Hello, I am new to JTAG/Flash and my first project is to upload an already created file (.mhx, I think is the same as .s) to a DSP56F807 chip. So I try example first. I have breadboarded a parallel port command converter and attached it to my xp computer. Code Warrior (Special-DSC56800E v8.3) was downloaded and installed. My chip is on a pcb on a fixture with pogo pins (JTAG/Flash) and powered. I have the Code Warrior Connection Server running (CCS.exe) with the debugger=CCS 56800E Protocol Plugin with the connection type=CCS Remote Connection.(I'm not sure this is correct. I wanted to use USB TAP originally but found that the chip would not work with this TAP). Since my port card is addressed as 0xD000, I "delete all", "config cc lpt:0xD000", then save configuration. I then run from my ...flash_jtag_loader_80x_82x>flash_over_jtag.exe flash807.cfg test807.s -p0xD000 My result is: DSP56F800 Flash loader. Compiled on Jul 23 2003, 15:47:57. version Epsilon 0.7 (c) Motorola 2001 - 2002, MCSL Partial Copyright 2000-2002, Zloba Alexander I/O port driver started Using printer port at address 0xD000 JTAG IR path length: 4 JTAG DR path length: 1 (BYPASS) IDCode status: 0x9 Jtag ID: 0x1f2701d Debug Request status: 0x9 Enable OnCE status: 0x9, polls left: 10 Enable OnCE status: 0x9, polls left: 9 Enable OnCE status: 0x9, polls left: 8 Enable OnCE status: 0x9, polls left: 7 Enable OnCE status: 0x9, polls left: 6 Enable OnCE status: 0x9, polls left: 5 Enable OnCE status: 0x9, polls left: 4 Enable OnCE status: 0x9, polls left: 3 Enable OnCE status: 0x9, polls left: 2 Enable OnCE status: 0x9, polls left: 1 Enable OnCE status: 0x9, polls left: 0 Target chip refused to enter Debug mode! The target was reset, the application is running There is something wrong here. I believe I am supposed to be getting a Debug Request status:0xd, succeed on Enable OnCE, then place target chip into debug mode. Does anyone know what 0x9 instead of 0xd is telling me? Appreciate any feedback through my steps and flag any errors.... Thanks, Paul --------------------------------------- Posted through http://www.DSPRelated.com
Parallel Port Command Converter, Flash_over_jtag.exe and 56F807
Started by ●September 15, 2015
