Hi! I have an s domain transfer function H(s) and trying to determine the response of the system to the unit step function. I tried this: Y(s) = H(s) * X(s) = H(s) * Hc(s) = H(s)/s (* is product, not convolution) But the frequency response using freqs(Y(s)) is wrong. (I bet it must be obvious to someone why). The frequency spectrum should a have a value at DC (omega*j = 0) but in this case it is undefined. What is going wrong? Thanks! Atmapuri.
Frequency response function...
Started by ●February 24, 2005
Reply by ●February 25, 20052005-02-25
Hi! Found the solution. The frequency response should be evaluted at some s = alfa + wj where alfa is different from zero. By performing IFFT on the sampled frequency response, the time series then has to be compensated by multiplying it with e^(alfa*t) to obtain the true step response. Thanks! Atmapuri "Atmapuri" <janez.makovsek@usa.net> wrote in message news:aKlTd.9507$F6.1836303@news.siol.net...> Hi! > > I have an s domain transfer function H(s) > and trying to determine the response of the system > to the unit step function. > > I tried this: > > Y(s) = H(s) * X(s) = H(s) * Hc(s) = H(s)/s > > (* is product, not convolution) > > But the frequency response using freqs(Y(s)) is wrong. > (I bet it must be obvious to someone why). The > frequency spectrum should a have a value at DC (omega*j = 0) > but in this case it is undefined. > > What is going wrong? > > Thanks! > Atmapuri. > >
Reply by ●February 26, 20052005-02-26
"Atmapuri" <janez.makovsek@usa.net> writes:> The frequency response should be evaluted > at some s = alfa + wj where alfa is different from zero."What's it all about, Alfa?" -- % Randy Yates % "Remember the good old 1980's, when %% Fuquay-Varina, NC % things were so uncomplicated?" %%% 919-577-9882 % 'Ticket To The Moon' %%%% <yates@ieee.org> % *Time*, Electric Light Orchestra http://home.earthlink.net/~yatescr
