Hi, I would like to know how I can prove that the transfer function is an LTI system. with regards sudhir This message was sent using the Comp.DSP web interface on www.DSPRelated.com
proving LTI System
Started by ●February 14, 2005
Reply by ●February 14, 20052005-02-14
"kjsudhir" <kjsudhir@hotmail.com> wrote in message news:1111avlth4gaf9d@news.supernews.com...> Hi, > > I would like to know how I can prove that the transfer function is an LTI > system. > > with regards > sudhir > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.comHi khsudjir - if you can search through the archives of this newsgroup for threads started by Lucy you may be lucky enough to find the answer you are looking for. Best of Luck - Mike
"kjsudhir" <kjsudhir@hotmail.com> wrote in message news:1111avlth4gaf9d@news.supernews.com...> Hi, > > I would like to know how I can prove that the transfer function is an LTI > system. > > with regards > sudhir > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.comI believe that the transfer functions only exist for LTI systems.
Ken Davis wrote:> "kjsudhir" <kjsudhir@hotmail.com> wrote in message > news:1111avlth4gaf9d@news.supernews.com... > >>Hi, >> >>I would like to know how I can prove that the transfer function is an LTI >>system. >> >>with regards >>sudhir >> >>This message was sent using the Comp.DSP web interface on >>www.DSPRelated.com > > > I believe that the transfer functions only exist for LTI systems. > >But I've found that neophytes often use the term "transfer function" incorrectly. In fact, I'm not sure that the term isn't perfectly valid in other contexts to mean entirely different things. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
kjsudhir wrote:> Hi, > > I would like to know how I can prove that the transfer function is an LTI > system. > > with regards > sudhir > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.comHave you googled for "linear system"? A linear system, h, is one that, for any two inputs x1 and x2 and any two constants A1 and A2 follows the relation: if y1(t) = h(x1(t)) and y2(t) = h(x2(t)) then the system is linear if and only if h(A1*x1(t) + A2*x2(t)) = A1*y1(t) + A2*y2(t). A system is time invariant if for any time shift t_s and any signal x(t), if y(t) = h(x(t)) then h(x(t - t_s)) = y(t - t_s). So an LTI system is one that is both linear and time-invariant. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
