"Max Hauser" <maxREMOVE@THIStdl.com> wrote in message news:111oecet5h9b407@corp.supernews.com...> "Allan Herriman" >> > > Neglecting novelty items like recursive FIR implementations, there are > other famous nonrecursive structures that also realize Finite Impulse > Responses but lack the transversal (tapped-delay) structure. A parallel > set of delay lines of different lengths or delays, each weighted at their > input or output, and finally summed, is such a structure. (It has been > useful in some delay-line technologies that had constraints, for example > certain CCD technologies circa the 1970s.) > > -- Max HauserIn the olden days when delay lines of any appreciable length were expensive we used a relatively wideband torsional wire acoustic delay line over the range 100kHz to 1MHz. The line wasn't tapped. We wanted to delay signals up to 100kHz or so and create a FIR filter sort of response. So, we used frequency domain multiplexing on the line and used the line multiple times: output at baseband at t first pass at 150kHz downtranslate a tap out at t+T uptranslate for: second pass at 300kHz, downtranslate a tap out at t+2T upstranslate for: third pass at 450kHz, downtranslate a tap out at t+3T End result, one delay element of length T for a FIR filter of length 4. So, in a way, these were different length delay lines in parallel even though the physical line was the same one. Note that this isn't recursive because all the signal paths are independent / not added - well they are added in the delay line but separated in frequency so the end result is not recursive. Fred
Definition for transversal equalizers
Started by ●February 20, 2005
Reply by ●February 24, 20052005-02-24
"Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in message news:0fednQVKW-v_DoPfRVn-og@centurytel.net...> > "Max Hauser" <maxREMOVE@THIStdl.com> wrote in message > news:111oecet5h9b407@corp.supernews.com... >> "Allan Herriman" >>> >> >> Neglecting novelty items like recursive FIR implementations, there are >> other famous nonrecursive structures that also realize Finite Impulse >> Responses but lack the transversal (tapped-delay) structure. A parallel >> set of delay lines of different lengths or delays, each weighted at their >> input or output, and finally summed, is such a structure. (It has been >> useful in some delay-line technologies that had constraints, for example >> certain CCD technologies circa the 1970s.) >> >> -- Max Hauser > > In the olden days when delay lines of any appreciable length were > expensive we used a relatively wideband torsional wire acoustic delay line > over the range 100kHz to 1MHz. The line wasn't tapped. We wanted to > delay signals up to 100kHz or so and create a FIR filter sort of response. > So, we used frequency domain multiplexing on the line and used the line > multiple times: > > output at baseband at t > first pass at 150kHz downtranslate a tap out at t+T > uptranslate for: > second pass at 300kHz, downtranslate a tap out at t+2T > upstranslate for: > third pass at 450kHz, downtranslate a tap out at t+3T > > End result, one delay element of length T for a FIR filter of length 4. > So, in a way, these were different length delay lines in parallel even > though the physical line was the same one. > Note that this isn't recursive because all the signal paths are > independent / not added - well they are added in the delay line but > separated in frequency so the end result is not recursive. > > FredWell, on second thought, it seems that this implementation was more serial than parallel. Fred
