All,
I'm trying to simplifiy the following equation for the zero'th order
modified Bessel function of the first kind. I'm using the
approximation for the Bessel function as
Io(z) = exp(z)/sqrt(2*pi*z)
I would like to have the natural logarithm of this function
log(Io(z)) = log(exp(z) / sqrt(2*pi*z))
= z + log(1/sqrt(2*pi*z))
but i don't want to have to calculate the log of a sqrt function.
What I'd like is a simplification that gives me an easy way to calc
the log(Io(z)) for each value of z. Any ideas?
CW
Bessel function simplification problem
Started by ●March 4, 2005
Reply by ●March 4, 20052005-03-04
Hello CW, If Io(z) approx exp(z)/sqrt(2*pi*z) then log(Io(z)) approx z-0.5*log(2*pi*z) = z-log(z)/2 -A where constant A = log(2pi)/2 IHTH, Clay
"CW" <prada_white@yahoo.ca> wrote in message news:8c58d246.0503040759.2d9d6f60@posting.google.com...> All, > > I'm trying to simplifiy the following equation for the zero'th order > modified Bessel function of the first kind. I'm using the > approximation for the Bessel function as > > Io(z) = exp(z)/sqrt(2*pi*z) > > I would like to have the natural logarithm of this function > > log(Io(z)) = log(exp(z) / sqrt(2*pi*z)) > > = z + log(1/sqrt(2*pi*z)) > > but i don't want to have to calculate the log of a sqrt function. > What I'd like is a simplification that gives me an easy way to calc > the log(Io(z)) for each value of z. Any ideas? > > CWHi CW loq(sqrt(x)) = log(x)/2 (I think) so you are trying to simplify z-log(z)/2-log(2*pi). good luck - Mike
Sorry, i should have added that z is not bounded -1 < z < 1 so I'm not sure that the Mclaurin series will help me. what i can say about z is that it will be a real non-negative number. Does that shed any more light? CW
"CW" <prada_white@yahoo.ca> wrote in message news:8c58d246.0503040759.2d9d6f60@posting.google.com...> All, > > I'm trying to simplifiy the following equation for the zero'th order > modified Bessel function of the first kind. I'm using the > approximation for the Bessel function as > > Io(z) = exp(z)/sqrt(2*pi*z) > > I would like to have the natural logarithm of this function > > log(Io(z)) = log(exp(z) / sqrt(2*pi*z)) > > = z + log(1/sqrt(2*pi*z)) > > but i don't want to have to calculate the log of a sqrt function. > What I'd like is a simplification that gives me an easy way to calc > the log(Io(z)) for each value of z. Any ideas? > > CWHi CW again : I should have said z-log(z)/2 -log(2*pi)/2 sorry. Mike
CW wrote:> All, > > I'm trying to simplifiy the following equation for the zero'th order > modified Bessel function of the first kind. I'm using the > approximation for the Bessel function as > > Io(z) = exp(z)/sqrt(2*pi*z) > > I would like to have the natural logarithm of this function > > log(Io(z)) = log(exp(z) / sqrt(2*pi*z)) > > = z + log(1/sqrt(2*pi*z)) > > but i don't want to have to calculate the log of a sqrt function. > What I'd like is a simplification that gives me an easy way to calc > the log(Io(z)) for each value of z. Any ideas? > > CWMy first idea is that you've forgotten some basic concepts about logarithms. log(a*b) = log(a) + log(b). log(a^x) = x * log(a). 1/sqrt(2*pi*z) = (2*pi*z)^(-1/2) therefore log(1/sqrt(2*pi*z)) = -(log(2*pi) + log(z))/2. You still have to calculate the log, but you now don't have to calculate the square root as well. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Thanks for all the quick responses Clay, Mike and Tim. So I guess i'm down to calculating z-log(z)/2 upon each iteration, as the other term can be precomputed. So is the calculation of a log term computationally expensive? That was my main motivation for trying to remove it. CW
"CW" <prada_white@yahoo.ca> wrote in message news:1109954279.983132.154090@g14g2000cwa.googlegroups.com...> Thanks for all the quick responses Clay, Mike and Tim. > > So I guess i'm down to calculating z-log(z)/2 upon each iteration, as > the other term can be precomputed. So is the calculation of a log term > computationally expensive? That was my main motivation for trying to > remove it. > > CW >Hi CW - in general yes. There are a whole load of tricks to simplify it though most of which seem to have been discussed in this newsgroup so you ought to find something to suit you in the archives if you are using fixed point math. Also I believe that Ray Andraka published a trick on www.dpsguru.com if you are using floating point. best of luck - mike
CW wrote:> All, > > I'm trying to simplifiy the following equation for the zero'th order > modified Bessel function of the first kind. I'm using the > approximation for the Bessel function as > > Io(z) = exp(z)/sqrt(2*pi*z) > > I would like to have the natural logarithm of this function > > log(Io(z)) = log(exp(z) / sqrt(2*pi*z)) > > = z + log(1/sqrt(2*pi*z)) > > but i don't want to have to calculate the log of a sqrt function. > What I'd like is a simplification that gives me an easy way to calc > the log(Io(z)) for each value of z. Any ideas? > > CWIf course, log(1/sqrt(x)) = -log(sqrt(x)) = -[log(x)]/2. Won't that do? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
