c6711 data transfer
Started by memo January 28, 2005
Hello,
I am trying to use a c6711 for a controls project. This board does not
have a GPIO since it is the first revision. I want to know if there is any
way to input/output to the board (from an analog circuit) without buying
any daughter card.
Thanks in advance for your response,
memo
		This message was sent using the Comp.DSP web interface on DSPRelated.com
you can try using the sound channel ...
"memo" <mergezer@ysu.edu> wrote in message
news:10vln14e8qpa592@news.supernews.com...
> Hello, > I am trying to use a c6711 for a controls project. This board does not > have a GPIO since it is the first revision. I want to know if there is any > way to input/output to the board (from an analog circuit) without buying > any daughter card. > > Thanks in advance for your response, > memo > > > This message was sent using the Comp.DSP web interface on DSPRelated.com
