I just did a survey of the indices of a number of really good texts I've got laying around here, and there's scant little info regarding Hadamard Transforms that I've been able to find. The general idea of the HT (not to be confused with the Hartley Transform) is pretty basic, but I'm interested in a reference that talks a bit about interpreting the results. So far I'm at a bit of a loss as to what practical use the thing has or what the results mean. I've found treatments that explain what it is (which is simple enough), but very little on practical applications. Any ideas amont the collective wisdom out there? Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
References on Interpreting Hadamard Transform results
Started by ●March 3, 2005
Reply by ●March 3, 20052005-03-03
Eric Jacobsen wrote:> I just did a survey of the indices of a number of really good texts > I've got laying around here, and there's scant little info regarding > Hadamard Transforms that I've been able to find. > > The general idea of the HT (not to be confused with the Hartley > Transform) is pretty basic, but I'm interested in a reference that > talks a bit about interpreting the results. So far I'm at a bit of a > loss as to what practical use the thing has or what the results mean. > I've found treatments that explain what it is (which is simple > enough), but very little on practical applications. > > Any ideas amont the collective wisdom out there? > > Eric Jacobsen > Minister of Algorithms, Intel Corp. > My opinions may not be Intel's opinions. > http://www.ericjacobsen.orgThe discrete Hadamard transform of an image is a two-valued (it uses Walsh functions) hologram of the image. I never figured out what wavelength recreates the image. But then, isn't a 2-D Fourier transform a diffraction pattern? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●March 4, 20052005-03-04
eric.jacobsen@ieee.org (Eric Jacobsen) writes:> I just did a survey of the indices of a number of really good texts > I've got laying around here, and there's scant little info regarding > Hadamard Transforms that I've been able to find. > > The general idea of the HT (not to be confused with the Hartley > Transform) is pretty basic, but I'm interested in a reference that > talks a bit about interpreting the results. So far I'm at a bit of a > loss as to what practical use the thing has or what the results mean. > I've found treatments that explain what it is (which is simple > enough), but very little on practical applications. > > Any ideas amont the collective wisdom out there?Hi Eric, Even Eric Weisstein's "CRC Concise Encyclopedia of Mathematics," which usually has a prolific amount of information and references on such topics, simply states, A Fast Fourier Transform-like algorithm which produces a hologram of an image. There were no references. I could also find no information on the subject in either Poularikas' "The Transforms and Applications Handbook" or Bracewell's "The Fourier Transform and its Applications." Good luck! -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
"Randy Yates" <randy.yates@sonyericsson.com> wrote in message news:xxpsm3ba8in.fsf@usrts005.corpusers.net...> eric.jacobsen@ieee.org (Eric Jacobsen) writes: > >> I just did a survey of the indices of a number of really good texts >> I've got laying around here, and there's scant little info regarding >> Hadamard Transforms that I've been able to find. >> >> The general idea of the HT (not to be confused with the Hartley >> Transform) is pretty basic, but I'm interested in a reference that >> talks a bit about interpreting the results. So far I'm at a bit of a >> loss as to what practical use the thing has or what the results mean. >> I've found treatments that explain what it is (which is simple >> enough), but very little on practical applications. >> >> Any ideas amont the collective wisdom out there? > > Hi Eric, > > Even Eric Weisstein's "CRC Concise Encyclopedia of Mathematics," which > usually has a prolific amount of information and references on such > topics, > simply states, > > A Fast Fourier Transform-like algorithm which produces a hologram of an > image. > > There were no references. > > I could also find no information on the subject in either Poularikas' > "The Transforms and Applications Handbook" or Bracewell's "The Fourier > Transform and its Applications." > > Good luck! > -- > Randy Yates > Sony Ericsson Mobile Communications > Research Triangle Park, NC, USA > randy.yates@sonyericsson.com, 919-472-1124Hi Eric, The only thing I can remember ever using it for was in deconstructing a set of direct sequence spread spectrum codes into different nutually orthogonal sub-channels for a synchronous spread-spectrum multiple access scheme. Best of Luck - Mike
"Eric Jacobsen" <eric.jacobsen@ieee.org> wrote in message news:42278b35.322140484@news.west.cox.net...>I just did a survey of the indices of a number of really good texts > I've got laying around here, and there's scant little info regarding > Hadamard Transforms that I've been able to find. > > The general idea of the HT (not to be confused with the Hartley > Transform) is pretty basic, but I'm interested in a reference that > talks a bit about interpreting the results. So far I'm at a bit of a > loss as to what practical use the thing has or what the results mean. > I've found treatments that explain what it is (which is simple > enough), but very little on practical applications.Suppose that we have a sequence x[k] where k ranges from 0 to 2^m - 1. We can regard this as a function that maps the set {0, 1, ... , 2^m - 1} to real (or complex) numbers. Then the DFT supports cyclic convolution: the DFT of the cyclic convolution sequence z[n] where z[n] = sum from k = 0 to 2^m - 1 of x[k].y[n-k] with indices taken modulo 2^m is (ignoring multiplicative constants) the term-by-term product of the DFTs of x[k] and y[k]. But, we could also look at the integers {0, 1, ... , 2^m - 1} as m-bit binary vectors that comprise the field GF(2^m), so that x[a] can also be thought of as a function that maps the elements of GF(2^m) to real (or complex) numbers. Note that a is an m-bit vector regarded as an element of GF(2^m). Then, the Hadamard transform supports what is sometimes called the Poisson convolution: the Hadamard transform of w[b] = sum over all a in GF(2^m) x[a].y[b-a] is (ignoring multiplicative constants) the term-by-term product of the Hadamard transforms of x[a] and y[a]. Notice that b-a = b.XOR.a since addition and subtraction are the same operation in GF(2^m). What is the Hadamard transform useful for? Well, I have on my bookshelf a whole book titled Hadamard Transform Optics (by N. J. A. Sloane and M. Harwit, Academic Press 1979) which shows how the Hadamard transform is used to design better imaging spectrometers. I would suspect that the book is no longer in print.... One particular application of more direct interest to comp.dsp denizens is the following. Suppose we have a maximum-length linear feedback shift register sequence of period 2^m - 1 and wish to compute the periodic crosscorrelation between this sequence and some other sequence x[k] of period 2^m -1. No big deal: take the DFTs, multiply term by term (conjugating one term), and then the inverse DFT. Of course, this works better if we have a good FFT algorithm for length 2^m-1. Alternatively, if we *permute* the sequence x[k] appropriately, then the Hadamard transform of the permuted sequence is, with appropriate multiplicative constants and re-ordering (bit shuffling), the crosscorrelation between the maximum length sequence and x[k]. Is it worth it? Sure. there is a fast Hadamard transform algorithm that uses only m.2^m additions/subtractions and *no* multiplications which saves a lot of computation as compared to three DFTs, fast or not. This idea was used in the Mariner 9 mission's communications systems about 35 years ago. Some details (and circuit diagrams of the Green machine that implemented the fast Hadamard transform) algorithm are in Chapter 14 of the well-known MacWilliams and Sloane text on error-control codes. Hope this helps.
On Fri, 4 Mar 2005 13:40:03 -0600, "Dilip V. Sarwate" <sarwate@YouEyeYouSee.edu> wrote:>One particular application of more direct interest to comp.dsp denizens >is the following. Suppose we have a maximum-length linear feedback >shift register sequence of period 2^m - 1 and wish to compute the >periodic crosscorrelation between this sequence and some other sequence >x[k] of period 2^m -1. No big deal: take the DFTs, multiply term by >term (conjugating one term), and then the inverse DFT. Of course, this >works better if we have a good FFT algorithm for length 2^m-1. >Alternatively, if we *permute* the sequence x[k] appropriately, then >the Hadamard transform of the permuted sequence is, with appropriate >multiplicative constants and re-ordering (bit shuffling), the >crosscorrelation >between the maximum length sequence and x[k]. Is it worth it? Sure. >there is a fast Hadamard transform algorithm that uses only m.2^m >additions/subtractions and *no* multiplications which saves a lot of >computation as compared to three DFTs, fast or not. This idea was used >in the Mariner 9 mission's communications systems about 35 years ago. >Some details (and circuit diagrams of the Green machine that implemented >the fast Hadamard transform) algorithm are in Chapter 14 of the well-known >MacWilliams and Sloane text on error-control codes. > >Hope this helps.Dilip, Thanks for the note. I can easily see how enough scrambling of the HT basis functions would provide a crosscorrelation of an MLLF sequence with an input sequence since the kernels of the HT (and most transforms) are dot products. That seems to me to be just redefining a series of carefully arranged dot products as a transform, which can easily turn into a case of semantic argument about what is or is not a transform. This assumes I've understood you correctly, though, which may not be the case. I'm just imagining the permuting and bit shuffling you were describing could perhaps also be accomplished by fiddling with the basis function. In any case, I can easily see the computational advantage, though. For the Mariner 9 case, then, I'm assuming it was used for either synchronization (the correlation function again) or despreading? Cheers, Eric Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
"Eric Jacobsen" <eric.jacobsen@ieee.org> wrote in message news:4228c479.58641843@news.west.cox.net...> On Fri, 4 Mar 2005 13:40:03 -0600, "Dilip V. Sarwate" > <sarwate@YouEyeYouSee.edu> wrote: > >>One particular application of more direct interest to comp.dsp denizens >>is the following. ...... >>Alternatively, if we *permute* the sequence x[k] appropriately, then >>the Hadamard transform of the permuted sequence is, with appropriate >>multiplicative constants and re-ordering (bit shuffling), the >>crosscorrelation >>between the maximum length sequence and x[k]. Is it worth it? Sure. >>there is a fast Hadamard transform algorithm that uses only m.2^m >>additions/subtractions and *no* multiplications which saves a lot of >>computation as compared to three DFTs, fast or not. This idea was used >>in the Mariner 9 mission's communications systems about 35 years ago. >>Some details (and circuit diagrams of the Green machine that implemented >>the fast Hadamard transform) algorithm are in Chapter 14 of the well-known >>MacWilliams and Sloane text on error-control codes. > > Thanks for the note. > > I can easily see how enough scrambling of the HT basis functions would > provide a crosscorrelation of an MLLF sequence with an input sequence > since the kernels of the HT (and most transforms) are dot products. > That seems to me to be just redefining a series of carefully arranged > dot products as a transform, which can easily turn into a case of > semantic argument about what is or is not a transform.> This assumes I've understood you correctly, though, which may not be > the case. I'm just imagining the permuting and bit shuffling you were > describing could perhaps also be accomplished by fiddling with the > basis function. In any case, I can easily see the computational > advantage, though.It is possible to permute the basis functions (rows of the Hadamard matrix) instead of the sequence x[k], but, after permutation, the Hadamard matrix may not support the *fast* algorithm, which depends on the structure of the matrix being of the form H_m-1 H_m-1 H_m = H_m-1 -H_m-1 There is still a computational advantage of sorts with a permuted matrix though, since we need (2^m)^2 additions/subtractions to grind things out (and no multiplications) as compared to 3 (or 2) FFTs.> For the Mariner 9 case, then, I'm assuming it was used for either > synchronization (the correlation function again) or despreading?The Mariner 9 code was essentially a (31,6) PN sequence code (the m-sequence and its shifts and complements). Crosscorrelating the received signal with the m-sequence was effectively computing the autocorrelation function of the m-sequence (a thumbtack). The machine used the fast Hadamard transform idea to compute all crosscorrelation values simultaneously, and the location of the peak value in the transform gave 5 data bits and the sign of the peak the 6th data bit. Was it spreading? or was it coding? or was it 31-ary orthogonal modulation? Let's not get into semantic discussions....
Reply by ●March 5, 20052005-03-05
On Fri, 4 Mar 2005 17:37:30 -0600, "Dilip V. Sarwate" <sarwate@YouEyeYouSee.edu> wrote:>The Mariner 9 code was essentially a (31,6) PN sequence code >(the m-sequence and its shifts and complements). Crosscorrelating >the received signal with the m-sequence was effectively computing the >autocorrelation function of the m-sequence (a thumbtack). The machine >used the fast Hadamard transform idea to compute all crosscorrelation >values simultaneously, and the location of the peak value in the >transform gave 5 data bits and the sign of the peak the 6th data bit. > >Was it spreading? or was it coding? or was it 31-ary orthogonal >modulation? Let's not get into semantic discussions....Dilip, Thanks again, this makes sense and does answer my question. I agree on the semantics, too. ;) Cheers, Eric Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
Reply by ●March 6, 20052005-03-06
eric.jacobsen@ieee.org (Eric Jacobsen) wrote in message news:<422a02f6.140174187@news.west.cox.net>...> On Fri, 4 Mar 2005 17:37:30 -0600, "Dilip V. Sarwate" > <sarwate@YouEyeYouSee.edu> wrote: > > >The Mariner 9 code was essentially a (31,6) PN sequence code > >(the m-sequence and its shifts and complements). Crosscorrelating> >the received signal with the m-sequence was effectively computing the > >autocorrelation function of the m-sequence (a thumbtack). The machine > >used the fast Hadamard transform idea to compute all crosscorrelation > >values simultaneously, and the location of the peak value in the > >transform gave 5 data bits and the sign of the peak the 6th data bit. > > > >Was it spreading? or was it coding? or was it 31-ary orthogonal > >modulation? Let's not get into semantic discussions.... > > Dilip, > > Thanks again, this makes sense and does answer my question. > > I agree on the semantics, too. ;) > > Cheers, > > Eric > Eric Jacobsen > Minister of Algorithms, Intel Corp. > My opinions may not be Intel's opinions. > http://www.ericjacobsen.orgWhat did you think of my method of generating Gaussian noise with the Hadamard transform? I think the main use will be for optimisation and neural nets. I would call my efforts persistence research (ie 1984 to 2004) done in complete isolation from any sources of information on the Transform (I only got the internet in 2003), certainly it is not explained by any great ability. Hope it's useful. I published a couple of articles in Servo Magazine (Feb 2004, Oct 2004) about it. More for the money that anything else. It's only what was on my web page anyway. Sean O'Connor
Reply by ●March 7, 20052005-03-07
On 04 Mar 2005 07:41:04 -0500, Randy Yates <randy.yates@sonyericsson.com> wrote:>Hi Eric, > >Even Eric Weisstein's "CRC Concise Encyclopedia of Mathematics," which >usually has a prolific amount of information and references on such topics, >simply states, > > A Fast Fourier Transform-like algorithm which produces a hologram of an > image. > >There were no references. > >I could also find no information on the subject in either Poularikas' >"The Transforms and Applications Handbook" or Bracewell's "The Fourier >Transform and its Applications." > >Good luck! >-- >Randy YatesRandy, I checked the indices in nearly everything I have, including Abramowitz and Stegun as well as the CRC handbook. I figure between those two if it ain't in there it's close to not existing, but neither had a reference. Fortunately there are groups like this to which we can turn, though. ;) Cheers, Eric Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
