Hi, The transfer function for a lossy integrater is H(z) = z/(z-c) the magnitude spectrum is given by M(f) = |z|/|z-c| so lets say I have a c value of 0.8, how do I plot M(f)? I simply tried plugging in values for z ni the range of 0 to 1, but this does not give me what I would expect and I think I'm totally misunderstanding the z transorm. Any help?
Simple z-transform question
Started by ●February 7, 2005
Reply by ●February 7, 20052005-02-07
?ine Canby wrote:> Hi, > > The transfer function for a lossy integrater is > > H(z) = z/(z-c) > > the magnitude spectrum is given by > > M(f) = |z|/|z-c| > > so lets say I have a c value of 0.8, how do I plot M(f)? I simply > tried plugging in values for z ni the range of 0 to 1, but this does > not give me what I would expect and I think I'm totally > misunderstanding the z transorm. > > Any help?You are following a rote procedure that you learned from the Laplace domain, and since you don't understand it you're not applying it correctly to the z domain. In Laplace M(f) = |H(2*pi*j*f)| assuming that f is a frequency in Hz (so you plug in the j*omega operator). This works because the Laplace transform of a sine wave is L{sin(w*t)} = (1/2)*(1/(s + jw) - 1/(s - jw)), and finding the response to the transform boils down to finding the partial fraction expansion of (1/2)*(1/(s + jw) - 1/(s - jw))*H(s), which boils down to finding H(jw). The z domain is different from the Laplace domain. The z transform of a sine wave is Z{sin(w*k)} = (1/2)(1/(z - e^{j*w}) - 1/(z - e^{-j*w})). Go through all the partial fraction expansion gyrations and you're left with finding H(e^{j*w}). So in the z domain you find |H(e^{2*pi*j*f*Ts})|, where Ts is your sampling time and f is in Hz, and all is well. I prefer to roll all the frequency stuff into an angle (I usually call it theta, sometimes phi). This serves to remind me that I'm working in the sampled-time domain and I can't blithely cross from real continuous time to sampled time without thinking about it. In both frequency response cases you're tracing the stability boundary. In the Laplace domain this is the imaginary axis, where any pole with a negative real part is stable and any pole with a positive real part is unstable. In the z domain this is the unit circle, where any pole with an absolute value less than one is stable and any pole with an absolute value greater than one is unstable. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Reply by ●February 8, 20052005-02-08
"Tim Wescott" <tim@wescottnospamdesign.com> wrote in message news:110fbskq97rijd2@corp.supernews.com...> ?ine Canby wrote: > >> Hi, >> >> The transfer function for a lossy integrater is H(z) = z/(z-c) >> >> the magnitude spectrum is given by M(f) = |z|/|z-c| >> >> so lets say I have a c value of 0.8, how do I plot M(f)? I simply >> tried plugging in values for z ni the range of 0 to 1, but this does >> not give me what I would expect and I think I'm totally >> misunderstanding the z transorm. >> >> Any help? > > You are following a rote procedure that you learned from the Laplace > domain, and since you don't understand it you're not applying it correctly > to the z domain. > > In Laplace M(f) = |H(2*pi*j*f)| assuming that f is a frequency in Hz (so > you plug in the j*omega operator). This works because the Laplace > transform of a sine wave is L{sin(w*t)} = (1/2)*(1/(s + jw) - 1/(s - jw)), > and finding the response to the transform boils down to finding the > partial fraction expansion of (1/2)*(1/(s + jw) - 1/(s - jw))*H(s), which > boils down to finding H(jw). > > The z domain is different from the Laplace domain. The z transform of a > sine wave is Z{sin(w*k)} = (1/2)(1/(z - e^{j*w}) - 1/(z - e^{-j*w})). Go > through all the partial fraction expansion gyrations and you're left with > finding H(e^{j*w}). > > So in the z domain you find |H(e^{2*pi*j*f*Ts})|, where Ts is your > sampling time and f is in Hz, and all is well. I prefer to roll all the > frequency stuff into an angle (I usually call it theta, sometimes phi). > This serves to remind me that I'm working in the sampled-time domain and I > can't blithely cross from real continuous time to sampled time without > thinking about it. > > In both frequency response cases you're tracing the stability boundary. In > the Laplace domain this is the imaginary axis, where any pole with a > negative real part is stable and any pole with a positive real part is > unstable. In the z domain this is the unit circle, where any pole with an > absolute value less than one is stable and any pole with an absolute value > greater than one is unstable....like Tim said. And, if you don't like the exponential representation, you want to evaluate where z=a+jb and |z|=sqrt(a^2+b^2)=1 for all a and b that satisfy this condition. So, the polar form z=A:theta becomes z=1:theta where theta =0>2pi radians is easier to use and leads to the exponential version. Fred
?ine Canby wrote:> Hi, > > The transfer function for a lossy integrater is > > H(z) = z/(z-c) > > the magnitude spectrum is given by > > M(f) = |z|/|z-c| > > so lets say I have a c value of 0.8, how do I plot M(f)? I simply > tried plugging in values for z ni the range of 0 to 1, but this does > not give me what I would expect and I think I'm totally > misunderstanding the z transorm. > > Any help?No that won't work, given H(z) = z/(z-c) To get the "analog" frequency response you just need to substitute z=cexp(jwT) and vary w, where w is the frequency is rad/sec, T is sample period is seconds, and cexp is the complex exponent Everything is much easier if you use a language that supports complex math(C++ class,mathcad or even fortran) , in good old fortran its trivial j=(0,1) jw=j*w z=cexp(jw*T) h=z/(z-c) ! Or substitute any z transfer function here magnitude=20*log10(cabs(h)) phase =atan2d(aimag(h),real(h)) and if you want to compare the magnitude and phase response with an analog filter, then s = clog(z)/T ! by definition hs = 1/(s+a) ! Or substitue any s transfer function here magnitude=20*log10(cabs(hs)) phase =atan2d(aimag(hs),real(hs))
