RMK( > MCBSP_RCR1_RFRLEN1_OF(0), /* RFRLEN1 = 0 */ > MCBSP_RCR1_RWDLEN1_32BIT /* RWDLEN1 = 5 */ > ), > MCBSP_RCR2_RMK( > MCBSP_RCR2_RPHASE_SINGLE, /* RPHASE = 0 */ > MCBSP_RCR2_RFRLEN2_OF(0), /* RFRLEN2 = 0 */ > MCBSP_RCR2_RWDLEN2_8BIT, /* RWDLEN2 = 0 */ > MCBSP_RCR2_RCOMPAND_MSB, /* RCOMPAND = 0 */ > MCBSP_RCR2_RFIG_YES, /* RFIG = 0 */ > MCBSP_RCR2_RDATDLY_0BIT /* RDATDLY = 0 */ > ), > MCBSP_XCR1_RMK( > MCBSP_XCR1_XFRLEN1_OF(0), /* XFRLEN1 = 0 */ > MCBSP_XCR1_XWDLEN1_32BIT /* XWDLEN1 = 5 */ > > ), > MCBSP_XCR2_RMK( > MCBSP_XCR2_XPHASE_SINGLE, /* XPHASE = 0 */ > MCBSP_XCR2_XFRLEN2_OF(0), /* XFRLEN2 = 0 */ > MCBSP_XCR2_XWDLEN2_8BIT, /* XWDLEN2 = 0 */ > MCBSP_XCR2_XCOMPAND_MSB, /* XCOMPAND = 0 */ > MCBSP_XCR2_XFIG_YES, /* XFIG = 0 */ > MCBSP_XCR2_XDATDLY_0BIT /* XDATDLY = 0 */ > ), > MCBSP_SRGR1_RMK( > MCBSP_SRGR1_FWID_OF(1), /* FWID = 1 */ > MCBSP_SRGR1_CLKGDV_OF(1) /* CLKGDV = 1 */ > ), > MCBSP_SRGR2_RMK( > MCBSP_SRGR2_GSYNC_FREE, /* FREE = 0 */ > MCBSP_SRGR2_CLKSP_RISING, /* CLKSP = 0 */ > MCBSP_SRGR2_CLKSM_INTERNAL, /* CLKSM = 1 */ > MCBSP_SRGR2_FSGM_DXR2XSR, /* FSGM = 0 */ > MCBSP_SRGR2_FPER_OF(15) /* FPER = 0 */ > ), > MCBSP_MCR1_DEFAULT, > MCBSP_MCR2_DEFAULT, > MCBSP_PCR_RMK( > MCBSP_PCR_IDLEEN_RESET, /* IDLEEN = 0 */ > MCBSP_PCR_XIOEN_SP, /* XIOEN = 0 */ > MCBSP_PCR_RIOEN_SP, /* RIOEN = 0 */ > MCBSP_PCR_FSXM_INTERNAL, /* FSXM = 1 */ > MCBSP_PCR_FSRM_EXTERNAL, /* FSRM = 0 */ > MCBSP_PCR_CLKXM_OUTPUT, /* CLKXM = 1 */ > MCBSP_PCR_CLKRM_INPUT, /* CLKRM = 0 */ > MCBSP_PCR_SCLKME_NO, /* SCLKME = 0 */ > 0, /* DXSTAT = N/A */ > MCBSP_PCR_FSXP_ACTIVEHIGH, /* FSXP = 0 */ > MCBSP_PCR_FSRP_ACTIVEHIGH, /* FSRP = 0 */ > MCBSP_PCR_CLKXP_RISING, /* CLKXP = 0 */ > MCBSP_PCR_CLKRP_FALLING /* CLKRP = 0 */ > ), > MCBSP_RCERA_DEFAULT, > MCBSP_RCERB_DEFAULT, > MCBSP_RCERC_DEFAULT, > MCBSP_RCERD_DEFAULT, > MCBSP_RCERE_DEFAULT, > MCBSP_RCERF_DEFAULT, > MCBSP_RCERG_DEFAULT, > MCBSP_RCERH_DEFAULT, > MCBSP_XCERA_DEFAULT, > MCBSP_XCERB_DEFAULT, > MCBSP_XCERC_DEFAULT, > MCBSP_XCERD_DEFAULT, > MCBSP_XCERE_DEFAULT, > MCBSP_XCERF_DEFAULT, > MCBSP_XCERG_DEFAULT, > MCBSP_XCERH_DEFAULT > }; > > /* Create DMA Receive Side Configuration */ > DMA_Config dmaConfig = { > DMA_DMACSDP_RMK( > DMA_DMACSDP_DSTBEN_NOBURST, > DMA_DMACSDP_DSTPACK_OFF, > DMA_DMACSDP_DST_DARAM, > DMA_DMACSDP_SRCBEN_NOBURST, > DMA_DMACSDP_SRCPACK_OFF, > DMA_DMACSDP_SRC_PERIPH, > DMA_DMACSDP_DATATYPE_32BIT > ), /* DMACSDP */ > DMA_DMACCR_RMK( > DMA_DMACCR_DSTAMODE_POSTINC, > DMA_DMACCR_SRCAMODE_CONST, > DMA_DMACCR_ENDPROG_ON, > DMA_DMACCR_REPEAT_OFF, > DMA_DMACCR_AUTOINIT_OFF, > DMA_DMACCR_EN_STOP, > DMA_DMACCR_PRIO_LOW, > DMA_DMACCR_FS_DISABLE, > DMA_DMACCR_SYNC_REVT1 > ), /* DMACCR */ > DMA_DMACICR_RMK( > DMA_DMACICR_BLOCKIE_OFF, > DMA_DMACICR_LASTIE_OFF, > DMA_DMACICR_FRAMEIE_ON, > DMA_DMACICR_FIRSTHALFIE_OFF, > DMA_DMACICR_DROPIE_OFF, > DMA_DMACICR_TIMEOUTIE_OFF > ), /* DMACICR */ > 0, // (DMA_AdrPtr)(MCBSP_ADDR(DRR10)), /* DMACSSAL */ > 0, /* DMACSSAU */ > (DMA_AdrPtr)&rcv, /* DMACDSAL */ > 0, /* DMACDSAU */ > N, /* DMACEN */ > 1, /* DMACFN */ > 0, /* DMACFI */ > 0 /* DMACEI */ > }; > > /* Define a DMA_Handle object to be used with DMA_open function */ > DMA_Handle mhDma; > > /* Define a MCBSP_Handle object to be used with MCBSP_open function */ > MCBSP_Handle mhMcbsp; > > volatile Uint16 xfrCnt = 0; > Uint16 err = 0; > Uint16 old_intm; > Uint16 xmtEventId; > > //---------Function prototypes--------- > /* Protoype for MCBSP transmit interrupt function */ > interrupt void mcbspIsr(void); > void taskFxn(void); > > //---------main routine--------- > void main(void) > { > Uint16 i; > Uint32 kk; > > /* Initialize CSL library - This is REQUIRED !!! */ > CSL_init(); > > kk = 0x12345678; > > /* Initialize data for transfer */ > for (i = 0; i <= N - 1; i++) { > xmt[i] = kk++; > > rcv[i] = 0; > } > > /* Call function to effect transfer */ > taskFxn(); > } > > void taskFxn(void) > { > Uint16 srcAddrHi, srcAddrLo; > Uint16 dstAddrHi, dstAddrLo; > Uint16 i; > > > // By default, the TMS320C55xx compiler assigns all data symbols word > addresses. > // The DMA however, expects all addresses to be byte addresses. > // Therefore, we must shift the address by 2 in order to change the > word > // address to a byte address for the DMA transfer. > > // works on mcbsp1 > srcAddrHi = (Uint16)(((Uint32)(MCBSP_ADDR(DRR21))) >> 15) & > 0xFFFFu; > srcAddrLo = (Uint16)(((Uint32)(MCBSP_ADDR(DRR21))) << 1) & 0xFFFFu; > // wont work on mcbsp0 > // srcAddrHi = (Uint16)(((Uint32)(MCBSP_ADDR(DRR20))) >> 15) & > 0xFFFFu; > // srcAddrLo = (Uint16)(((Uint32)(MCBSP_ADDR(DRR20))) << 1) & > 0xFFFFu; > > > dstAddrHi = (Uint16)(((Uint32)(&rcv)) >> 15) & 0xFFFFu; > dstAddrLo = (Uint16)(((Uint32)(&rcv)) << 1) & 0xFFFF; > > > dmaConfig.dmacssal = (DMA_AdrPtr)srcAddrLo; > dmaConfig.dmacssau = srcAddrHi; > > dmaConfig.dmacdsal = (DMA_AdrPtr)dstAddrLo; > dmaConfig.dmacdsau = dstAddrHi; > > > /* Open MCBSP Port 1 and set registers to their power on defaults > */ > // works > mhMcbsp = MCBSP_open(MCBSP_PORT1, MCBSP_OPEN_RESET); > > // won't work > // mhMcbsp = MCBSP_open(MCBSP_PORT0, MCBSP_OPEN_RESET); > > > /* Get interrupt event assoicated MCBSP transmit */ > xmtEventId = MCBSP_getXmtEventId(mhMcbsp); > > /* Temporarily disable interrupts and clear any pending */ > /* interrupts for MCBSP transmit */ > old_intm = IRQ_globalDisable(); > IRQ_clear(xmtEventId); > > /* Enable MCBSP transmit interrupt in IER register */ > IRQ_enable(xmtEventId); > > /* Set Start Of Interrupt Vector Table */ > IRQ_setVecs(0x10000); > > /* Place address for MCBSP transmit interrupt service routine */ > /* in associated vector location */ > IRQ_plug(xmtEventId,&mcbspIsr); > > /* Open DMA Channel 2 and set registers to their power on defaults > */ > mhDma = DMA_open(DMA_CHA2,DMA_OPEN_RESET); > > /* Write values from configuration structure to MCBSP control regs > */ > MCBSP_config(mhMcbsp, &ConfigLoopBack32); > > /* Write values from configuration structure to DMA control regs */ > DMA_config(mhDma,&dmaConfig); > > /* Enable all maskable interrupts */ > IRQ_globalEnable(); > > /* Start MCBSP */ > MCBSP_start(mhMcbsp, MCBSP_SRGR_START|MCBSP_SRGR_FRAMESYNC,0x300u); > > /* Enable DMA */ > DMA_start(mhDma); > > /* Take MCBSP transmit annd receive out of reset */ > MCBSP_start(mhMcbsp, MCBSP_XMIT_START| MCBSP_RCV_START, 0); > > /* Wait for DMA transfer to be complete */ > while (!DMA_FGETH(mhDma,DMACSR,FRAME)) > { > NOP; > } > > /*------------------------------------------*\ > * Compare values > \*------------------------------------------*/ > for(i = 0; i <= N - 1; i++){ > if (rcv[i] != xmt[i]){ > ++err; > break; > } > } > > printf ("%s\n",err?"TEST FAILED" : "TEST PASSED"); > > /* Restore status of global interrupt enable flag */ > IRQ_globalRestore(old_intm); > > /* We're done with MCBSP and DMA , so close them */ > MCBSP_close(mhMcbsp); > DMA_close(mhDma); > } > > /* MCBSP transmit interrupt service routine */ > interrupt void mcbspIsr(void) { > > if (xfrCnt < N) { > MCBSP_write32(mhMcbsp,xmt[xfrCnt]); > ++xfrCnt; > } > else { > MCBSP_FSETH(mhMcbsp,SPCR2,XRST,0); > } > } >
Reply by ●January 26, 20052005-01-26
Brad, Thanks for the reply. The McBSP is set up in digital loop back mode so there are no signals. The values are tx out the McBsp and rx in internally. I will double check the settings for the McBSP. I assumed they where ok since all was fine when set to McBSP1 teeretz
Nevermind, Missed a setting in DMACCR (Should be DMA_DMACCR_SYNC_REVT0) I knew I was missing something simple... Still learning CSL. I do stand by my comment about the DMACSSAL. It gets written over later by some fudging to fix byte addressing issues. For the McBsp one may use (DMA_AdrPtr)((MCBSP_ADDR(DRR10))<<1), /* DMACSSAL */ in the setup structure and kill off the fix later on. Thanks teeretz
