A challenging DSP problem
Started by Unknown ●March 8, 2005
Hi all
The problem is to detect repeating patterns of music in any
(Movie/Album)Song.
The duration of repeating pattern is dynamic is sometimes well over 2
seconds.
Therefore for a 44.1khz song 16-bit stereo , the buffer size req for
coreelation itself would be 1.76mb .Can anybody suggest some good DSP
techniques to overcome the buffer problem and still be able to extract
the repeating patterns thro' out the song.
Hoping for a solution.
vijay
Why not just buffer it in external SDRAM?
<duvijan@gmail.com> wrote in message
news:1110270525.879539.317270@g14g2000cwa.googlegroups.com...
> Hi all > > The problem is to detect repeating patterns of music in any > (Movie/Album)Song. > The duration of repeating pattern is dynamic is sometimes well over 2 > seconds. > Therefore for a 44.1khz song 16-bit stereo , the buffer size req for > coreelation itself would be 1.76mb .Can anybody suggest some good DSP > techniques to overcome the buffer problem and still be able to extract > the repeating patterns thro' out the song. > > Hoping for a solution. > vijay >
"Brad Griffis" <bradgriffis@hotmail.com> wrote in message
news:p6iXd.17724$hU7.12216@newssvr33.news.prodigy.com...
> Why not just buffer it in external SDRAM? > > > <duvijan@gmail.com> wrote in message > news:1110270525.879539.317270@g14g2000cwa.googlegroups.com... >> Hi all >> >> The problem is to detect repeating patterns of music in any >> (Movie/Album)Song. >> The duration of repeating pattern is dynamic is sometimes well over 2 >> seconds. >> Therefore for a 44.1khz song 16-bit stereo , the buffer size req for >> coreelation itself would be 1.76mb .Can anybody suggest some good DSP >> techniques to overcome the buffer problem and still be able to extract >> the repeating patterns thro' out the song. >> >> Hoping for a solution. >> vijay >> > >
Hi Vijay, If you could find a way of characterising what was important in about 200 milliseconds of your HIFI source and encoding that into about a 20 bytes 'key' or less then you could store that instead and look for repeat patterns in key values much more easily. Best of Luck - Mike
Here's one suggestion: LPF, downsample to the point where the time window is tractable, then use autocorrelation. If the pattern has significant energy at lower frequencies, this may work.
Mark Borgerding wrote:
> duvijan@gmail.com wrote: > > Hi all > > > > The problem is to detect repeating patterns of music in any > > (Movie/Album)Song. > > The duration of repeating pattern is dynamic is sometimes well over
2
> > seconds. > > Therefore for a 44.1khz song 16-bit stereo , the buffer size req
for
DSP
extract
> > the repeating patterns thro' out the song. > > > > Hoping for a solution. > > vijay > > > > Here's one suggestion: LPF, downsample to the point where the time > window is tractable, then use autocorrelation. > > If the pattern has significant energy at lower frequencies, this may
work. I think you mean cross correlation.
[snip]
>> >>Here's one suggestion: LPF, downsample to the point where the time >>window is tractable, then use autocorrelation. >> >>If the pattern has significant energy at lower frequencies, this may > > work. > > I think you mean cross correlation. >
If the pattern is known, then sure, cross-correlation would work great. Without a priori knowledge, what would you correlate against? BTW, only a limited number of delays are needed from the autocorrelation sequence, sufficient to encompass the time between repeats. -- Mark P.S. I'm a papa. ( see m'boy at http://www.borgerding.net )
> john wrote: > > Mark Borgerding wrote: > [snip] > >> > >>Here's one suggestion: LPF, downsample to the point where the time > >>window is tractable, then use autocorrelation. > >> > >>If the pattern has significant energy at lower frequencies, this
may
> > > > work. > > > > I think you mean cross correlation. > > > > If the pattern is known, then sure, cross-correlation would work
great.
> Without a priori knowledge, what would you correlate against? > > > BTW, only a limited number of delays are needed from the
autocorrelation
> sequence, sufficient to encompass the time between repeats. > > > -- Mark > > P.S. > I'm a papa. ( see m'boy at http://www.borgerding.net )
Congratulations! I see what you mean, autocorrelate a big time vector containing repeats. John
Awww... Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
] P.S.    I'm a papa. ( see m'boy at http://www.borgerding.net )
Woo-hooo!!!
Congratulations, Mark!
Ciao,
Peter K.
in article eWNXd.1833$gS.1692@fe1.columbus.rr.com, Mark Borgerding at
mark@borgerding.net wrote on 03/09/2005 21:03:
and congrats from me. i was in a similar situation in '97. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
