I need to record some real-world RF waveforms. All-digital approach looks *very* disk intensive! Wondering if there are multi-channel analog recorders adequate for the job. Pointers to "better" digital solutions are appreciated as well. Scenario: I have 8 antennas receiving ~1GHz signals, ~5 MHz bandwidth each signal. Each antenna drives 3 RF->IF sections, for a total of 24 IF outputs. IF is around 75MHz. IF is undersampled (Fs=60MHz) with 12-bit A/D converters. 60M samples/second * 12 bits/8 bits/byte) = 90 Mbytes/sec 24 channels * 90 Mbytes/sec = 2.16 GB/sec (That's 129.6 GB/minute or 7.776 Terabytes/hour, and I'd like to record a full hour of data.) 24 channels is ideal, but 4 channels is absolute minimum. Could record either the 75MHz IF output, or 1GHz RF straight from the antennas. I then need to play these back (4-24 channels in parallel) for testing my receiver (al RF or just IF). [Analog in and out is easiest. Digital record/playback approach is OK (no wow & flutter problem) as long as resolution remains around 12-bits and there are no artifacts of original sampling, because I need "authentic" signals coming thru the IF and into my A/D converters for accurate testing.] [I could also test my DSP section only, by recording my own A/D converter outputs, given an affordable disk system with sufficient I/O bandwidth. With 8 channels at 90MB/s = 720 megabytes/second, I could record about 6 minutes of data on one 250 GB drive, which is an acceptable starting point for me.] Tall order I know, but I'm open to creative solutions. Thanks a ton for *any* help or references you can provide. mj
Analog, multichannel RF recorder?
Started by ●February 3, 2005
Reply by ●February 3, 20052005-02-03
jjohnson@cs.ucf.edu wrote:> I need to record some real-world RF waveforms. All-digital approach > looks *very* disk intensive! > > Wondering if there are multi-channel analog recorders adequate for the > job. Pointers to "better" digital solutions are appreciated as well. > > Scenario: > > I have 8 antennas receiving ~1GHz signals, ~5 MHz bandwidth each > signal. > > Each antenna drives 3 RF->IF sections, for a total of 24 IF outputs. > IF is around 75MHz. > > IF is undersampled (Fs=60MHz) with 12-bit A/D converters. > > 60M samples/second * 12 bits/8 bits/byte) = 90 Mbytes/sec > > 24 channels * 90 Mbytes/sec = 2.16 GB/sec > (That's 129.6 GB/minute or 7.776 Terabytes/hour, and I'd like to record > a full hour of data.) > > 24 channels is ideal, but 4 channels is absolute minimum. > Could record either the 75MHz IF output, or 1GHz RF straight from the > antennas. > > I then need to play these back (4-24 channels in parallel) for testing > my receiver (al RF or just IF). > > [Analog in and out is easiest. Digital record/playback approach is OK > (no wow & flutter problem) as long as resolution remains around 12-bits > and there are no artifacts of original sampling, because I need > "authentic" signals coming thru the IF and into my A/D converters for > accurate testing.] > > [I could also test my DSP section only, by recording my own A/D > converter outputs, given an affordable disk system with sufficient I/O > bandwidth. With 8 channels at 90MB/s = 720 megabytes/second, I could > record about 6 minutes of data on one 250 GB drive, which is an > acceptable starting point for me.] > > Tall order I know, but I'm open to creative solutions. Thanks a ton for > *any* help or references you can provide.What if you extract the modulation on the signals, record that, and regenerate the original signals by modulating oscillators? Why do you need a cycle-by-cycle record of the rf? -- john
jjohnson@cs.ucf.edu wrote:> I need to record some real-world RF waveforms. All-digital approach > looks *very* disk intensive! > > Wondering if there are multi-channel analog recorders adequate for the > job. Pointers to "better" digital solutions are appreciated as well. > > Scenario: > > I have 8 antennas receiving ~1GHz signals, ~5 MHz bandwidth each > signal. > > Each antenna drives 3 RF->IF sections, for a total of 24 IF outputs. > IF is around 75MHz. > > IF is undersampled (Fs=60MHz) with 12-bit A/D converters.That isn't undersampling if the bandwidth of each IF is less than 30 MHz. If it's really undersampled, you have garbage; find another project. If the bandwidth is much less than 30 MHz -- which in a 75MHz IF seems likely -- you can sample at a lower rate, saving data. You probably need to know only the baseband signal. They can recreate the RF with appropriate modulators.> 60M samples/second * 12 bits/8 bits/byte) = 90 Mbytes/sec > > 24 channels * 90 Mbytes/sec = 2.16 GB/sec > (That's 129.6 GB/minute or 7.776 Terabytes/hour, and I'd like to record > a full hour of data.) > > 24 channels is ideal, but 4 channels is absolute minimum. > Could record either the 75MHz IF output, or 1GHz RF straight from the > antennas. > > I then need to play these back (4-24 channels in parallel) for testing > my receiver (al RF or just IF). > > [Analog in and out is easiest. Digital record/playback approach is OK > (no wow & flutter problem) as long as resolution remains around 12-bits > and there are no artifacts of original sampling, because I need > "authentic" signals coming thru the IF and into my A/D converters for > accurate testing.] > > [I could also test my DSP section only, by recording my own A/D > converter outputs, given an affordable disk system with sufficient I/O > bandwidth. With 8 channels at 90MB/s = 720 megabytes/second, I could > record about 6 minutes of data on one 250 GB drive, which is an > acceptable starting point for me.] > > Tall order I know, but I'm open to creative solutions. Thanks a ton for > *any* help or references you can provide. > > mj >Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●February 4, 20052005-02-04
jjohnson@cs.ucf.edu wrote:> I need to record some real-world RF waveforms. All-digital approach > looks *very* disk intensive! > > Wondering if there are multi-channel analog recorders adequate forthe> job. Pointers to "better" digital solutions are appreciated as well. > > Scenario: > > I have 8 antennas receiving ~1GHz signals, ~5 MHz bandwidth each > signal. > > Each antenna drives 3 RF->IF sections, for a total of 24 IF outputs. > IF is around 75MHz. > > IF is undersampled (Fs=60MHz) with 12-bit A/D converters. > > 60M samples/second * 12 bits/8 bits/byte) = 90 Mbytes/sec > > 24 channels * 90 Mbytes/sec = 2.16 GB/sec > (That's 129.6 GB/minute or 7.776 Terabytes/hour, and I'd like torecord> a full hour of data.) > > 24 channels is ideal, but 4 channels is absolute minimum. > Could record either the 75MHz IF output, or 1GHz RF straight from the > antennas. > > I then need to play these back (4-24 channels in parallel) fortesting> my receiver (al RF or just IF). > > [Analog in and out is easiest. Digital record/playback approach is OK > (no wow & flutter problem) as long as resolution remains around12-bits> and there are no artifacts of original sampling, because I need > "authentic" signals coming thru the IF and into my A/D converters for > accurate testing.] > > [I could also test my DSP section only, by recording my own A/D > converter outputs, given an affordable disk system with sufficientI/O> bandwidth. With 8 channels at 90MB/s = 720 megabytes/second, I could > record about 6 minutes of data on one 250 GB drive, which is an > acceptable starting point for me.] > > Tall order I know, but I'm open to creative solutions. Thanks a tonfor> *any* help or references you can provide. > > mjYou mention that the signal BW is just 5 MHz. Is the signal center frequency fixed within the IF? If so, you could digitally downconvert the signal, with sample rate reduction, and record the baseband. I would think writing out to multiple disks simultaneously to reduce the required BW is the way to go. John
Sorry to have not been more accurate, precise, and clear. First, I think I should have said "bandpass sampled" instead of undersampled. IF output is centered at 75 MHz, +/- about 15MHz of signal BW (spectrum from 60MHz to 90 MHz). Sampling at 60MHz shifts that down to baseband (0-30MHz) where the DSP begins. The 5 MHz BW I quoted is after some of the filtering in our DSP. I was hoping to capture analog on a multichannel recorder so I could do repeated playback thru the RF->IF analog chain, and iteratively tweak components (including my A/D converters), without having the artifacts of other (possibly inferior) A/D converters corrupting my "gold-standard" reference signals. Digital capture also means I have to hook up 24 modulators to replay the RF. I wanted to avoid degrading my reference signals as much as possible. Replaying and modulating captured baseband means the next time I look at the signals in my DSP, they will have been thru my IF twice, plus somebody else's modulator, which munges things a bit. Thus, capturing original Rx antenna output would be ideal. Also, capturing the data will be expensive, as it requires rental of an airplane for a couple of hours. Swapping disks every 2-5 minutes does not give me much continuous, uninterrupted data to work from. (I want to replay an entire flight segment thru certain maneuvers and across a good strectch of airspace.) Having said that, if there is an "easy" (affordable, off-the shelf) RAID solution I can write to from my ADC converters (129.6 GB/minute for at least 10 minutes), I could use that for replay into my DSP datapath simulations. Not ideal, but far better than nothing. Hope this better explains my needs and rationale. But as I mentioned before, all feedback is appreciated. Thanks again, mj
In sci.physics jjohnson@cs.ucf.edu wrote:> Sorry to have not been more accurate, precise, and clear. First, I > think I should have said "bandpass sampled" instead of undersampled. > IF output is centered at 75 MHz, +/- about 15MHz of signal BW (spectrum > from 60MHz to 90 MHz).> Sampling at 60MHz shifts that down to baseband (0-30MHz) where the DSP > begins. The 5 MHz BW I quoted is after some of the filtering in our > DSP.> I was hoping to capture analog on a multichannel recorder so I could do > repeated playback thru the RF->IF analog chain, and iteratively tweak > components (including my A/D converters), without having the artifacts > of other (possibly inferior) A/D converters corrupting my > "gold-standard" reference signals.> Digital capture also means I have to hook up 24 modulators to replay > the RF. I wanted to avoid degrading my reference signals as much as > possible. Replaying and modulating captured baseband means the next > time I look at the signals in my DSP, they will have been thru my IF > twice, plus somebody else's modulator, which munges things a bit. Thus, > capturing original Rx antenna output would be ideal.> Also, capturing the data will be expensive, as it requires rental of an > airplane for a couple of hours. Swapping disks every 2-5 minutes does > not give me much continuous, uninterrupted data to work from. (I want > to replay an entire flight segment thru certain maneuvers and across a > good strectch of airspace.)> Having said that, if there is an "easy" (affordable, off-the shelf) > RAID solution I can write to from my ADC converters (129.6 GB/minute > for at least 10 minutes), I could use that for replay into my DSP > datapath simulations. Not ideal, but far better than nothing.> Hope this better explains my needs and rationale. But as I mentioned > before, all feedback is appreciated.> Thanks again,> mjAn off the shelf linux box with 4 400GB (~$300 ea) drives configured as one large disk with linux gets you 1.6 TB. However, AFAIK the fastest disks around these days have a transfer rate of 1.5 GB/sec which only gets you 90 GB/minute. There are some solid state disks around that can do better (but not much) than that with multiple fiber channel interfaces, but they aren't cheap. I know of no computer system you can buy that will directly address over 1 TB of memory; direct to memory would get you the speed, but not the capacity. I think you are screwed in storing this much data this quickly on any current storage device unless you can do real time compression on the data. -- Jim Pennino Remove -spam-sux to reply.
jjohnson@cs.ucf.edu wrote:> I need to record some real-world RF waveforms. All-digital approach > looks *very* disk intensive!Just on general principles, you can beat down the RF signal to video using quadrature detectors. Record the in phase video and quadrature videos on two video channels of sufficient bandwidth. In fact, you would be best off using A/D converter and record digitally. That, and the frequency and phase of the carrier, should give you all the information you need. Actual waveforms could be reconstructed in a computer, if you really need that. Bill
<jjohnson@cs.ucf.edu> wrote in message news:1107460901.200754.128210@c13g2000cwb.googlegroups.com...> I need to record some real-world RF waveforms. All-digital approach > looks *very* disk intensive! > > Wondering if there are multi-channel analog recorders adequate for the > job. Pointers to "better" digital solutions are appreciated as well. > > Scenario: > > I have 8 antennas receiving ~1GHz signals, ~5 MHz bandwidth each > signal. > > Each antenna drives 3 RF->IF sections, for a total of 24 IF outputs. > IF is around 75MHz. > > IF is undersampled (Fs=60MHz) with 12-bit A/D converters. > > 60M samples/second * 12 bits/8 bits/byte) = 90 Mbytes/sec > > 24 channels * 90 Mbytes/sec = 2.16 GB/sec > (That's 129.6 GB/minute or 7.776 Terabytes/hour, and I'd like to record > a full hour of data.) > > 24 channels is ideal, but 4 channels is absolute minimum. > Could record either the 75MHz IF output, or 1GHz RF straight from the > antennas. > > I then need to play these back (4-24 channels in parallel) for testing > my receiver (al RF or just IF). > > [Analog in and out is easiest. Digital record/playback approach is OK > (no wow & flutter problem) as long as resolution remains around 12-bits > and there are no artifacts of original sampling, because I need > "authentic" signals coming thru the IF and into my A/D converters for > accurate testing.] > > [I could also test my DSP section only, by recording my own A/D > converter outputs, given an affordable disk system with sufficient I/O > bandwidth. With 8 channels at 90MB/s = 720 megabytes/second, I could > record about 6 minutes of data on one 250 GB drive, which is an > acceptable starting point for me.] > > Tall order I know, but I'm open to creative solutions. Thanks a ton forAs you have "8 antennas receiving ~1GHz signals, ~5 MHz bandwidth each", what you might do is to mix the outputs the eight signals with a quasi-random, time-reference signal ( Perhaps from the GPS system.), and feed the outputs into nine video recorders. ( One for the quasi-random, time-reference signal.) A digital computer or optical computer, could be used to sample any two of the channels and to determine auto-correlations, cross-correlations, perform Fourier transforms, power spectral density, etc. -- Tom Potter
Reply by ●February 5, 20052005-02-05
