I'm working with Nallatech BallySHARC module and I have a problem to boot DSP through JTAG cable because it's done correctly only if I load on the FPGA the Nallatech bitstream and not my bitstream... Does anybody help me????Does anybody work with this board???? thank every body... Dario This message was sent using the Comp.DSP web interface on www.DSPRelated.com
BallySHARC JTAG problem
Started by ●March 11, 2005
Reply by ●March 11, 20052005-03-11
Did you ask technical support at Nallatech? What did they say? -- ------------------------------ Jaime Andr�s Aranguren Cardona jaac@sanjaac.com SanJaaC Electronics Soluciones en DSP www.sanjaac.com "Dario" <gll_dra@hotmail.com> escribi� en el mensaje news:O8OdnVnlrPfTD6zfRVn-1Q@giganews.com...> I'm working with Nallatech BallySHARC module and I have a problem to boot > DSP through JTAG cable because it's done correctly only if I load on the > FPGA the Nallatech bitstream and not my bitstream... > Does anybody help me????Does anybody work with this board???? > > thank every body... > > Dario > > > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.com
Reply by ●March 18, 20052005-03-18
Nallatech support didn't answer to my question. I don't know what i can do.>Did you ask technical support at Nallatech? What did they say? > >-- >------------------------------ >Jaime Andr�s Aranguren Cardona >jaac@sanjaac.com >SanJaaC Electronics >Soluciones en DSP >www.sanjaac.com > > >"Dario" <gll_dra@hotmail.com> escribi� en el mensaje >news:O8OdnVnlrPfTD6zfRVn-1Q@giganews.com... >> I'm working with Nallatech BallySHARC module and I have a problem toboot>> DSP through JTAG cable because it's done correctly only if I load onthe>> FPGA the Nallatech bitstream and not my bitstream... >> Does anybody help me????Does anybody work with this board???? >> >> thank every body... >> >> Dario >> >> >> >> This message was sent using the Comp.DSP web interface on >> www.DSPRelated.com > > >This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Reply by ●March 19, 20052005-03-19
Mmmhhhh.... I dont' know that board at all, so i am just wondering. Maybe the FPGA interfaces to the JTAG pins on the DSP too, and it's default bitstream has what it takes to CORRECTLY letting you use a JTAG cable for programming the DSP. Could you verify that? Are the schematics available to you? JaaC Dario wrote:> Nallatech support didn't answer to my question. > I don't know what i can do. > > > >Did you ask technical support at Nallatech? What did they say? > > > >-- > >------------------------------ > >Jaime Andr=E9s Aranguren Cardona > >jaac@sanjaac.com > >SanJaaC Electronics > >Soluciones en DSP > >www.sanjaac.com > > > > > >"Dario" <gll_dra@hotmail.com> escribi=F3 en el mensaje > >news:O8OdnVnlrPfTD6zfRVn-1Q@giganews.com... > >> I'm working with Nallatech BallySHARC module and I have a problemto> boot > >> DSP through JTAG cable because it's done correctly only if I loadon> the > >> FPGA the Nallatech bitstream and not my bitstream... > >> Does anybody help me????Does anybody work with this board???? > >> > >> thank every body... > >> > >> Dario > >> > >> > >> > >> This message was sent using the Comp.DSP web interface on > >> www.DSPRelated.com > > > > > > > > > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.com
Reply by ●March 21, 20052005-03-21
The schematics are not available and i can't recompile the nallatech project because it's incomplete. I think that the documentation it's incomplete about JTAG or other required feature for the FPGA. It's possible some kind of reverse engineering on the bitstream? Dario>Mmmhhhh.... I dont' know that board at all, so i am just wondering. > >Maybe the FPGA interfaces to the JTAG pins on the DSP too, and it's >default bitstream has what it takes to CORRECTLY letting you use a JTAG >cable for programming the DSP. > >Could you verify that? > >Are the schematics available to you? > >JaaC > >Dario wrote: >> Nallatech support didn't answer to my question. >> I don't know what i can do. >> >> >> >Did you ask technical support at Nallatech? What did they say? >> > >> >-- >> >------------------------------ >> >Jaime Andr=E9s Aranguren Cardona >> >jaac@sanjaac.com >> >SanJaaC Electronics >> >Soluciones en DSP >> >www.sanjaac.com >> > >> > >> >"Dario" <gll_dra@hotmail.com> escribi=F3 en el mensaje >> >news:O8OdnVnlrPfTD6zfRVn-1Q@giganews.com... >> >> I'm working with Nallatech BallySHARC module and I have a problem >to >> boot >> >> DSP through JTAG cable because it's done correctly only if I load >on >> the >> >> FPGA the Nallatech bitstream and not my bitstream... >> >> Does anybody help me????Does anybody work with this board???? >> >> >> >> thank every body... >> >> >> >> Dario >> >> >> >> >> >> >> >> This message was sent using the Comp.DSP web interface on >> >> www.DSPRelated.com >> > >> > >> > >> >> >> >> This message was sent using the Comp.DSP web interface on >> www.DSPRelated.com > >This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Reply by ●March 22, 20052005-03-22
Hi Dario wrote:> The schematics are not available and i can't recompile the nallatech > project because it's incomplete. I think that the documentation it's > incomplete about JTAG or other required feature for the FPGA.The landscape is not too appealing...> It's possible some kind of reverse engineering on the bitstream?Maybe the people at comp.arch.fpga (which you can acces from www.deja.com) can be of better help.> DarioI hope you can get it done!
