How do I calculate entropy of a sampled signal of lenght N samples? I assume I need the PDF (probability density function) - can I use the Periodogram P(f) is this is like the histogram and use H=-sum{=1 to N of } P(k)log(P(k)) does it have to be log base 2? I assume if I take the entropy of white noise what should be? Also I notice that log(P(f) are the cepstrum coefficients. Tom
How do I calculate entropy?
Started by ●September 3, 2004
Reply by ●September 3, 20042004-09-03
Tom wrote:> How do I calculate entropy of a sampled signal of lenght N samples? > > I assume I need the PDF (probability density function) - can I use the > Periodogram P(f) is this is like the histogram and use > > H=-sum{=1 to N of } P(k)log(P(k)) > > does it have to be log base 2? > > I assume if I take the entropy of white noise what should be? > > Also I notice that log(P(f) are the cepstrum coefficients. > > > TomThe entropy of a sequence X = { x_1 x_2 x_3 ... x_N } is defined as H(X) = sum_1_to_N ( p_i log( p_i ) ) where p_i = | x_i | / || X || and || X || = sum_1_to_N ( | x_i | ). Good luck, OUP
One Usenet Poster <me@my.computer.org> writes:> Tom wrote: > > How do I calculate entropy of a sampled signal of lenght N samples? > > I assume I need the PDF (probability density function) - can I use > > the > > > Periodogram P(f) is this is like the histogram and use > > H=-sum{=1 to N of } P(k)log(P(k)) > > > does it have to be log base 2? > > > I assume if I take the entropy of white noise what should be? > > > Also I notice that log(P(f) are the cepstrum coefficients. > > > Tom > > > The entropy of a sequence X = { x_1 x_2 x_3 ... x_N } is defined as > > H(X) = sum_1_to_N ( p_i log( p_i ) ) > > where p_i = | x_i | / || X || > > and || X || = sum_1_to_N ( | x_i | ).Hold on a minute there, cowboy. Where in the tarheeled' nation did you get that? Nope. It oughta be H(X) = -1 * sum_1_to_N ( p_i log( p_i ) ), where p_i is the probability of symbol x_i occurring and log is base 2. -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
Randy Yates wrote:> Hold on a minute there, cowboy. Where in the tarheeled' nation > did you get that?"The Minimum Entropy Criterion of Range Alignment in ISAR Motion Compensation", Genyuan Wang and Zheng Bao, Radar 97, 16 Oct 1997, p. 237, equation (4). OUP
"One Usenet Poster" <me@my.computer.org> wrote in message news:10jhcr4hs9sag86@corp.supernews.com...> Randy Yates wrote: > > > Hold on a minute there, cowboy. Where in the tarheeled' nation > > did you get that? > > "The Minimum Entropy Criterion of Range Alignment in ISAR Motion > Compensation", Genyuan Wang and Zheng Bao, Radar 97, 16 Oct 1997, p. > 237, equation (4). > > OUPThanks but that s eems to be for binary data - I meant a sampled waveform.DO you suggest converting everything to binary first? Thanks Tom
Reply by ●September 4, 20042004-09-04
The entropy describes the information contained in a source, and is measured in terms of the symbol alphabet. Ex: 3.15 bits/symbol or X (alphabet elements)/symbol. So if you want to know the entropy of a sampled waveform you need to decide first your coding alphabet. For example if you consider 1024 levels and 1024 symbols you'll have. H{X} = {-1/log{1024}}* Sum {log{p(Xi=i)}*p{Xi=i} If you want a Real-Time Entropy you can use this aproximation: for i=1.N for j=1.Lenght(Buffer) Buffer[j] = input; end P = Histogram(Buffer)/Length(Buffer); // You can // calculate the histogram and divide by the number of // samples to get an approximation of P(Xi=i). H(i) = {-1/log{Length Buffer}}* Sum {log{P(k)}*P(k) end regards, David.
">> for i=1.N > for j=1.Lenght(Buffer) > Buffer[j] = input; > end > P = Histogram(Buffer,Length{P})/Length(Buffer); // You can > // calculate the histogram and divide by the number of > // samples to get an approximation of P(Xi=i). > H(i) = {-1/log{Length Buffer}}* Sum {log{P(k)}*P(k) > endSorry i meant H(i) = {-1/log{length(P)}}* Sum {log{P(k)}*P(k)} Where P length is constant, you only changes the values contained in P
"David Martinez" <macarena.dupouy@neuf.fr> wrote in message news:chbsi0$olb$1@apollon.grec.isp.9tel.net...> The entropy describes the information contained in a source, and ismeasured> in terms of the symbol alphabet. > > Ex: 3.15 bits/symbol or X (alphabet elements)/symbol. > > So if you want to know the entropy of a sampled waveform you need todecide> first your coding alphabet. > > For example if you consider 1024 levels and 1024 symbols you'll have. > > H{X} = {-1/log{1024}}* Sum {log{p(Xi=i)}*p{Xi=i} > > If you want a Real-Time Entropy you can use this aproximation: > > for i=1.N > for j=1.Lenght(Buffer) > Buffer[j] = input; > end > P = Histogram(Buffer)/Length(Buffer); // You can > // calculate the histogram and divide by the number of > // samples to get an approximation of P(Xi=i). > H(i) = {-1/log{Length Buffer}}* Sum {log{P(k)}*P(k) > end > > regards, > > David. > > > >Thanks but I am thinking outside the circle a bit here - have a look at this - I just found it.How does this fit in - am I asking the wrong question? http://www.menem.com/~ilya/digital_library/entropy/bercher_vignat_00.pdf Tom
