I always thought oscillations in a control loop were caused by the feedback getting 180 degrees out of phase with the input (inverted) and the gain being greater than 1 at that point. You have two choices, lower the gain or slow down the systems response to increase the phase margin. "Stan Pawlukiewicz" <spam@spam.mitre.org> wrote in message news:d0n1pi$al2$1@newslocal.mitre.org...> John Gibson wrote: > > Thank you for your considered responses. To further elaborate: > > > > - The force sensor (a semiconductor piezo-resistive sensor) is part of > > the system, and the oscillations are the result of the entire system > > vibrating in response to the initial impact. > > > > - We are unable to accurately model the system as a spring/mass/damping > > system since we cannot know the effective mass of the system due to > > external influence. > > > > Reading your comments has made me revise my perspective on the problem. > > The way I see it is that there are two discrete signals being measured; > > a short-term transient signal (the sharp step resulting from the > > initial impact) and a long-term steady state signal (the force applied > > by the object as it is in contact with the system and the signal that > > we are really interested in). Whist I agree that the oscillations > > resulting from the initial impact are a real part of the signal, from a > > system processing point of view they are noise and we would like to > > remove them if possible. The ideal system would produce the same force > > readings irrespective of if the object coupled with the system with a > > hard impact (large oscillations) or a gentle impact (minimal > > oscillations). > > > > Thus, the problem is really "how can we remove the effects of the > > initial transient signal that is not of interest to the system?" Clay > > suggested measuring the impulse response and de-convolving, which is > > something we considered. However, we are again hampered by the fact > > that the impulse response is dependent on the mass of the system, which > > is not constant. > > > > What I was hoping for was some kind of adaptive algorithm that could > > detect the magnitude and frequency of a damped oscillation (the same > > way an echo canceller might detect the lag and magnitude of an echo) > > thus allowing removal. Alternatively, perhaps there is a signal > > processing technique that allows the two signals to be separated and > > processed separately. Perhaps I am being overly optimistic in thinking > > this, but the problem seems like it would be very common in systems > > that use sensors (force or otherwise) and thus there might be a > > well-known solution. > > > > Best regards, > > John > > > > Sometimes a structure will have locations where the oscillations are > anti-podal to other points on the structure. It may be possible to > group a number of sensors together so that the structure borne > oscillations cancel and the external force appears as a common mode > signal. If you had a method of calibrating the impact at the object > that does the impacting, it might make things a bit easier. Also don't > assume the that the imparted impact is a pure step function unless you > have a good reason to assume so, particularly if the impacting object > has its own modes of oscillation.
Help with removing transient oscillations in a force signal
Started by ●March 8, 2005
Reply by ●August 17, 20052005-08-17
