Help with removing transient oscillations in a force signal
Started by John Gibson ●March 8, 2005
Jerry Avins wrote:
> John Gibson wrote: > > Thank you for your considered responses. To further elaborate: > > > > - The force sensor (a semiconductor piezo-resistive sensor) is part
of
> > the system, and the oscillations are the result of the entire
system
> > vibrating in response to the initial impact. > > > > - We are unable to accurately model the system as a
spring/mass/damping
> > system since we cannot know the effective mass of the system due to > > external influence. > > > > Reading your comments has made me revise my perspective on the
problem.
> > The way I see it is that there are two discrete signals being
measured;
> > a short-term transient signal (the sharp step resulting from the > > initial impact) and a long-term steady state signal (the force
applied
> > by the object as it is in contact with the system and the signal
that
> > we are really interested in). Whist I agree that the oscillations > > resulting from the initial impact are a real part of the signal,
from a
> > system processing point of view they are noise and we would like to > > remove them if possible. The ideal system would produce the same
force
> > readings irrespective of if the object coupled with the system with
a
> > hard impact (large oscillations) or a gentle impact (minimal > > oscillations). > > > > Thus, the problem is really "how can we remove the effects of the > > initial transient signal that is not of interest to the system?"
Clay
> > suggested measuring the impulse response and de-convolving, which
is
> > something we considered. However, we are again hampered by the fact > > that the impulse response is dependent on the mass of the system,
which
> > is not constant. > > > > What I was hoping for was some kind of adaptive algorithm that
could
> > detect the magnitude and frequency of a damped oscillation (the
same
> > way an echo canceller might detect the lag and magnitude of an
echo)
> > thus allowing removal. Alternatively, perhaps there is a signal > > processing technique that allows the two signals to be separated
and
> > processed separately. Perhaps I am being overly optimistic in
thinking
> > this, but the problem seems like it would be very common in systems > > that use sensors (force or otherwise) and thus there might be a > > well-known solution. > > > > Best regards, > > John > > John, > > Imagine that the system compliance is made insignificantly small.
(That
> can be done.) How would impact then affect your measurements? The > initial oscillations you now read are true measurements of the > oscillating force on your sample as it and the weighing platform
move.
> > The mass of your sample and its velocity at impact tell you the
amount
> of energy that something has to absorb before the transient is > dissipated. The duration of the dissipation interval will provide a > useful estimate of the power required to do that with an active
absorber.
> > As it is, you want to avoid measuring what is there and instead
display
> what would have been there if only .... That's hard. > > Jerry > -- > Engineering is the art of making what you want from things you can
get.
=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF= =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF= =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF It sounds like you have a decaying oscillation riding on the response that you seek. I wonder if you could track each successive positive and negative peak in the response and subtract them to estimate the waveform that the oscillation is superimposed upon. John
"John Gibson" <johngibson1968@hotmail.com> wrote in message
> > We have also tried a number of DSP techniques to remove the > oscillations, including using a notch filter, but the frequency of the > oscillation is not constant and depends on the mass of the system > (which is not constant). Does anyone know of a digital signal > processing technique that can be used to attenuate the oscillations? > The system samples at 500 Hz and measures a force signal up to 200 Hz. > The oscillations occur at between 60 Hz to 120 Hz and are often of a > similar magnitude as the initial force applied to the sensor (in other > words, the force signal can, at times, oscillate almost back to the > zero-force level). > > Your comments and suggestions would be very much appreciated. > > Regards, > John
Hi John, I need to know something more about the spectrum of your noise and your signal. -- oscillation at first glance are sinusoidal? I mean, is the first armonic preatty high compared to the others composing your noise? --parasitic oscillation are not fixed and they drift in the range 60-120Hz, isn't it? -- what about the spectrum of your signal while parasitc oscillation are drifting? you told that your signal is in the range 0-200Hz and that the oscillation amplitudes are so high that they can pull down to zero the signal in certain istants. from your words I understand that signal spectrum and noise spectrum "share" the same frequency range. if the signal spectrum looks different from noise spectrum, we can do something for suppressing it. By "different" I mean different from a comb spectrum as probably as the noise is. I alredy faced a problem similar to yours in the past. I had to remove sea waves oscillation capured from a ship navigation system launching ultrasonic waves on the sea surface. In that case, noise and signal was separated because signal was the DC component and noise was the oscillation one. spectrum of the waves had several lines but the main issue was that the frequency wasn't fixed because of the ship motion on the sea surface. in fact, the ship could move in the wave direction, or in the orthogonal direction, or in opposite direction... and can also change direction during his cruise causing heavy drifting in the frequencies composing the noise spectrum. as limit case, the frequency of the noise was "zero" when the ship was riding a wave. don't think about oceanic waves... the waves I was concerned were "small" and comparable to the ones you see on a small lake with a soft breeze. I wait for your comments. Bye Jack
John Gibson wrote:
> Thank you for your considered responses. To further elaborate: > > - The force sensor (a semiconductor piezo-resistive sensor) is part of > the system, and the oscillations are the result of the entire system > vibrating in response to the initial impact. > > - We are unable to accurately model the system as a spring/mass/damping > system since we cannot know the effective mass of the system due to > external influence. > > Reading your comments has made me revise my perspective on the problem. > The way I see it is that there are two discrete signals being measured; > a short-term transient signal (the sharp step resulting from the > initial impact) and a long-term steady state signal (the force applied > by the object as it is in contact with the system and the signal that > we are really interested in). Whist I agree that the oscillations > resulting from the initial impact are a real part of the signal, from a > system processing point of view they are noise and we would like to > remove them if possible. The ideal system would produce the same force > readings irrespective of if the object coupled with the system with a > hard impact (large oscillations) or a gentle impact (minimal > oscillations). > > Thus, the problem is really "how can we remove the effects of the > initial transient signal that is not of interest to the system?" Clay > suggested measuring the impulse response and de-convolving, which is > something we considered. However, we are again hampered by the fact > that the impulse response is dependent on the mass of the system, which > is not constant. > > What I was hoping for was some kind of adaptive algorithm that could > detect the magnitude and frequency of a damped oscillation (the same > way an echo canceller might detect the lag and magnitude of an echo) > thus allowing removal. Alternatively, perhaps there is a signal > processing technique that allows the two signals to be separated and > processed separately. Perhaps I am being overly optimistic in thinking > this, but the problem seems like it would be very common in systems > that use sensors (force or otherwise) and thus there might be a > well-known solution. > > Best regards, > John >
Sometimes a structure will have locations where the oscillations are anti-podal to other points on the structure. It may be possible to group a number of sensors together so that the structure borne oscillations cancel and the external force appears as a common mode signal. If you had a method of calibrating the impact at the object that does the impacting, it might make things a bit easier. Also don't assume the that the imparted impact is a pure step function unless you have a good reason to assume so, particularly if the impacting object has its own modes of oscillation.
of
spring/mass/damping
Hello John, When we view something like this as being modeled by a differential equation, then we know the solution to be a sum of the homogeneous and particular solutions. And it sounds like you only want the particular solution without the homogeneous one. The simplest way is to start the system with no stored energy. I.e., have the springs in their lowest energy states. Also do you have something moving vertically against gravity, so gravitational potential energy is a concern? But if you start with zero energy and then watch the response to the applied force, the result will be just the particular solution. Do you have a mechanical model in terms of unknown masses, dampening constants, and spring constants? If you find the impulse response, then you should be able to work backwards to find your effective mass, etc. Or does your system have a dynamic configuration where modeling by a linear equation will fail? Are the constraints on the motion holonomic? My approach would be to write out the Lagrangian or Hamiltonian for the system and work from there. Let us know more, and we may be able to help more. Clay
Thank you again to those who responded. I think I have the answer to my
question, even if it is not the one that I wanted. That is, that this
problem is difficult, and no well-known digital signal processing
solution exists (at least, not amongst the formidable knowledge of the
comp.dsp readers). I have also not found a general solution to the
problem in the research literature. The suggested idea of modelling the
system is probably beyond the scope of the project, the processing
power of the micro-controller in the system, and my mathematical
ability.
It seems that part of the problem is that most systems using force
sensors are only interested in static readings, so they simply apply
some mechanical damping and wait for the oscillations to decay. Systems
that do require dynamic force signals generally have low bandwidths
(e.g. less than 30 Hz) and thus can simply low-pass filter out the
oscillations as they generally occur at frequencies above this.
The solution I am considering is that we find a way to mechanically
raise the effective spring constant (the "K") of the system
(essentially increasing the "stiffness" of the oscillating components),
thus raising the natural frequency of the oscillations above that of
the required bandwidth where they can be easily removed using a
low-pass filter. However, this approach does have drawbacks, including
potentially reducing the long-term reliability of the components in the
system.
We should probably also reconsider the 200 Hz bandwidth requirement,
which may be excessive (one document said something like "everything
you wanted to know about a mechanical system occurs at frequencies
below 100 Hz, with > 90% of the action below 30 Hz").
Best regards,
John
P.S. Am I the only one who didn't know what a "holonomic constraint"
was? I will have to work that into the discussion at the next design
meeting...
news:1110324375.597629.230530@l41g2000cwc.googlegroups.com...
John, Let me paraphrase back and augment what you've said above: "We have a "system" to which is applied a step force. That is, the force is rather instantly applied and is thereafter maintained" The electrical analogy would be a circuit to which a fixed voltage is applied - possibly through some source impedance. "We see an oscillatory transient when the step force is applied. This is not of interest to us. How can we see the result of the steady force only?" The electrical analogy would be a circuit to which a fixed voltage is applied and we are interested in knowing the DC output at some node in the system - perhaps at the same node to which the voltage was applied. From this I'm imagining a "system" that looks like this: A complex structure "A" of masses, springs and weights. Another complex structure "B" of masses, springs and weights. Structure A has an iron plate on its periphery. It is initially at rest. Structure B has a large magnet on its periphery such that should Structure B impact Structure A with appropriate orientation, at *any* velocity, the magnet will stick the two structures together forming Structure C which is a composite of Structures A and B. Structure B is initially moving toward Structure A with some velocity. I can suppose that Structure "A" is fixed and that Structure "B" is variable. So, we are going to start our analysis at the exact instant when the two structures collide and become one. This will be the initial condition. If we assume that Structure A is at rest so the springs in A will only be set by gravity. Structure B is also at rest except it has a linear velocity, so all the masses in Structure B will have a velocity, and the springs in B will be set only due to gravity. This completely describes the initial condition of all the masses and springs at impact - whether we know what they are or not. Upon impact, Structure C is formed. It is the same as A and B except that there is now coupling between A and B that wasn't there before. Accordingly, the differential equations that describe the reaction of C is potentially somewhat different than the differential equations that describe the reaction of A or B to external forces. Perhaps this is going further than you need but it's a nice model of what appears to be the situation. You can certainly simplify A or B or C according to what you really have - to simplify this description. A solution of the differential equations for C given the initial conditions provided by A and B is what results in all of the forces and motions that occur after impact. A span of possibilities might look like this: 1) Structure A is a thick-walled steel box that is fastened to the earth such that impact of Structure B will not move Structure A. The only thing that happens is the walls of the box vibrate at impact - and vibrate at relatively high frequencies. Thereafter, Structure A simply transfers the force imparted by Structure B. Structure B is an hydraulic ram that strikes and presses on Structure A. It is so large and massive that any vibrations are at very, very high frequencies, are of low amplitude and dampen very quickly. The major observables are the constant force imparted to A and the initial vibrations of A. (A lowpass system with few natural modes). 2) Structure A is the same as above but has rods of various lenghts welded to it. The impact of Structure B causes all of the rods to vibrate at their own natural frequencies - of which there are many. None of them are damped very much so the vibrations continue for a long time. Structure B has similar rods attached to it that add even more frequencies. (A lowpass system with lots of natural modes) 3) Structure A is the same as in #1 but is not fastened to the earth such that impact of structure B will move Structure A - eventually structure C will take on a velocity and there will be no force between Structures A and B. (a highpass system). 4) ....would be the combination of #2 and #3. We note that #3 and #4 only have transient responses. There is *no* steady state response of force between A and B - er.... it is zero. #1 and #2 have a steady state response of force between A and B as I've tried to describe them. So, I can imagine that your situation is like #1 and #2 and not like #3 and #4. Is that so? And, I can imagine that you want to know the steady state response very soon after impact. Otherwise, the solution to your problem is to simply wait for steady state to be dominant. OK, so if this is your objective then it appears that you want to remove all of the transient motion and force and extract the steady state. This would be very similar to lowpass filtering the response. This gives rise to two cautions: a) A lowpass filter forces you to wait because it has a time contant or transient response time that is roughly the reciprocal of its bandwidth. b) The system itself may be a lowpass filter such that time must pass before the steady state response presents itself. In this case, lowpass filtering the transient may have no impact - because the system itself is filtering things even more. I'm not sure this answers any questions but perhaps it improves insight and will serve to focus follow-on questions. Note that situation #2 has lots of frequencies present. This implies a lowpass filter with relatively low bandwidth. On the other hand, situation #1 has many fewer frequencies. This implies a lowpass filter with relatively higher bandwidth / faster response time. If you had the differential equations (but you've said you don't) then you could solve them on a computer that runs faster than the system response time and could predict the steady state outcome before it happens. That is, you could sample the initial results and solve a companion problem that would predict the future of the system. Lacking a system model and differential equaitons, I think it would be pretty easy to show that the initial response is not an indicator of the steady state response. Here is an electrical analogy: +-----+ +-----------------+ R1 +--------+-------+ | | | | | | +-----+ | | | | | +----|-----+ +-+-+ +-+-+ | | | | | | | | |R2 | |C1 | | | +-+-+ +-+-+ | Vi | | | | =0@t<0 | | | | =5@t>=0 | +---+---+ +----+-----+ | | +------------ | | | +-+-+ | | | Vo | |R3 | | +-+-+ | | +------------------------------------+------------ Here assume that C is very large - this masks the value of R2. The initial value of Vo is: Vo@0 = 5*(R3)/(R1+R3) at t=0 which gives *no clue* that the steady state value of Vo is: Vo@inf = 5*(R3)/(R1+R2+R3) There is no filter that will allow you to get Vo@inf from Vo@0 unless you know the details of the sytem - in this case about R2 specifically. Fred
John Gibson wrote:
> Thank you again to those who responded. I think I have the answer to my > question, even if it is not the one that I wanted. That is, that this > problem is difficult, and no well-known digital signal processing > solution exists (at least, not amongst the formidable knowledge of the > comp.dsp readers). I have also not found a general solution to the > problem in the research literature. The suggested idea of modelling the > system is probably beyond the scope of the project, the processing > power of the micro-controller in the system, and my mathematical > ability. > > It seems that part of the problem is that most systems using force > sensors are only interested in static readings, so they simply apply > some mechanical damping and wait for the oscillations to decay. Systems > that do require dynamic force signals generally have low bandwidths > (e.g. less than 30 Hz) and thus can simply low-pass filter out the > oscillations as they generally occur at frequencies above this. > > The solution I am considering is that we find a way to mechanically > raise the effective spring constant (the "K") of the system > (essentially increasing the "stiffness" of the oscillating components), > thus raising the natural frequency of the oscillations above that of > the required bandwidth where they can be easily removed using a > low-pass filter. However, this approach does have drawbacks, including > potentially reducing the long-term reliability of the components in the > system. > > We should probably also reconsider the 200 Hz bandwidth requirement, > which may be excessive (one document said something like "everything > you wanted to know about a mechanical system occurs at frequencies > below 100 Hz, with > 90% of the action below 30 Hz"). > > Best regards, > John > > P.S. Am I the only one who didn't know what a "holonomic constraint" > was? I will have to work that into the discussion at the next design > meeting...
Holonomic restraints are divided into two classes: rhenomorous restraints (those which explicitly involve time) and scleronomous restraints (in which time is not an explicit variable). (I had to look it up.) I think I see a way to solve your problem in principle if your system is linear. (It's easy to make the system stiffer, but there can be no damping without motion. and impact energy must be dissipated.) Assume for simplicity that the system consists of a single spring and mass, and that the mass to be measured adds directly to the system mass. (A more complex system can also be analyzed. The unladen system, if struck with a hammer, will ring at a certain frequency. A load a mass will change that frequency predictably. The frequency alone provides only an inaccurate estimate of the mass, but there are cookbook methods, now nearly forgotten, for accurately predicting where a lightly galvanometer will ultimately settle. Go to it: it's just a nasty differential equation that will simplify to something tractable in the end. To stiffen the sensor, use it as a null meter. Calibration is unimportant. Oppose the motion with an appropriate actuator (piezoelectric, magnetostrictive, solenoid, what have you) and take as your force indication the strength of the excitation needed to prevent the sensor from reading anything. The higher the gain of the feedback loop, the less the overall compliance. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
news:1110409275.555666.152490@o13g2000cwo.googlegroups.com...
> > P.S. Am I the only one who didn't know what a "holonomic constraint" > was? I will have to work that into the discussion at the next design > meeting... >
Hello John and others, Holonomic constraints are important when using generalized coordinates to describe a mechanical system's motion. For example LaGrange's method, based on the principle of least action, uses position and velocity. Hamilton's method adds nothing new to the physics, but instead reformulates the problem in terms of position and momentum. Since each of the coordinates (individual positions, velocities, and momenta) in both methods are treated independently, holonomic constraints make the problem simpler to solve. In fact you end up with a differential equation in only the important coordinates. For example if you have an object rolling along a rough surface without slipping, this nonholonomic constraint removes a degree of independence between the angular position and translational position. This throws a bit of a wrench into the LaGrange or Hamilton method. I.e., you need the answer to find the answer. If you are going to get into mathematical modeling of mechanical systems, I heartily recommend Herbert Goldstein's "Classical Mechanics." This is a standard graduate text in a physics program. The book is used nationwide and even used quite a bit outside of the US. It is the standard reference for mechanics. IHTH, Clay
"John Gibson" <johngibson1968@hotmail.com> wrote in message news:<1110409275.555666.152490@o13g2000cwo.googlegroups.com>...
Hi John, I "see" you didn't take into account my "proposal"- I didn't write down my solution because I don't know if it can solve your problem. I would prefer to have a minumum of elements form you. anyway here my questions again: -- oscillation at first glance are sinusoidal? I mean, is the first armonic preatty high compared to the others composing your noise? --parasitic oscillation are not fixed and they drift in the range 60-120Hz, isn't it? -- what about the spectrum of your signal while parasitc oscillation are drifting? you told that your signal is in the range 0-200Hz and the oscillation amplitudes are so high that they can pull down to zero the signal in certain istants. from your words I understand that signal spectrum and noise spectrum "share" the same frequency range. if the signal spectrum looks different from noise spectrum, we can do something for suppressing it. By "different" I mean different from a comb spectrum as probably as the noise is. As I told you, I think I solved something similar (for my thesis in 1995). First of all I would point out that noise is what you define as "noise". e.g. for a radio-engineer, noise could be deep-space noise corrupting a radio link. for a radio-astronomer, the same noise became the signal to acquire and analyze. So for you, noise are oscillations at the output of your transducer excited by impacts or other phenomenons. I never thought about changing the mechanical parameters of your device. this is what you actually have and for this you should find a suitable processing scheme. if the spectrum of your noise is similar to a comb spectrum we may have good chances to remove it. doesn't matter if the frequencies of the comb are "moving". I adopted succesfully an adaptive notch filtering scheme for such kind of "noise". It well functions especially when the power of the noise spectrum is "concentrated" around a discrete set of frequency (like in the comb). the algorithm tunes automatically the notch(es) frequency/ies of a notch filter over the spectral(s) line(s) of your noise. briefly this is the principle: the power of the signal at the output of your notch filter is a function of the notch frequency (note: the notch bandwidth is adjustable and it must be choosen for fastest convergence of the adaptive algorithm). this sentence is true especially if your noise have a "dominant" spectral line. The adaptive algorithm move the notch in the directions established by the opposite of the gradient of the signal power at the output of the notch filter. As previously mentioned, signal power become a function of the frequency notch and the gradient is calculated respect to the frequency. if you move the notch in the direction opposite to the gradient, you are going to minimize the output power of your signal, i.e. you are going to "kill" your drifting spectral line. if the drift stops, the gradient goes to zero and the notch remain "tuned". this adaptive algoritm do not like very much a DC component in your signal. don't worry, remove it with a 1st order high pass filter and everything will function properly. with a DC component, the adaptive algorithm may try to "kill" it by moving the notch at zero frequency. removing of the DC component must be done only for the adaptive algorithm. I mean the algorithm that calculate the notch frequency assigned to the notch filter. This approach has no effect on the DC component at the output of the notch filter. Your adaptive notch filter is a tracking filter able to follow your drifting noise oscillation(s) if your system has more than one "dominant" spectral line, you can repeat the process again for "killing" also the other(s) line(s). I think this not your case. You are working with a linear mechanical system which is time-variant (mass may change...isn't it?). oscillation for such linear system are always armonic (i.e. multiple of the fundamental frequency, which is drifting because the system is time-variant). moreover, a mechanical system may have a low pass behaviour, i.e. the amplitude of the spectral lines (due to oscillations) is descendent. in this case, most of the power could be located at fundamental frequency which is a good case for using and adaptive notch filtering scheme. once you "killed" the first armonic, you know also the frequency of all the others "lines". if it's necessary you can post-process the signal at the output of the notch with another notch filter tuned at twice the first armonic.... and so on. you do not specified how fast should be your filtering scheme. Of course a "longer" processing chain will increase the time response of the system. If you give me more details I can try to retrive some matlab code I wrote and some of the articles I read that suggest me such approach. Bye
news:ycOdnQ2Y4sHOgrPfRVn-vA@rcn.net...
>> > Aren't the measured and actual forces on the sensing element the same? > Assuming that the effective mass of the linkage is small relative to the > load, deconvolving will yield a (perhaps pretty) fiction. Unless the > effective mass of the linkage is small relative to the load, the > oscillatory response depends heavily on the load. >
Hello Jerry, It depends on where he has mounted his sensor. Is it between the external force and the system, or is it simply measuring the force of constraint? Imagine he has a mass on a spring. Its impulse response is damped sinusoid. Now let's imagine John has a device with a claw that will grab the mass and move it sinusoidally for a few cycles and then let go of it. If the force sensor is between the mass and the spring, it measures the force the spring exerts on the mass. The best I can guess John wants to measure the force applied by the thing doing the initial shaking. Well he could mount the force sensor between the claw and the arm that moves the claw. This will be close to the external force being applied to the system. But John never came forth with a very good description of his system and where the sensor is mounted. So we are not able to dig very deep into his problem. Clay
