> > Do you mean just clipping the signal to a square? that would not be very > > musical. > > /Johan > > Square law implies that the output approximates the square of the input. > I don't think that's what you want; soft clipping is more like square > root, hut with sign retained. Arctan(ax) and arcsinh(ax) are useful > distorters. http://www.mathsnet.net/asa2/modules/p52asinh.html > > Jerry > -- > Engineering is the art of making what you want from things you can get. > �����������������������������������������������������������������������Thanks Jerry, this is the first post that makes sense to me (and understand). /Johan
Amp modelling
Started by ●March 15, 2005
Reply by ●March 19, 20052005-03-19
Reply by ●March 21, 20052005-03-21
Reply by ●March 22, 20052005-03-22
"Steve Underwood" <steveu@dis.org> wrote in message news:d183mk$7bq$1@home.itg.ti.com...> Randy Yates wrote: > > >"Jon Harris" <goldentully@hotmail.com> writes: > > > > > >>[...] > >>Yeah, it always seemed to me that the guitar guys used the "I have to crankit> >>all the way up to get a good tone" line as an excuse to play really loud. > >> > Electric guitars do need to be loud. There are made as acoustically dead > as possible to maximise their sustain. Further enhancement of sustain > comes from controlled acoustic feedback. However, since the guitar is > very dead, it takes a lot of noise to excite it. If you don't want to be > playing with the guitar right up close to the speaker, you are going to > end up with something pretty loud.I always thought that the feedback-based sustain was more used as an occasional special effect rather than a normal mode of operation, but I suppose that depends on the style of music. Plus you can get considerable sustain from compression, either a dedicated process before the distortion, or through the natural compression of the heavily overdriven amp.
Reply by ●March 23, 20052005-03-23
Nihil wrote:> Tim Wescott wrote: > > >>4ths are the classic rock & roll "power chord". > > > I think you meant the 5ths :)Fifth up, fourth down from the octave: same. Half way between is the real chiller. Sqrt(2) anyone? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Nihil wrote:> Tim Wescott wrote: > > >>4ths are the classic rock & roll "power chord". > > > I think you meant the 5ths :) >Could be -- it's been explained to me, but I'm a clarinetist - I just can't make stringed instruments do my bidding. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
in article NNOdnWclg7Hwct3fRVn-tA@rcn.net, Jerry Avins at jya@ieee.org wrote on 03/22/2005 23:24:> Nihil wrote: >> Tim Wescott wrote: >> >> >>> 4ths are the classic rock & roll "power chord". >> >> >> I think you meant the 5ths :) > > Fifth up, fourth down from the octave: same. Half way between is the > real chiller. Sqrt(2) anyone?not so bad if you're in the Locrian mode. (bwahahahahahaha!) -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
robert bristow-johnson wrote:> in article NNOdnWclg7Hwct3fRVn-tA@rcn.net, Jerry Avins at jya@ieee.org wrote > on 03/22/2005 23:24: > > >>Nihil wrote: >> >>>Tim Wescott wrote: >>> >>> >>> >>>>4ths are the classic rock & roll "power chord". >>> >>> >>>I think you meant the 5ths :) >> >>Fifth up, fourth down from the octave: same. Half way between is the >>real chiller. Sqrt(2) anyone? > > > not so bad if you're in the Locrian mode. (bwahahahahahaha!)Locrian mode? And that would B? I'll try to think in the interval. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins <jya@ieee.org> writes:> I'll try to think in the interval.Pul-LEESE! -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
