[OT] Scanning electron microscope display
Started by Richard Owlett ●February 19, 2005
This post inspired by recent posts by Jeff Miller.
My questions include
Does anyone have good links to descriptions of:
a. scanning electron microscopes in general?
    I've found Google searches for "SEM" or "scanning electron
    microscope" to be rather non-productive.
b. SEM detection and display schemes?
My only explicit qualification to ask questions is that
 >30 years ago, I was an instrument tech in a university setting.
I think my most basic question is why a fast 16 bit A/D?
When you have a CRT display, is more than 8 or 9 bits really useful?
A secondary question revolves around using scintillation(sp?) followed
by a photomultiplier.
Why not use a "channel electron multiplier" in count mode?
Also the problem of "image tearing" was mentioned in one post.
Would not that be alleviated by synchronizing display and offsetting of
scan?
I assume I've demonstrated my naivety ;]
Richard Owlett wrote:
> This post inspired by recent posts by Jeff Miller. > > My questions include > > Does anyone have good links to descriptions of: > a. scanning electron microscopes in general? > I've found Google searches for "SEM" or "scanning electron > microscope" to be rather non-productive.
Try google, it's too bad I didn't catch this question last night: I found some pretty good ones.
Most common detection is scintillator/PMT for secondary electrons. Two factors affect the contrast of a secondary electron image: topography (shadow) but also secondary emmision ratio varies depending on material: from about .5 to 2 secondarys per incident electron. Perhaps next most common is X-ray spectrometry, which is very good for distinguishing materials based on atomic number. Usually requires LN2 to reduce noise to point of getting a usefull signal. Often used for false colorizing. Back-scattered electron (BSE) detectors can also distinguish materials I think. Typically silicon. There are a few others. Traditionally, the images are displayed on a CRT with a long-decay phosphor. At high mags, refresh time can be 2 seconds or more: very annoying. Typically 2 CRT's are provided, one with a camera mount: ultimatley you don't _really_ get the "big picture" until your film is developed. It's critical to understand that in all cases, the CRT deflection coils are driven in sync with the SEM scanning coils: practically in parallel.
> > My only explicit qualification to ask questions is that > >30 years ago, I was an instrument tech in a university setting. > > I think my most basic question is why a fast 16 bit A/D?
I've posted to this group and cross-posted to several others asking about S/N of various media, we'll see what turns up. There's always the rationale that the extra information can be used for post-aquisition processing, which would bring up details that wouldn't otherwise be visible. What's that called: histogramtic edge enhancement, for example.
> > When you have a CRT display, is more than 8 or 9 bits really useful? > > A secondary question revolves around using scintillation(sp?) followed > by a photomultiplier. > > Why not use a "channel electron multiplier" in count mode?
Contamination. Typical vacuum in the chamber is 10-5 to 10-6, and traditionally it is very dirty with diffusion pump oil. This not only coats the surfaces of the EM but polymerizes on exposure to electron bombardment. Nevertheless, I have a strong background in high vaccum and am confident I can get a clean (ie: dominated by water vapor) vacuum of 10-8, and will be trying this very thing. That's one of the reasons I want a 16 bit A/D: having heard that the analog front ends of SEM's are generally accepted as having 72 dB SNR, I'd like some headroom because I want to figure out where the limitation is with expereiments like this.
> > Also the problem of "image tearing" was mentioned in one post. > Would not that be alleviated by synchronizing display and offsetting of > scan?
Traditionally this is no good because the refresh rate is so slow. But ultimatley there's no (built in) way to know the sample has moved, as the sample is moved mechanically.
> > I assume I've demonstrated my naivety ;] > >
Also look for information about homebrew STM, and try to find the company in Germany selling kits for about $1K euros. I'll definitely be building one "soon". I suppose this discussion belongs in sci.microscopy. They're lonely over there. -Jeff
jeff miller wrote:
> ultimatley you don't _really_ get the "big picture" until your film is > developed.
Polaroid?
> It's critical to understand that in all cases, the CRT deflection coils > are driven in sync with the SEM scanning coils: practically in parallel.
> ... There's always the > rationale that the extra information can be used for post-aquisition > processing, which would bring up details that wouldn't otherwise be > visible. What's that called: histogramtic edge enhancement, for example.
YES!
I doubt it.
> ... Typical vacuum in the chamber is 10-5 to 10-6, and > traditionally it is very dirty with diffusion pump oil.
Good Lord! Don't SEMs use cold caps and nitrogen traps? Even Freon coils from an old freezer is a great deal better than nothing. ... Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
jeff miller wrote:
> Richard Owlett wrote: > >> This post inspired by recent posts by Jeff Miller. >> >> My questions include >> >> Does anyone have good links to descriptions of: >> a. scanning electron microscopes in general? >> I've found Google searches for "SEM" or "scanning electron >> microscope" to be rather non-productive. > > > Try google, it's too bad I didn't catch this question last night: I > found some pretty good ones.
When I Googled I got many hits. It turned somewhat [while mangling a metaphor] into "not seeing forest for the leaves, let alone the trees". I suspect browsing sci.microscopy, as you suggested, may answer my underlying questions for which I don't have background to frame
> >> b. SEM detection and display schemes? > > [ snip description of what incident electrons produce ] > > Traditionally, the images are displayed on a CRT with a long-decay > phosphor. At high mags, refresh time can be 2 seconds or more: very > annoying. Typically 2 CRT's are provided, one with a camera mount: > ultimatley you don't _really_ get the "big picture" until your film is > developed. >
Which is the driving force behind going digital. You can see large high-resolution images in seconds rather than hours.
> It's critical to understand that in all cases, the CRT deflection coils > are driven in sync with the SEM scanning coils: practically in parallel. >
Understood.
>> >> My only explicit qualification to ask questions is that >> >30 years ago, I was an instrument tech in a university setting. >> >> I think my most basic question is why a fast 16 bit A/D? > > > I've posted to this group and cross-posted to several others asking > about S/N of various media, we'll see what turns up. There's always the > rationale that the extra information can be used for post-aquisition > processing, which would bring up details that wouldn't otherwise be > visible. What's that called: histogramtic edge enhancement, for example. > >> >> When you have a CRT display, is more than 8 or 9 bits really useful?
I'm following your thread on this topic.
>> >> A secondary question revolves around using scintillation(sp?) followed >> by a photomultiplier. >> >> Why not use a "channel electron multiplier" in count mode? > > > Contamination. Typical vacuum in the chamber is 10-5 to 10-6, and > traditionally it is very dirty with diffusion pump oil.
Brings back memories. We had a couple of old mass specs that my boss had retrofitted with ion pumps. The diffusion pumps were used essentially as roughing pumps. They had LN2 traps. But I don't recall if they were always used.
> [snip channel multiplier problems] >> Also the problem of "image tearing" was mentioned in one post. >> Would not that be alleviated by synchronizing display and offsetting >> of scan? > > > Traditionally this is no good because the refresh rate is so slow. But > ultimatley there's no (built in) way to know the sample has moved, as > the sample is moved mechanically.
Is that still a problem in current designs? I can think of a couple of ways to detect "when"/"how far" sample holder has moved, unaffected by platform being move mechanically with attendant "slop".
> Also look for information about homebrew STM, and try to find the > company in Germany selling kits for about $1K euros.
That sounds *CHEAP*! How much "infrastructure" ( pumps, electronics, etc ) does that include? That could be affordable to tech oriented high schools. In the 60's, when Varian introduced 60 MHz NMRs with permanent magnets, I thought that had impressive possibilities.
Not I. I've purchased a 100+ year old house which has undergone strange improvements.
> > I suppose this discussion belongs in sci.microscopy. They're lonely over > there. >
I may keep them company ;) Thanks for your reply.
Jerry Avins wrote:
>> ... Typical vacuum in the chamber is 10-5 to 10-6, and traditionally >> it is very dirty with diffusion pump oil. > > > Good Lord! Don't SEMs use cold caps and nitrogen traps? Even Freon coils > from an old freezer is a great deal better than nothing. >
How about trap chilled by cold tap water. Actually a somewhat serious question as I recall the heater of an oil diffusion pump is rather "warm" ;] [ may I claim out of the mouths of .... ? ]
> Jerry Avins wrote: > >>> ... Typical vacuum in the chamber is 10-5 to 10-6, and traditionally >>> it is very dirty with diffusion pump oil. >> >> >> >> Good Lord! Don't SEMs use cold caps and nitrogen traps? Even Freon >> coils from an old freezer is a great deal better than nothing. >> > > How about trap chilled by cold tap water. > Actually a somewhat serious question as I recall the heater of an oil > diffusion pump is rather "warm" ;] > > [ may I claim out of the mouths of .... ? ]
I used to keep a water-cooled cold cap right over a 10-inch (no typo) diffusion pump to keep heater radiation from quickly boiling off the nitrogen in the chevron-baffle oil trap. That was some pump! It could handle 10^-3 without choking, and it pulled a 20"-diameter, 24"-high working volume from 10^-4 to 2x10-^7 in about 4 minutes. The pressure never went above 3x10^5 when we were evaporating gold, tin, nickel, or even lead and chrome. It took 12 hours to get down to 10^-8, though. To answer your question, I suppose that ice water would reduce oil contamination in the work chamber. but it won't keep it low enough for many applications. Vapor pressure goes with something like the 4th to 7th power of absolute temperature. Liquid nitrogen is great. The lowest one can reach with commercial refrigerants is helpful. I used cold brine in my home-brew mirror-coating system. I can't say that it helped. "Why do you wear that amulet?" "To keep tigers away" "But there no tigers anywhere on this continent!" "See? it works!" Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
jeff miller wrote:
> > I suppose this discussion belongs in sci.microscopy. They're lonely over > there. > > -Jeff >
I couldn't find that group ;{
Jerry Avins wrote:
> jeff miller wrote: > > ... > >> ultimatley you don't _really_ get the "big picture" until your film is >> developed. > > > Polaroid? > >> It's critical to understand that in all cases, the CRT deflection >> coils are driven in sync with the SEM scanning coils: practically in >> parallel. > > > ... > >> ... There's always the rationale that the extra information can be >> used for post-aquisition processing, which would bring up details that >> wouldn't otherwise be visible. What's that called: histogramtic edge >> enhancement, for example. > > > YES! > >>> When you have a CRT display, is more than 8 or 9 bits really useful? > > > I doubt it. > >> ... Typical vacuum in the chamber is 10-5 to 10-6, and traditionally >> it is very dirty with diffusion pump oil. > > > Good Lord! Don't SEMs use cold caps and nitrogen traps? Even Freon coils > from an old freezer is a great deal better than nothing. > > ... > > Jerry
Many use turbos these days, though vibration can be a problem. I've never seen a trap on an SEM, but I'm sure it's done for special purposes. The real problem is they never bake out. But it seems the vacuum just isn't a problem. All the rage these days are scopes that operate at 10-1 to 10-3 range. They have at least one pump on the column near the filament, often several pumps one between each aperture, so that the vacuum is good near the cathode (filament) which is all that really matters. -Jeff
> jeff miller wrote: > >> Richard Owlett wrote: >> >>> This post inspired by recent posts by Jeff Miller. >>> >>> My questions include >>> >>> Does anyone have good links to descriptions of: >>> a. scanning electron microscopes in general? >>> I've found Google searches for "SEM" or "scanning electron >>> microscope" to be rather non-productive. >> >> >> >> Try google, it's too bad I didn't catch this question last night: I >> found some pretty good ones. > > > When I Googled I got many hits. It turned somewhat [while mangling a > metaphor] into "not seeing forest for the leaves, let alone the trees". > > I suspect browsing sci.microscopy, as you suggested, may answer my > underlying questions for which I don't have background to frame > > > >> >>> b. SEM detection and display schemes? >> >> >> [ snip description of what incident electrons produce ] >> >> Traditionally, the images are displayed on a CRT with a long-decay >> phosphor. At high mags, refresh time can be 2 seconds or more: very >> annoying. Typically 2 CRT's are provided, one with a camera mount: >> ultimatley you don't _really_ get the "big picture" until your film is >> developed. >> > > Which is the driving force behind going digital. You can see large > high-resolution images in seconds rather than hours. > >> It's critical to understand that in all cases, the CRT deflection >> coils are driven in sync with the SEM scanning coils: practically in >> parallel. >> > > Understood. > >>> >>> My only explicit qualification to ask questions is that >>> >30 years ago, I was an instrument tech in a university setting. >>> >>> I think my most basic question is why a fast 16 bit A/D? >> >> >> >> I've posted to this group and cross-posted to several others asking >> about S/N of various media, we'll see what turns up. There's always >> the rationale that the extra information can be used for >> post-aquisition processing, which would bring up details that wouldn't >> otherwise be visible. What's that called: histogramtic edge >> enhancement, for example. >> >>> >>> When you have a CRT display, is more than 8 or 9 bits really useful? > > > I'm following your thread on this topic. > >>> >>> A secondary question revolves around using scintillation(sp?) >>> followed by a photomultiplier. >>> >>> Why not use a "channel electron multiplier" in count mode? >> >> >> >> Contamination. Typical vacuum in the chamber is 10-5 to 10-6, and >> traditionally it is very dirty with diffusion pump oil. > > > Brings back memories. We had a couple of old mass specs that my boss had > retrofitted with ion pumps. The diffusion pumps were used essentially as > roughing pumps. They had LN2 traps. But I don't recall if they were > always used. > > > >> [snip channel multiplier problems] >> >>> Also the problem of "image tearing" was mentioned in one post. >>> Would not that be alleviated by synchronizing display and offsetting >>> of scan? >> >> >> >> Traditionally this is no good because the refresh rate is so slow. But >> ultimatley there's no (built in) way to know the sample has moved, as >> the sample is moved mechanically. > > > Is that still a problem in current designs? > I can think of a couple of ways to detect "when"/"how far" sample holder > has moved, unaffected by platform being move mechanically with attendant > "slop". > > >> Also look for information about homebrew STM, and try to find the >> company in Germany selling kits for about $1K euros. > > > That sounds *CHEAP*! > How much "infrastructure" ( pumps, electronics, etc ) does that include? > That could be affordable to tech oriented high schools. In the 60's, > when Varian introduced 60 MHz NMRs with permanent magnets, I thought > that had impressive possibilities. > >> I'll definitely be building one "soon". > > > Not I. I've purchased a 100+ year old house which has undergone strange > improvements. > > >> >> I suppose this discussion belongs in sci.microscopy. They're lonely >> over there. >> > > I may keep them company ;) > > > Thanks for your reply.
Beauty part is you don't need any infrastructure for an atomic force microscope. They operate mechanically, and at atmospheric pressrue. I've got a house like that, 1884. It deos suffer for my hobbies. -Jeff
jeff miller wrote:
> Many use turbos these days, though vibration can be a problem. I've > never seen a trap on an SEM, but I'm sure it's done for special > purposes. The real problem is they never bake out.
My set-up was a stack: pump, cold cap, nitrogen cold-trap, slide valve, working chamber. With the valve closed and steam in the cold trap, it baked out just fine. I only needed to do that when it had gotten exposed to air. Even when the chevrons were oily enough to drip at room temperature, there was no problem with oil vapor coming off them when cold. Of course, we tried hard to avoid ever going higher than roughing vacuum in the pump stack. I had valves at both ends of it. We vented the working chamber with helium before opening it to the air. That was supposed to minimize adsorption of nasties.
> But it seems the vacuum just isn't a problem. All the rage these days > are scopes that operate at 10-1 to 10-3 range. They have at least one > pump on the column near the filament, often several pumps one between > each aperture, so that the vacuum is good near the cathode (filament) > which is all that really matters.
A lot of processes get by on minimum vacuum. Before I knew better, I made a "vacuum" "tube" without an envelope. We had an electric hot plate with a nichrome coil heater in an open ceramic labyrinth. The top of the coil nearly touched the bottom of the pot. (Can you imagine such a thing on the market today? We never had trouble with it.) I laid a piece of brass screen wire over it for a grid (so that's where the name comes from!), some glass glass beads on that to make an insulating gap, and a metal pie plate (so that's where the name comes from!) with water in it so it wouldn't warp, and with 700 volts on the plate, made a Hartley oscillator work. An eighth inch at one atmosphere is much more than an electron's mean free path, but that's evidently not the whole story. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
