Rune Allnor schrieb:> To me, this sounds as a zero-phase filter. Is is possible > to use a linear phase filter and delay the output stream > sligthly?Delaying the stream is no problem at all but I'll have to look up what a linear phase filter is;). Thomas
Processing a signal stream
Started by ●March 7, 2005
Reply by ●March 8, 20052005-03-08
Thomas,> I will try some different weighting functions and > see what fits best.I guess one other thing you could try is to use a short-time fourier transform with a Gaussian weighting window (also called the Gabor transform). The Gaussian window provides the best time-frequency resolution that's especially useful for non-stationary signals. Or, you could experiment with filter banks (wavelets). In fact, I guess the problem you're facing was the reason why wavelets were invented! - Ravi
Mike Yarwood schrieb:> Hi Thomas - from your discription it sounds as though you don't window again > after the ifft and before you reassemble your overlapped blocks - I would > certainly try this , in fact I would try doing this without windowing in the > forward process first then try different weights in the forward/return > direction.You're right. I think to window the resulting blocks would eliminate the problem with the discontinuities but otoh leave notable variations on the loudness, no? That was the reason to use overlapping blocks. They aren't that bad after all and I slowly get the feeling that the main problem is my high expectation;(.> Best of Luck - MikeI'll need it, thanks Mike. Thomas
Dr. Thomas Radtke wrote:> Rune Allnor schrieb: > >> To me, this sounds as a zero-phase filter. Is is possible >> to use a linear phase filter and delay the output stream >> sligthly? > > > Delaying the stream is no problem at all but I'll have to look up what a > linear phase filter is;). > > ThomasThomas, "Linear phase" is jargon for phase that varies linearly with frequency. In other words, a plot of phase shift vs. frequency is a straight line. In most instances, the plot passes through the origin. In those instances, it is the frequency manifestation of a pure delay in time. A delay sufficient to retard 50 Hz by 30 degrees also retards 100 Hz by 60 degrees, and so on. A linear-phase filter, easily constructed as an FIR filter with symmetric coefficients, is equivalent to a no-phase-shift filter and a delay of just about half the filter's number of taps. If there are an odd number of taps, the delayed but unfiltered signal is available at the middle tap. That's probably more than you want to know, but so what? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●March 9, 20052005-03-09
Jerry Avins schrieb: [..]> > That's probably more than you want to know, but so what? >:) No, I actually want to learn as much as possible about everything thats related to my project. It's a hobby for me so I'm not under any time constrains. You guys gave me a lot to try and to think about, thanks to all of you - for now;). Thomas
