Hi Everybody, Suppose that you've been provided with a stable IIR filter (which guarantees that its impulse response will become stable). the impulse response can be generated by dividing the numerator by denominator and continuing it (long division) as long as desired. There's a point that, based on the IIR filter coefficients, can anybody give a function like C*r^-n in which n is the time index, so that it behaves like an upperbound for the absolute value of the impulse response? Let me know if you have any ideas. Vahid
Uppebounding the impulse response of an IIR filter?
Started by ●March 15, 2005
Reply by ●March 15, 20052005-03-15
<vraissi@gmail.com> wrote in message news:1110914268.819143.257260@l41g2000cwc.googlegroups.com...> Hi Everybody, > > Suppose that you've been provided with a stable IIR filter (which > guarantees that its impulse response will become stable). the impulse > response can be generated by dividing the numerator by denominator and > continuing it (long division) as long as desired. > > There's a point that, based on the IIR filter coefficients, can anybody > give a function like C*r^-n in which n is the time index, so that it > behaves like an upperbound for the absolute value of the impulse > response? Let me know if you have any ideas. > > Vahid >Hello Vahid, From your filter, find the transfer function. Then use partial fraction decomposition to break the transfer function into a sum of linear and quadratic terms, and finally inverse Z transform each of the terms to get the time domain functions. IHTH, Clay
Reply by ●March 16, 20052005-03-16
<vraissi@gmail.com> wrote in message news:1110914268.819143.257260@l41g2000cwc.googlegroups.com...> Hi Everybody, > > Suppose that you've been provided with a stable IIR filter (which > guarantees that its impulse response will become stable). the impulse > response can be generated by dividing the numerator by denominator and > continuing it (long division) as long as desired. > > There's a point that, based on the IIR filter coefficients, can anybody > give a function like C*r^-n in which n is the time index, so that it > behaves like an upperbound for the absolute value of the impulse > response? Let me know if you have any ideas. > > Vahid >Vahid, It seems to me that you might do something like this: First, recognize that the impulse response will be a superposition of terms that come from conjugate pole pairs. Next, recognize that each pole pair results in a damped sinousoid in the impulse response. The closer to the unit circle, the slower the decay. Since you don't know how the sinusoids will add without generating the impulse response itself (which it appears you don't want to do) then perhaps you assume that all the sinusoids could add at their peaks at one time or another. This suggests adding their exponentially decaying envelopes to get an upper bound. How you do this with proper scaling is an exercise I'll leave to the student. If this is too conservative an upper bound then that is also an exercise I'll leave to the graduate student. If I knew a "canned" answer, I might have given it..... but I don't. Fred
