Very narrowband filter
Started by e09 March 10, 2005
I need help on how to filter a very narrowband signal.
Signal bandwidth = 0.05 Hz
Signal frequency = 5000 Hz
Sampling rate = 30000Hz
For the filter (lowpass or bandpass FIR):
transition bandwidth = 0.02 Hz
max passband ripple = 0.15 dB
minimal stopband attenuation = 80 dB
If I can only get a lowpass filter
I will bring the signal to baseband.
I do know that I need to use multistage multirate filter.
Any help with this simulation will be appreciatted.
The simulation is in Matlab.
Thanks
e09 wrote:
> I need help on how to filter a very narrowband signal. > Signal bandwidth = 0.05 Hz > Signal frequency = 5000 Hz > Sampling rate = 30000Hz > For the filter (lowpass or bandpass FIR): > transition bandwidth = 0.02 Hz > max passband ripple = 0.15 dB > minimal stopband attenuation = 80 dB > > If I can only get a lowpass filter > I will bring the signal to baseband. > > I do know that I need to use multistage multirate filter. > Any help with this simulation will be appreciatted. > The simulation is in Matlab. > > Thanks
You don't necessarily need to use a multistage multirate filter. I haven't tried it (no Matlab on my Mac), but for starters, you might load up 'sptool' in Matlab and try to design some IIR bandpass filters for those specifications. You did not mention a phase linearity / group delay variation specification, so IIR warrants consideration, IMO. John
I am curious how many taps are acceptable and how long your startup
transient is allowed to be.  Also, is the stability of the signal such
that the frequency will not wander in and out of the passband? Does it
matter if it does?  Do you care that it will ring like crazy if you hit
it with something impulsive?
Dirk
"dbell" <dbell@niitek.com> writes:
> Do you care that it will ring like crazy if you hit > it with something impulsive?
Doesn't the answer to this question have to be either "No" or "I do but there's nothing I can do about it" if the OP does indeed require a narrow bandwidth (e.g., to improve SNR as much as possible) since narrow bandwidth == long time response? -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
No.  The answer could be "I hadn't thought it out and it isn't going to
work even if I build it."  I can't tell from the OPs post, but
considering the possibility might save the OP some time.
Dirk
Randy Yates wrote:
> "dbell" <dbell@niitek.com> writes: > > > Do you care that it will ring like crazy if you hit > > it with something impulsive? > > Doesn't the answer to this question have to be either "No" or "I do > but there's nothing I can do about it" if the OP does indeed require
a
> narrow bandwidth (e.g., to improve SNR as much as possible) since > narrow bandwidth == long time response? > -- > Randy Yates > Sony Ericsson Mobile Communications > Research Triangle Park, NC, USA > randy.yates@sonyericsson.com, 919-472-1124
"dbell" <dirkman@erols.com> writes:
> Randy Yates wrote: >> "dbell" <dbell@niitek.com> writes: >> >> > Do you care that it will ring like crazy if you hit >> > it with something impulsive? >> >> Doesn't the answer to this question have to be either "No" or "I do >> but there's nothing I can do about it" if the OP does indeed require a >> narrow bandwidth (e.g., to improve SNR as much as possible) since >> narrow bandwidth == long time response? > > No.
Then please tell me how one builds a filter that simultaneously has a very narrow bandwidth and a limited temporal response? -- % Randy Yates % "She's sweet on Wagner-I think she'd die for Beethoven. %% Fuquay-Varina, NC % She love the way Puccini lays down a tune, and %%% 919-577-9882 % Verdi's always creepin' from her room." %%%% <yates@ieee.org> % "Rockaria", *A New World Record*, ELO http://home.earthlink.net/~yatescr
Randy,
You don't.  My point was that there is an alternate answer to those you
proposed that might apply, that is (rephrased) "I do care and it makes
the solution not usable."  I asked the original questions because I
have seen people try this very type of design to find out that they
could not use it because of what was actually a fundamental property of
their design.  Since the OP was not specific about the application, I
thought I would raise some issues before he implemented the 'solution'.
Dirk
Randy Yates wrote:
> "dbell" <dirkman@erols.com> writes: > > Randy Yates wrote: > >> "dbell" <dbell@niitek.com> writes: > >> > >> > Do you care that it will ring like crazy if you hit > >> > it with something impulsive? > >> > >> Doesn't the answer to this question have to be either "No" or "I
do
require a
> >> narrow bandwidth (e.g., to improve SNR as much as possible) since > >> narrow bandwidth == long time response? > > > > No. > > Then please tell me how one builds a filter that simultaneously has a > very narrow bandwidth and a limited temporal response? > -- > % Randy Yates % "She's sweet on Wagner-I think
a tune, and
room."
ELO
Randy Yates wrote:
> "dbell" <dirkman@erols.com> writes: > >>Randy Yates wrote: >> >>>"dbell" <dbell@niitek.com> writes: >>> >>> >>>>Do you care that it will ring like crazy if you hit >>>>it with something impulsive? >>> >>>Doesn't the answer to this question have to be either "No" or "I do >>>but there's nothing I can do about it" if the OP does indeed require a >>>narrow bandwidth (e.g., to improve SNR as much as possible) since >>>narrow bandwidth == long time response? >> >>No. > > > Then please tell me how one builds a filter that simultaneously has a > very narrow bandwidth and a limited temporal response?
It can't be done. Dirk knows it can't be done. He very kindly wants to the be sure the OP knows it can't be done. I lent a physicist an adjustable power supply one time. It had a current limiter too; he specifically wanted one like that. He brought it back half an hour later, saying that it needed to be fixed. I showed him that the voltage could be set between zero and 20 volts, and the current could be clamped between a few microamps and half an amp. He said that what he needed to do was to set them simultaneously. I took him a long time to understand why that couldn't be done without adjusting the load. My neighbor once told me that the starter on his car didn't work. Asked how he knew, he said it was plain: the car wouldn't start. "It goes rrr rrr rrr, but it won't start." That one was easy. I told him "starter" was a misnomer; it's really a cranker, and the rrr rrr rrr sound proved that both battery and cranker were fine. Then I adjusted his points. Moral: never take for granted that the other guy understands the problem or the constraints on a solution. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
"e09" <ewong9@juno.com> wrote in message
news:1110490865.518669.77780@o13g2000cwo.googlegroups.com...
What the other folks were alluding to is this (I think): Are you aware that the settling time for such a filter would be around 20 seconds (1/0.05Hz) ? Is that acceptable to you?\ Fred
> Randy, > > You don't. My point was that there is an alternate answer to those you > proposed that might apply, that is (rephrased) "I do care and it makes > the solution not usable." I asked the original questions because I > have seen people try this very type of design to find out that they > could not use it because of what was actually a fundamental property of > their design. Since the OP was not specific about the application, I > thought I would raise some issues before he implemented the 'solution'.
I see now your intention - you were definitely asking a good question. However, even though it's academic, logically your response to my question was incorrect because I added the clause "if the OP does indeed require a narrow bandwidth." The case you bring up means in effect that a narrow bandwidth can't be a requirement. -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
