Sound Localization
Started by Karthik Ravikanti March 1, 2005
Hi again,
Thanx for the responses guys....but I found the problem!!!
The dual mono female input jack I was using was the culprit.
I tested it with a multimeter and the channels were shorted...I
replaced it with one stereo jack....and everything is just workin as it
should....thanx again..
Karthik Ravikanti
http://students.iiit.net/~karthik_ravikanti
Let there be Sound!!!
Thanks for the follow-up.  Glad to know the problem is solved.  It's often the
simple things!  Having strong trouble-shooting skills will take you far in
figuring out these types of problems.  A good general strategy is to simplify,
partition, and isolate the problem.  For example, if there are 3 possible
sources of a problem, think of tests that could prove/disprove each one
individually.
"Karthik Ravikanti" <karthik.ravikanti@gmail.com> wrote in message
news:1109781100.592571.246300@f14g2000cwb.googlegroups.com...
> Hi again, > > Thanx for the responses guys....but I found the problem!!! > > The dual mono female input jack I was using was the culprit. > I tested it with a multimeter and the channels were shorted...I > replaced it with one stereo jack....and everything is just workin as it > should....thanx again.. > > > Karthik Ravikanti > > http://students.iiit.net/~karthik_ravikanti > > ---- > > Let there be Sound!!! >
Jon Harris wrote:
> Thanks for the follow-up. Glad to know the problem is solved. It's often the > simple things! Having strong trouble-shooting skills will take you far in > figuring out these types of problems. A good general strategy is to simplify, > partition, and isolate the problem. For example, if there are 3 possible > sources of a problem, think of tests that could prove/disprove each one > individually.
An do the simplest ones first, even if you think they're less likely to find the trouble. They sometimes will (or lead you to it) and they don't cost much. ... Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
