Hello, everybody. I'm just a beginner. I use ADSP-21065L SHARC EZ-KIT Lite where is codec AD1819A. The default sampling rate is 48 kHz and I need to change it. But it's so difficult for me to do it. I would like to change it for example from 48 kHz to 8 kHz. Please help me if you can. Thank you very much Marek The code: /*-------------------------------------------------------------------------- INCLUDES --------------------------------------------------------------------------*/ #include <def21060.h> #include <21065l.h> #include <signal.h> #include <macros.h> #include <math.h> #include <filters.h> #include <ezkit/1819regs.h> /*-------------------------------------------------------------------------- CONSTANT & MACRO DEFINITIONS --------------------------------------------------------------------------*/ /* Codec tag word to send out left and right samples */ #define DOUT_TAG 0x9800 /* Codec tag word to send out address and data slots */ #define REGOUT_TAG 0xe000 /* This is the codec register setting for line input on both channels */ #define SOURCE_IS_LINE 0x0404 #define SOURCE_IS_MIC 0 /* Codec addreses */ #define SOURCE_ADDR 0x1a00 #define RECGAIN_ADDR 0x1c00 #define CODEC_ISR_VECT 0X9001 /*-------------------------------------------------------------------------- EXTERNAL DECLARATIONS --------------------------------------------------------------------------*/ /* These compile to the same addresses as in the kernel if the .ldf is set up correctly */ extern volatile int user_tx_buf[6]; extern volatile int user_tx_ready; extern volatile int user_rx_buf[6]; extern volatile int user_rx_ready; /*-------------------------------------------------------------------------- FUNCTION PROTOTYPES --------------------------------------------------------------------------*/ void init_codec(void); void main (void); /**************************************************************************** ** ** Procedure: main() ** ** Arguments: None ** ** Returns: None ** ** Desc: main code ** ****************************************************************************/ void main ( void ) { float filter_input; // Initialize some codec registers. init_codec(); // Loop forever. user_tx_ready = 0; for(;;) { user_rx_ready = 1; idle(); while (user_rx_ready); while (user_tx_ready); // Get sample from Codec or random noise. filter_input = user_rx_buf[RIGHT_CHNL]; // Output. user_tx_buf[RIGHT_CHNL] = filter_input; user_tx_buf[LEFT_CHANL] = user_tx_buf[RIGHT_CHNL]; user_tx_buf[TAG] = DOUT_TAG; user_tx_ready = 1; }; } /**************************************************************************** ** ** Procedure: init_codec() ** ** Arguments: None ** ** Returns: None ** ** Desc: Unmasks the sport1 interrupt and uses the kernel isr ** to initialize the codec input source and record gain. ** ****************************************************************************/ void init_codec( void ) { asm("#include <def21065l.h>"); interrupt(SIG_SPT1I,(void (*)(int))CODEC_ISR_VECT); asm("BIT SET IMASK SPT1I;"); /* unmasks sport interrupt */ /* Set source to LINE */ user_tx_buf[TAG] = REGOUT_TAG; user_tx_buf[ADDR] = SOURCE_ADDR; user_tx_buf[DATA] = SOURCE_IS_LINE; user_tx_ready = 1; /* Tell the isr that txbuf is ready */ idle(); idle(); /* Set record gain */ user_tx_buf[TAG] = REGOUT_TAG; user_tx_buf[ADDR] = RECGAIN_ADDR; user_tx_buf[DATA] = 0; user_tx_ready = 1; /* Tell the isr that txbuf is ready */ idle(); idle(); return; } **************************************************************************** ** $TITLE: BUFFERS.ASM$ ** BUFFERS.ASM ** --------- ** Links variables into the same locations the kernel uses so that ** the demo can talk to the kernel to use its codec isr or output SWI ** ** ****************************************************************************/ GLOBAL _user_tx_buf; GLOBAL _user_tx_ready; GLOBAL _user_rx_buf; GLOBAL _user_rx_ready; GLOBAL _user_data_out_ptr; GLOBAL _user_num_data; GLOBAL _user_data_type; SEGMENT/DM seg_bnk3; // make the buffers line up the same as in the kernel var _user_tx_buf[6]; var _user_tx_ready; var _user_rx_buf[6]; var _user_rx_ready; var _user_data_out_ptr; //pointer to data to send to the host var _user_num_data; //says how many data items there are var _user_data_type; // 0 = ascii, 1 = decimal, 2 = hex ENDSEG; /* This file contains the interrupt table for the ADSP-21065L */ /* When the C program exits either by returning from main() or by an */ /* explicit or implicit call to exit(), control will transfer to the */ /* label ___lib_prog_term. Currently, the ___lib_prog_term label is */ /* defined at the end of the reset vector as an IDLE instruction. */ /* If your application needs to perform some operation AFTER the C */ /* program has finished executing, remove the ___lib_prog_term label */ /* from the runtime header, and place it at the beginning of your */ /* code. */ /************************************************************************** New file created June 2001. The run-time model states that i0 can't be used in the run-time libs. Use i2 for interrupt handling instead. **************************************************************************/ #define KERNEL_UART_ISR 0x9000 #define KERNEL_CODEC_ISR 0x9001 #define KERNEL_SWI3_ISR 0x9002 #define __ADSP21065L__ #undef __ADSP21020__ #include <ezkit/sig_glob.h> #define INT(irp) \ BIT CLR MODE1 0x1000; /*Disable interrupts */ \ JUMP ___z3_int_determiner(DB); /*jmp to finish setting up */ \ DM(I7,M7)=R0; /*Save r0 (scratch dreg) */ \ R0=SIGMASK(SIG_##irp); /*Base of int table */ #define RESERVED_INTERRUPT NOP;NOP;NOP;NOP GLOBAL ___lib_prog_term; /* Termination address */ GLOBAL __done_execution; EXTERN ___lib_setup_c; EXTERN ___lib_int_table; EXTERN _main; SEGMENT/PM seg_rth; /* Runtime header segment */ RESERVED_INTERRUPT; ___lib_RSTI: NOP; /* Not really executed */ JUMP ___lib_start; NOP; NOP; #ifdef __ADSP21160__ ___lib_IICDI: INT(IICDI) ; /* Access to illegal IOP space */ #else RESERVED_INTERRUPT; #endif ___lib_SOVFI: INT(SOVF); /* status/loop/PC stack overflow */ ___lib_TMZHI: INT(TMZ0); /* high priority timer */ ___lib_VIRPTI: INT(VIRPTI); /* external interrupts */ ___lib_IRQ2I: INT(IRQ2); ___lib_IRQ1I: INT(IRQ1); // IRQ0 // This vector is used for the UART. // It is written during power-on and protected from over-writing // by rewriting it after writing data to memory (so this declaration // is redundant, but a good reminder). // Over-writing this vector will stop the kernel. // The user may over-write it from his/her code - but will loose // the capability to communicate over the RS-232 interface. // IRQ0, IRPTL bit 8, Vector 0x20 ___lib_IRQ0I: JUMP KERNEL_UART_ISR; RTI; NOP; RTI; RESERVED_INTERRUPT; ___lib_SPR0I: INT(SPR0I); /* serial port DMA channel interrupts */ ___lib_SPR1I: INT(SPR1I); ___lib_SPT0I: INT(SPT0I); // If you wish to use the kernel's codec services, do not write // over the following vector ___lib_SPT1I: JUMP KERNEL_CODEC_ISR; RTI; RTI; RTI; #ifndef __ADSP21160__ #ifdef __ADSP21065L__ RESERVED_INTERRUPT; RESERVED_INTERRUPT; #else ___lib_LP2I: INT(LP2I); /* link port DMA channel interrupts */ ___lib_LP3I: INT(LP3I); #endif #else ___lib_LP0I: INT(LP0I); /* link port DMA channel 4 */ ___lib_LP1I: INT(LP1I); /* link port DMA channel 5 */ ___lib_LP2I: INT(LP2I); /* link port DMA channel interrupts */ ___lib_LP3I: INT(LP3I); ___lib_LP4I: INT(LP4I); /* link port DMA channel 8 */ ___lib_LP5I: INT(LP5I); /* link port DMA channel 9 */ #endif ___lib_EP0I: INT(EP0I); /* ext port DMA channel interrupts */ ___lib_EP1I: INT(EP1I); #ifndef __ADSP21065L__ ___lib_EP2I: INT(EP2I); ___lib_EP3I: INT(EP3I); ___lib_LSRQ: INT(LSRQ); /* link service request */ #else RESERVED_INTERRUPT; RESERVED_INTERRUPT; RESERVED_INTERRUPT; #endif ___lib_CB7I: INT(CB7); /* circular buffer #7 overflow */ ___lib_CB15I: INT(CB15); /* circular buffer #15 overflow */ ___lib_TMZLI: INT(TMZ); /* low priority timer */ ___lib_FIXI: INT(FIX); /* fixed point overflow */ ___lib_FLTOI: INT(FLTO); /* floating point overflow */ ___lib_FLTUI: INT(FLTU); /* floating point underflow */ ___lib_FLTII: INT(FLTI); /* floating point invalid */ ___lib_SFT0I: INT(USR0); /* user interrupts 0..3 */ ___lib_SFT1I: INT(USR1); ___lib_SFT2I: INT(USR2); // If you wish to use the kernel's host output services, do not write // over the following vector ___lib_SFT3I: JUMP KERNEL_SWI3_ISR; RTI; RTI; RTI; ___z3_int_determiner: DM(I7,M7)=R1; R1=I2; DM(I7,M7)=R1; /* Save I2 (scratch reg) */ I2=R0; DM(I7,M7)=I13; /* Save I13 (scratch reg) */ I13=DM(5,I2); /* get disp to jump to */ JUMP (M13, I13) (DB); /* Jump to dispatcher */ BIT SET MODE2 0x80000; /* Freeze cache */ I13=DM(2,I2); /* rd handler addr (base+2) */ /* Note: It's okay to use PM in getting the above values b'cse z3 has a */ /* linear memory. Therefore dm and pm are the same and we can use either.*/ ___lib_start: CALL ___lib_setup_c; /* Setup C runtime model */ #ifdef MAIN_RTS CJUMP _main (DB); /* Begin C program */ DM(I7,M7)=R2; DM(I7,M7)=PC; #else JUMP _main; /* Begin C program */ #endif /* Setting the __done_execution flag indicates that this processor is */ /* finished executing, for the benefit of anyone who may be watching. */ ___lib_prog_term: PM(__done_execution)=PC; IDLE; JUMP ___lib_prog_term; /* Stay put */ VAR __done_execution = 0; ENDSEG; This message was sent using the Comp.DSP web interface on www.DSPRelated.com
The changing of sampling rate of AD1819A
Started by ●February 25, 2005
Reply by ●February 25, 20052005-02-25
Marek wrote:> Hello, everybody. I'm just a beginner. I use ADSP-21065L SHARC EZ-KIT Lite > where is codec AD1819A. The default sampling rate is 48 kHz and I need to > change it. But it's so difficult for me to do it. I would like to change > it for example from 48 kHz to 8 kHz. Please help me if you can. > Thank you very much > Marek... I don't have the manual handy, nor am I sure it can be done (but I'd be surprised if not). As a quick fix until something better comes along, you can simply use one sample out of six and throw the other five away. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Marek... This the register addresses for the audio codec are defined in the section "CONSTANT & MACRO DEFINITIONS". You will want to add the following values to that section: ********************** #define SAMPLE_RATE_8KHZ 0x401F #define SAMPLE_RATE0_ADDR 0x7800 #define SAMPLE_RATE1_ADDR 0x7A00 ********************** 78h and 7Ah are the addresses for the registers that control the sample rates. The setting for 8kHz is 8000 in hex, or 1F40 (swapped in the SHARC so its 401F). This will define your contants. Next, in the procedure init_codec(), you need to send the correct commands to initialize the codec: *********************** /* Set Sample Rate 0 to 8kHz */ user_tx_buf[TAG] = REGOUT_TAG; user_tx_buf[ADDR] = SAMPLE_RATE0_ADDR; user_tx_buf[DATA] = SAMPLE_RATE_8KHZ; user_tx_ready = 1; /* Tell the isr that txbuf is ready */ idle(); idle(); /* Set Sample Rate 1 to 8kHz */ user_tx_buf[TAG] = REGOUT_TAG; user_tx_buf[ADDR] = SAMPLE_RATE1_ADDR; user_tx_buf[DATA] = SAMPLE_RATE_8KHZ; user_tx_ready = 1; /* Tell the isr that txbuf is ready */ idle(); idle(); *********************** I haven't worked with the SHARC in 3 years or so, and this is mostly from memory, so it may not be exactly right. If you need any more reference, check out this link: http://www.analog.com/UploadedFiles/Obsolete_Data_Sheets/1809887AD1819A.pdf Good Luck! - CyRex
Hi Guys, Beware that it is not simply changing the register what works for this particular CODEC. There was an extremely interesting document in ADI website title "Interfacing the ADSP21065L SHARC DSP to the AD1819A AC-97 Soundport Codec", which you can get from here: http://www.analog.com/UploadedFiles/Application_Notes/250806129AD1819A_21065L.pdf It very thoroughly explains how to do it. I have a C version of this. If you want it, I'd be glad to share it. Please write to me at soporte@sanjaac.com, and I will send it in a few hours (I don't have it right here). Regards, JaaC CyRex wrote:> Marek... > > This the register addresses for the audio codec are defined in the > section "CONSTANT & MACRO DEFINITIONS". You will want to add the > following values to that section: > > ********************** > #define SAMPLE_RATE_8KHZ 0x401F > > #define SAMPLE_RATE0_ADDR 0x7800 > #define SAMPLE_RATE1_ADDR 0x7A00 > ********************** > > 78h and 7Ah are the addresses for the registers that control thesample> rates. The setting for 8kHz is 8000 in hex, or 1F40 (swapped in the > SHARC so its 401F). This will define your contants. > > Next, in the procedure init_codec(), you need to send the correct > commands to initialize the codec: > > *********************** > /* Set Sample Rate 0 to 8kHz */ > user_tx_buf[TAG] = REGOUT_TAG; > user_tx_buf[ADDR] = SAMPLE_RATE0_ADDR; > user_tx_buf[DATA] = SAMPLE_RATE_8KHZ; > user_tx_ready = 1; /* Tell the isr that txbuf isready> */ > idle(); > idle(); > > /* Set Sample Rate 1 to 8kHz */ > user_tx_buf[TAG] = REGOUT_TAG; > user_tx_buf[ADDR] = SAMPLE_RATE1_ADDR; > user_tx_buf[DATA] = SAMPLE_RATE_8KHZ; > user_tx_ready = 1; /* Tell the isr that txbuf isready> */ > idle(); > idle(); > *********************** > > I haven't worked with the SHARC in 3 years or so, and this is mostly > from memory, so it may not be exactly right. If you need any more > reference, check out this link: > >http://www.analog.com/UploadedFiles/Obsolete_Data_Sheets/1809887AD1819A.pdf> > Good Luck! > - CyRex
True, there are some other things than need to be done so that the SHARC interprets and stores/processes the input signals correctly when the sample rate is not 48kHz, but changing the register is what will actually set the sample rate of the codec. How the SHARC deals with the incoming samples is a different story... -CyRex
