Fast 1-D DCT algorithms
Started by Koen March 11, 2005
Hi,
Does anyone know of working and tested code (C/C++/pseudo/...) for doing a
fast 1-D DCT ?
I know about the Numerical Recipes code, but that has a rather restrictive
license...
I also have DCT and IDCT working already using the straight implementation
from the formulas, but I'd be interested in fast versions (like there exist
for FFT for powers of 2).
Thanks in advance!
Koen
"Koen" <no@ssppaamm.com> writes:
> Hi, > > Does anyone know of working and tested code (C/C++/pseudo/...) for doing a > fast 1-D DCT ? > I know about the Numerical Recipes code, but that has a rather restrictive > license... > I also have DCT and IDCT working already using the straight implementation > from the formulas, but I'd be interested in fast versions (like there exist > for FFT for powers of 2). > Thanks in advance!
http://home.earthlink.net/~yatescr/fftk.c Have at it, and good luck. By the way, when I implemented this in 1989, my computer was a 286 PC AT without the floating-point chip. A 1024-point FFT took over a minute. When I bought my 287 chip, the time went down to 10 seconds - I was elated! -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
Our FFTW (www.fftw.org) has fast DCTs (types I-IV) for all n (not just
powers of 2).  There are also a bunch of other free libraries that
supply DCTs (e.g. FFTPACK, Ooura's code, etc.)
Regards,
Steven G. Johnson
(That's pretty slow!  Cooley and Tukey's 1965 implementation could do a
2048-point FFT in 1.2 seconds on an IBM 7095.  See
http://www.ph.utexas.edu/~itiq/chiu/cooley/p301.jpg)
(Note that the OP was asking for a DCT code, not a plain FFT.)
stevenj@alum.mit.edu writes:
> (That's pretty slow! Cooley and Tukey's 1965 implementation could do a > 2048-point FFT in 1.2 seconds on an IBM 7095. See > http://www.ph.utexas.edu/~itiq/chiu/cooley/p301.jpg)
Using double precision floating-point? I couldn't tell from the book scan.
Doh! -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
Randy Yates wrote:
> By the way, when I implemented this in 1989, my computer was > a 286 PC AT without the floating-point chip. A 1024-point FFT > took over a minute. When I bought my 287 chip, the time went > down to 10 seconds - I was elated!
Ah, Randy! Those were the days! Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
The IBM 7095 had both 36-bit single precision and 72-bit double
precision floating-point arithmetic.  The C & T paper doesn't say which
one they used, but I'm guessing that they used single precision on the
principle that they would have bragged if they had used double.
> The IBM 7095 had both 36-bit single precision and 72-bit double > precision floating-point arithmetic. The C & T paper doesn't say which > one they used, but I'm guessing that they used single precision on the > principle that they would have bragged if they had used double.
Hmm. Still, I think 24 years later we would have been doing better. Maybe I'm mis-remembering (maybe it wasn't 1024 points). It's only been 17 freakin' years (yikes!). Or did I do something wrong? Note that my computation time includes computing the twiddle factors. -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
"Koen" <no@ssppaamm.com> wrote in message news:d0rrt4$19i$1@gaudi2.UGent.be...
<snip> I don't know of any "working and tested" pseudo-code for _anything_! Sometimes it sure would be nice to have a pseudo-code compiler! :-) To Koen, sorry I don't have an answer for you. -Jon
stevenj@alum.mit.edu wrote:
> The IBM 7095 had both 36-bit single precision and 72-bit double > precision floating-point arithmetic. The C & T paper doesn't say which > one they used, but I'm guessing that they used single precision on the > principle that they would have bragged if they had used double. >
36 bits in binary, and not 32 bits in hexadecimal, had just enough precision that the need for double precision was much less common. The folks on 48 bit machines had trouble understanding why one used double precision and the folks on 60 bit machines considered double precision an obscure form of showing off that was totally unrelated to the real world. The 7090 was a 3 index version of the later 7094 which had 7 index registers. (Is the 9095 for real of just a typo?) 360 model numbers often ended in 5 like 360/65 which was a popular model. 360/75 was hardwired and faster and 360/85 was an early example of the use of memory caches.
