Hello, I am using Linear feedback shift register(LFSR) to test Digital filter(DF) because LFSR generate white noise and has a flat like spectrum. Can anynody suggest when I pass white noise in DF, on what citeria should I judge the filter (Device Under Test) is pass or fail ?? my filter is 3rd order polyphase comb decimation filter with decimation factor of 256. I will appreciate if somebody pass hints or forword suggestions. Thanks in advance. Abdul
Testing Digital Filter
Started by ●February 9, 2005
Reply by ●February 9, 20052005-02-09
Abdul wrote:> Hello, > > I am using Linear feedback shift register(LFSR) to test Digital > filter(DF) because LFSR generate white noise and has a flat like spectrum. > Can anynody suggest when I pass white noise in DF, on what citeria should I > judge the filter (Device Under Test) is pass or fail ?? my filter is 3rd > order polyphase comb decimation filter with decimation factor of 256. > > I will appreciate if somebody pass hints or forword > suggestions. >That depends entirely on what your filter is supposed to do. Generally when you design something you start by clarifying what it is you want, then you go from there to a design, then you check that you design meets prediction by testing. So predict what your desired filter's output would be when using input from the LFSR, and check to see if your actual filter matches. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
"Abdul" <abdul_araheem@yahoo.com> wrote in message news:cucnlu$ha4$1@rzsun03.rrz.uni-hamburg.de...> Hello, > > I am using Linear feedback shift register(LFSR) to test Digital > filter(DF) because LFSR generate white noise and has a flat like spectrum. > Can anynody suggest when I pass white noise in DF, on what citeria shouldI> judge the filter (Device Under Test) is pass or fail ?? my filter is 3rd > order polyphase comb decimation filter with decimation factor of 256.If you designed the filter (using certain specs I'm sure) then you should know exactly what to test for (hint - the specs). The pass/fail criteria should really come from the designer of the filter - there isn't a universal rule. So for example, you might be looking for 3dB BW, stop band attenuation, transition BW, passband ripple etc. It's likely that you don't care about some of these params and that's ok - but it's for you to decide/know. Cheers Bhaskar> > I will appreciate if somebody pass hints or forword > suggestions. > > Thanks in advance. > > Abdul > >
